Xray T2'007
#3902
If I were to purchase another top deck (and cut away the middle) to use as 2.5mm "graphite pads", is that 2.5mm enough to allow the use of my Core 5K lipos? I am trying to avoid purchasing a new lipo pack!
#3903
Check out this link about fitting LiPos in the '007
http://www.nexusracing.com/newsdesk_...newsdesk_id=60
#3904
I am unsure if the Orion 4800 and Core 5000 are the same thickness. Looks like Nexus just raised the top deck 1.5mm on the US ed....so 2.5mm should work okay. I hope!
#3905
Thanks VernDog! Very stealth looking mod. Which 4K lipo you using?
Manutech makes a 2mm top deck shim kit now, I bought one but haven't installed yet...but looks like it will work fine. It will prob. be a snug fit to run with a base plate weight under battery. Also keep in mind, you are running the 3mm chassis that sits .5mm lower then the 2.5mm (as seen by the cuttouts in chassis for bulkheads).
With the 2.5 mm shim you are considering, you should be able to run the Core5000 with no baseplate, or a 4000 and under with baseplate.
I rate 4000's as follows...
1) SMC 4000
2) Trinity 3800
3) Orion 3800
Keep in mind, there are new gen LiPo's just now coming out at 40C...so I'd wait for the new SMC if wanting to run a baseplate LiPo combo.
Generally speaking a 5000 LiPo is 24mm thick and a 3600 is 21mm thick (with no humps or sanded off humps)
http://www.manutech.info/rcracinghom...gproducts.html
#3906
Thanks again for all the useful info Verndog!
#3907
If you all would rather not raise the upper deck or cut the bulkhead, another option would be
http://www.manutech.info/134101specs.html
this sets the rear of the battery out a little, this not only works without raising the upper deck, but also allows for "less" weight being needed, also gives good balance as the motor is sticking out opposite of where the plate sticks out. Plate was designed around the smc5000 and the 008 xray, but will work on the 007 (with a very small amount of grinding to the upper deck) and also the 009s.
#3908
#3909
007 tech question for you guys...
What is the simplest/easiest way to swap lower chassis plates?
Going foam to rubber chassis...was hoping I could support it upside-down and swap that way.
Thanks for any hints...if any exist!
#3910
If you look at the pictures of the smc5000 in the 008 frame you will see where the battery gets really close to this area, on the 007s, the upper deck is slightly wider here, and this is where the upper deck requires modification.
Hope this helps...
#3911
#3912
Hey CJ...I think he was referring to shaving a smidge from the CF top deck. Take a look at the manutech link he provided...
#3913
#3914
#3915
Sorry for the confusion... you could I suppose shave a little off of the battery pack, but in order to keep the battery case in tack, you would grind a little off the edge of the carbon fiber upper deck, right in the area were it widens out.
