TrakPower 4900 Lithium Race Packs!!! >
Old 09-11-2006, 07:31 AM
Default TrakPower 4900 Lithium Race Packs!!!
TrakPower 4900 Lithium Polymer Race Pack
Factory Matched for every pack!!!
Features:
-4.7 mOhm 1/4 of the resistance of a Zapped NiCd
-4900 mAh 700mAh more capacity than the leading NiMH
-268g 40% less than most NiMH packs
-7.4V Nominal, 8.4V fully charged
-7V held under 100 Amp Load More Power
-10th-Scale Car Racing Fit
-Integral 4mm Gold-Plated connectors
The performance is nothing short of amazing! Imagine having your matched nimh packs power thru-out the entire race rather than only the first 2 mins!
More Power, Lighter weight, sturdier casing, lower price............
It's definitely well worth it's weight in GOLD!!!
In Stock NOW!!!!
Immediate Shipping!!!
For orders or enquiries, please contact me directly via [email protected]
IT'S TIME TO STOP COMPROMISING!!!
~~~~The World's Hightest Performance Lithium Comes to RC MotorSport. ~~~~
Welcome all dealer enquiries, Low requirements!!!
ammo is offline
Old 09-12-2006, 03:22 AM
Additonal details:
Dimensions: 137.0mm in length, 45.0mm in width and 22.7mm in thickness
Weight: 268g
Capacity: 4900mah
Nominal voltage: 7.4V
Typical IR at terminals: 4.7mOhm
Discharge Capabilities: 20C 100 Amp continuous, 30c 150 Amp max acceleration 50 nearly 250 Amp spikes
Standard charge rate: 5 Amps (1C)
Fast Charge rate: 10 Amps (Max 2.5C with balancing charger)
Max charge: 8.40V
Max discharge – never below 6.0V – 6.2V recommended / don’t limp home
Connectors (built in) 2 x 4mm bullet females, gold plated
Centre tap for balancing: 2mm bullet female, gold plated
Cycle life estimate:
-Raceworthy: 100 Cycles
-Practice/Mixed use 200 Cycles+ if ratings observed and followed.
Cycle life estimates are halved if fast charging always deployed: recommend a mix of standard and fast charging as the need/opportunity arises
Warnings: TrackPower Lithium Polymer has a far greater energy potential than older/ traditional battery technologies used in RC. Treat Lithium Polymer batter technology as FLAMABLE SOLID FUEL. ALWAYS use a LiPo charger set to 2-Cell / 7.4V LiPo for this 2s1p pack. NiCd/NiMH “delta peak” chargers are COMPLETELY UNACCEPTABLE for LiPo technology and WILL cause a fire. Failure to observe maximum and minimum ratings and the warnings stated here an on the reverse of each pack will achieve NO PERFORMANCE ADVANTAGE, will VOID WARRANTEE, and will lead to UNSAFE OPERATING CONDITIONS. Practices such as pre-race Peaking and Zapping are unnecessary and must be strictly prohibited for LiPo Tech owing to their immediate danger in the context of LiPo chemistry.
ammo is offline
Old 09-12-2006, 10:46 AM
There have been enquiries and one of the most common question is about it's high speed charging. TrakPower 4900 can be charged at up to 10amps on a lithium capable charger.
With true convenience, you can fully utilise your equipment instead of having to waste time and additonal money for high rate dischargers, individual cells dischargers, etc. All you do is after a run is to plug it on the charger to fill up the pack with electrons again. Compare it with nimh, whereby you have to wait for the sizzling hot pack to cool off and to discharge it properly before being able to charge up again.
For a competitive raceday, you will need 5-8 packs of nimh cells? not to mention a ton of supporting equipment to ensure the packs will still be able to deliver for the next charge? Consider TrakPower 4900, only 2-3 packs are required and i'm state that as a very big margin. now add on the convenience, add on the lighter weight, not having to worry about dumping? Just take the additional power as a bonus!!!!
Spend more time surfing thru the pit area making more friends, sharing more setup tips, enjoying yourself instead of having to worry about whether your nimh is done discharging.....
ammo is offline
Old 09-12-2006, 11:23 AM
R/C Tech Founder
These forums are not for commercial product announcements or advertising. Thanks.
futureal is offline
