Xray T2'007
Old 07-18-2007, 07:52 PM
  #2986
PitCrew's Avatar
Anybody have an email adress for Ralph Burch?
PitCrew is offline
Old 07-18-2007, 08:51 PM
  #2987
Gravity RC
Pit Crew: [email protected]
Cvt-01: the kit coppers are availible seprately, i think in a set of 4. the inboard toe definitly makes a big difference in the balance of the car, but like you said both in or out works depending on what you are looking for, i felt like i needed my car to transfer more weight over the front end and stay their longer threw the courner this is what i think it did for me. Barrys car was definitly the best but my car accually worked better with my ending set-up than it did with barrys set-up for whatever reasons.
Thanks paul
Paul L is offline
Old 07-18-2007, 09:10 PM
  #2988
VooDooPH's Avatar
Trader Rating: 18 (100%+)
BigB,
bad crash. the track we run in is really more for the sturdier nitro cars. the islands are around 3-4inches tall and the perimiter is a net with steel posts. probably hit one of the steel posts during the last run (had some glitching problems).
VooDooPH is offline
Old 07-18-2007, 10:12 PM
  #2989
Big B's Avatar
Originally Posted by VooDooPH
BigB,
That sucks, I too have had some glitching problems as well as having people on the same channes (eventhough I have the clip), hopefully all that will be solved since I bought the Futaba 3pks with the Fasst system
Big B is offline
Old 07-19-2007, 03:54 AM
  #2990
Trader Rating: 51 (100%+)
Thumbs up
If anyone is looking to pick up a like new US Spec T2'007 for a good price click below.
http://www.rctech.net/forum/showthread.php?t=170046
Apex is offline
Old 07-19-2007, 02:17 PM
  #2991
racer34v's Avatar
Trader Rating: 131 (100%+)
I have a ?
Iwas looking over my 007 and i was wondering if i could shave a bit off the end of the axles where they stick out past the wheel retainer nut.... cant see them hitting the boards as being a good thing...
racer34v is offline
Old 07-19-2007, 04:01 PM
  #2992
Korey Harbke's Avatar
Trader Rating: 13 (100%+)
You sure can! In fact... I think I saw Paul doing that this last weekend.
-Korey
Korey Harbke is offline
Old 07-19-2007, 04:26 PM
  #2993
fjm9898's Avatar
Trader Rating: 11 (100%+)
hahaha yea it was one hell of a spark show!
fjm9898 is offline
Old 07-19-2007, 05:08 PM
  #2994
racer34v's Avatar
sweet...! thanks
alan
racer34v is offline
Old 07-20-2007, 05:30 PM
  #2995
rmdhawaii's Avatar
I have some "Clueless Noob" questions:
T2 '007 US = foam on carpet
T2 '007 EU = rubber on asphalt
1. If I want to run foam on asphalt, would it be better to get the US or EU version?
2. Out of the box, was the original T2 designed to run on carpet or asphalt and with what type of tires?
Thanks!
rmdhawaii is offline
Old 07-20-2007, 05:37 PM
  #2996
t4m1y4niac's Avatar
Thanks!
IMO
1. just take te EU version..it has more flexibility than US ver since the lower deck on EU ver is 2.5mm.
2. the original T2 can run both carpet and asphalt, that's why Juraj hudy make a wonderful "Multi flex"...
t4m1y4niac is offline
Old 07-20-2007, 06:15 PM
  #2997
Big B's Avatar
Thanks!
The EU will give you more flex cause the chassis is 2.5mm, I would also suggest that you get the 2mm topdeck. Why do you want to run foam instead of rubber? I thought the origional T2 came in a EU and US version as well
Big B is offline
Old 07-20-2007, 08:13 PM
  #2998
C_O_jones's Avatar
OK, I'm DONE, fed up and can't take anymore of your crap BigB!
From what the people from your local track tell me, is that you cant complete a lap without stuffing it into the pipes.
You keep telling people what to do, but don't have a clue yourself.
You posted on your local thread that you cant get your car to turn but tell all here just what it takes.
Same crap on the 1/12th threads.
Re-read your post above, your telling a guy that wants to run foam on asphalt to go with a thin chassis and a thin top deck, you don't have a friggin clue!
Have you even run on foams, I know you have NEVER been to the local carpet tracks or Time Zone where they do run foams, oh and TZ is asphalt.
A majority of the people that post here and give out information, know what they are doing.
That's what makes these thread so good, it helps people,
so grow up, learn how to race, qualify for a main, and then give out advise.
Fred
C_O_jones is offline
Old 07-20-2007, 09:17 PM
  #2999
alecladanga's Avatar
hi guys
i need help again. had a major crash last outing and the front chassis on my t2 007 has about .5 mm tweak. i took out all of the parts and tried to see where the tweak was, found out that my front shock tower is bent slightly (figured this out because i placed it on a flat surface - glass - when i pressed on the right top of the shock tower, the opposite end will go up about .5 mm).
what should i do? place the shock tower on a flat surface add some weight on it and leave it overnight for it flatten out? replace it?
or any other suggestions?
alecladanga is offline
Old 07-20-2007, 09:25 PM
  #3000
Mr. Shookie's Avatar
Originally Posted by alecladanga
hi guys
Replace the tower. PERIOD...
Once there is any kind of tweak like that you won't ever get your setup perfect...
Tweak is the devil...LOL
-Shookie <><
Mr. Shookie is offline
