Xray T2'007
#1336
Originally Posted by Darint
I ran into a little challenge with the stock 116t spur, I believe a 35t pinion was as large as I could go.. So, I'd recommend a 112t spur for the smaller tire sizes..
#1337
Originally Posted by teamgp
Same here. The 112t spur allows you the range from running a high torque motor (Checkpoint), almost all the way down to high rpm mod motors. Keep in mind that the high torque or stock motor gearing will move the motor all the way forward. It will be opposite for the high rpm motors with the motor being moved to the rear.
#1340
Originally Posted by Jack Smash
Clint, what pinion and spur are you runnng with the 4.5?
#1341
where are the blank 007 setup sheet available for downloading ?
#1342
All of the documentation is available for download on www.teamxray.com in the 'Homepage -> T2'007 -> Downloads' area...
Here is a Direct link
#1343
What servo is best choice for the T2 007? Is it the Futaba 9550?
#1345
Originally Posted by Kave
I run the 9550 in mine with great success. Its perfect for a TC.
#1347
Ben:
Hi,
I have both. I really like the KO better. I have two of them and they are both in my 007's. I tried the 9550 and took it out. (it's in one of my TA-05's now). the 2413 seems smoother overall. the speed is about the same.....I think. I don't have the specs on the 9550 but even my son likes the KO and he's never happy with any servo.....there all to slow for him!!!!!!!
Hi,
