Old 09-12-2006, 03:37 AM   #1
A Ilievski's Avatar
Trader Rating: 39 (100%+)
Default Rubber Tyres ???
Hi, so far ive only raced foam tyres and i got no idea about rubber tyres. I want to know the basics for rubber tyres, like which tyres for what track, surfaces, which for carpet etc etc.
Alex Ilievski
A Ilievski is offline   Reply With Quote
Old 09-12-2006, 03:42 AM   #2
luke humphrey's Avatar
Hi, for outdoors, depending on the track temp, i usually use CS's if its roasting hot i use 27's if its luke warm the usually 22's, i tried some rp's the other day both the 24's and the 30's, both good for different conditions work a treat.
Hope this helps!
luke humphrey is offline   Reply With Quote
Old 09-12-2006, 06:28 AM   #3
Martin Hofer's Avatar
Send a message via ICQ to Martin Hofer
As rubber tires are the only tires we run in germany we have a lot of experiences with the tires.
Speaking about aphalt racing, the tire holding it's performance the longest is the Sorex 36.
The CS27 is the best allround tire.
Indoor on carpet we mostly run CS 27 or Sorex 28s. sometimes Vtec 27s.
Martin Hofer is offline   Reply With Quote
Old 09-12-2006, 07:38 PM   #4
PeteB's Avatar
In Australia the most popular /standard tyre is Sorex, compound ratings go from 20 (very cold smooth concrete), 24 (smooth concrete) 28 (asphalt), 32(warm asphalt) 36 and 40 (hot asphalt). I'd start with some sorex 28s and if you are slipping around go to 24s, if they wear out too quickly go to 32s. I only use Sorex's, and love them...
You will also need to get some inserts, start off with sorex B medium.
make sure you glue it properly otherwise they will vibrate at high speed
GTB SS + 13.5 & 10.5
Trakpower 4900
PeteB is offline   Reply With Quote
Old 09-13-2006, 10:26 PM   #5
trainable's Avatar
Default Hi!
I've raced mainly in the Philippines and we've basically got warm (hot!)/humid weather there..and we raced outdoors on an asphalt raceway.
Same thing there-- Sorex still is the choice of tires. 32's for AM racing, 36's from Midmorning to early Afternoon. 30's-28's from late afternoon to early evenings. 24's for night races.
Inserts -- I mainly like soft to medium compounds. Soft one's will give you better traction but the rubber wears out faster. Mediums will be a middlepath -- less traction but less threadwear..
Rims -- Speedmind dish rims!
Traction compounds also help...
And like PeteB said -- make sure you CA/glue them on the rims well..
trainable is offline   Reply With Quote
Rubber Tyres Birky Rookie Zone 16 06-13-2013 04:01 PM
How to tell when rubber tyres are gone?? LOSI123 Electric On-Road 12 11-28-2007 06:23 PM
New to Rubber Tyres Rody Electric On-Road 7 08-21-2005 01:21 AM
Foam tyres or rubber tyres at IFMAR? habicht Electric On-Road 1 06-16-2005 10:02 AM
HPI rubber tyres new or used penggoy R/C Items: Wanted to Buy 1 05-02-2003 03:51 PM
SEO by vBSEO 3.5.0
