Xray T2'007
#2959
Just change over to the hard, std T2 susp arms, unless you have stupid high traction and then go with the US 007 Xtra hard arms.
#2960
While the chassis has the same mounting holes, you'll notice that the flex points are different. The "ears" on the front and rear of the chassis are in a different location when comparing the T2 to the 007.
#2961
I think Barry was using a T2 chassis, at least on thurs or fri.
Barry OWNED Mod the whole weekend, never seen him smile that much.
Oh, and it was really easy to know when he was running, nothing sounds like a brushed mod motor, when the BL guys were up, you couldn't tell the diff between them and stock, NO noise=No excitment.
#2962
#2964
No factory guys I have ever seen run aluminum shocks.
But I do see other aluminum goodies on their cars. Which means to me the regular plastic shocks work just fine, and there is no reasonable advantage to running aluminum shocks.
If you want to spend money on that kind of stuff, get the aluminum rear hubs (first choice) then aluminum steering knuckles (second choice)
But I am pretty sure, (if you are just going for bling bling) that Xray makes aluminum shocks as an option part.
#2965
Correct. They found out that the composite variant has a better heat beheaviour.
That's not correct. The ALU shocks are discontinued.
At this moment I use the ALU Serpent shocks and thay are awesome in maintenance, filling & bleeding and have a very constant rebound.
But the standard Xray shocks are fine
#2966
XRAY discontinued them, but you can still get the aluminium shock bodies from Serpent.
#2967
Hey guys, just a quick question on setup for the '007 - i run on a pretty tight track with low grip, very smooth but low grip especially at night (outdoors).
What setup do you guys recommend. I am running LRP Brushless 5.5 with a rollout of 10.2..
What I am finding is that the car tends to dive mid corner and hook resulting in it spinning mid corner. I would prefer it push slightly rather than oversteer. it pushes entering the corner but the mid corner hook is a bit of a killer. I am not running a sway bar either end, I am sure I should be doing this but dont have them yet.
Would you guys have a setup for similar conditions?
#2968
I just picked up a second hand T2 007 US Edition. Has anyone had success running it on rubber tires? If so, what did u do to make it work?
My local tracks are indoor carpet (on rubbers) and outdoor asphalt. I want to try and make this thing work without having to buy much else. Thx
#2969
Sticky, I answered you on xray's forum.
autoset, I recommend this one:
http://forum.teamxray.com/xform/inde...6&setup=t2_007
I don't have the same conditions as you, but it works awesome for me. I've done a few slight modifications to that setup, but start with that one.
#2970
Anyone know if any companies make an aftermarket 5 cell carpet (3.5mm) chassis for the T2'007?
