LRP Sphere + Novak Velocity?
Hi all,
I would like to know if is possible to user the new LRP Sphere COmpetition Digital with the Novak Valocity (4.5R, I think that is not possible to use 3.5R)? There are any midifications in the sensor cable connecto? are anyone using this combination of ESC and motor? rgds Sampaio |
You should experience no problem`s using that combination together...
They are designed to perform with each other.... |
The only thing you need to know is that the Spehere's don't have a motor temp cut-off like the GTB even though the velociti motors have the sensor. So nmake sure you know your gearing or youll fry the motor. The sphere does have a esc cutoff however. This I know from personal experience :(
Hi all,
I'm interesting in LRP just because its more safety for LIPO cell... I know that LRP detects LIPO, but Novak doesn't detect it. But the thermal protections is complicated..... Other Novak's problem for me is the glitch on Kopropo 40MHz receiver, I think that the best option is wait for new Orion Brushless ESC to see if both point will be considered by them..... Waht you think? cheers Sampaio |
Just to clarify . . .The LRP doesn't dtect LiPos . . .it just offers you the setting to cut off at a safe voltage. Just so you are aware
Hi Andrew,
thanks for information...... cheers Sampaio |
