ICE question
ICE question
I am getting a motor not connected error after 2 seconds of running my lathe off of my ICE charger. I just bought this charger, charged a pack with it and now I am running in to this error.
Is this a defective unit or is it known for not being able to run a lathe?
BTW, my PS is a Rivergate 30 amp.
Thanks!
Thanks!
The same thing happened to me so i switched motor to see if it was the charger but then it worked fine. Then i put the other motor back on and wiggled the crocodile clips onto the motor terminals to make sure it had good contact and then it worked.
Try that and see but if that doesn't work you may need to get a different motor.
10 amp limit is probably your issue. I have had my motor break-in feature shut off as described after a fresh comm cut and new brushes. Try another slave motor, it should solve the problem (or lighten the spring tension on the brushes). The Hudy lathe comes with a mild motor, and I dont have the same issue when making cuts on a comm.
Thanks!
Thanks!
Had the same problem, same "Red Herring" error message. Pulling more than 10 amps is the problem.
Mike
Mike
