Xray T2'007
#2896
Has anyone tried the Futaba S9451, I need a new servo cause my brand new Ko won't center anymore (I know I can send it in, but I sent in my VFS-1 2 months ago and I still havent gotten it back, I am done with Ko products) I know the S9550 is a great servo, but I figure the S9451 is a little faster and has a little more torque, and it really dosent need to be low profile since the 007 mounts it horizontal on the chassis
-Korey
#2899
You mean the Solid OneWay? According to the Setup Book it is best used on med-high grip tracks, where braking for corners is not required, it will give good off power steering. I used this for a practice session, I really liked how it feels, but the corners at our track were a little too tight, and I lost too much speed, I think it would werk great on a large sweeping course
#2901
I doubt most really use 100% EPA....
Well at least with the 007 and a real nice setup, I found that I have too much steering so I use less steering input which increases corner speed. Also the Low profile servos weigh less so you can reduce your total car weight...and if your under weight you can add weight where you really would want it which is near the center of the car, not hanging out the side..
Just my Opinion.
-Shookie <><
#2902
i just painted a G6 body for my 007
#2904
-Korey
#2905
XRAY T2'007 do you have 2mm chassis ?
#2906
#2907
Where to go from here???
-Adam
#2908
After losing last week's race to terrible weather, I finally got to run the Speed6 tonight. It's bloody awesome! With Korey's setup, the car was simply dialed. I have no idea how to make it better. It transitions very well, even through the very sharp ones, has great onpower, offpower, and midcorner steering. It's very easy to drive, and very fast around the track.
-Adam
-Adam
MUHAHAHAHA
With that, I'm sure i'm going down now.
#2910
-Adam
-Adam
