Old 09-09-2006, 10:05 AM   #1
Unhappy How Do You FIX This ....TC4 RTR...
Hi.. im new to RC Cars.. and i have the TC4 RTR when i drive it doesnt go Straight(it dose but not to much) how u fix it..radio can do it but...when i turn it makes an odd sound/ in other words.. if i fix it from my radio it goes Straight(wheel does seem Straight) but it makes an odd sound every time i make a turn..if i fix the odd sound... from radio.. the car doesnt seem to go Straight
RCNooB is offline   Reply With Quote
Old 09-09-2006, 11:14 AM   #2
PitNamedGordie's Avatar
Send a message via AIM to PitNamedGordie Send a message via Yahoo to PitNamedGordie
can you give us a btter idea of what it sounds like...grinding? squealing?
☆ The Track @ Harbor Hobbies ☆ www.harbor-hobby.net ☆
PitNamedGordie is offline   Reply With Quote
Old 09-09-2006, 11:37 AM   #3
i think it came from the servo... its not the sound of the wheel when u turn...i think that i seted the servo too much to the right or left ....
Old 09-09-2006, 12:12 PM   #4
Trader Rating: 32 (100%+)
Send a message via AIM to A. Rhodes
Sound like you either have the end point adjustments set incorrectly, or the servo horn is not centered correctly. The noise you are hearing is the servo reaching maximum throw, but the wheel / tie rod is not letting it, thuss the grinding sound.
Try this:
Take off the servo horn & reset the servo (on controller) to the middle. Re-install the servo horn (check instructions - attach at slight angle on TC4). Once installed, re-check the wheel travel L & R, and adjust as necessary for maximum turning without binding. Also, if you controller has sub trim option, use that to center the servo by eye, and then the steering trim to fine tune.
If the above does not work, you may have stripped the gears in the servo, and it would need to be replaced. If you are not 100%, take it to your LHS and have them take a look at it. If you do need to replace the servo, upgrade to a metal gear servo, if it is your budget.
Hope this helps.
Retired from RC....
Quantum - St. Croix - Bass Pro Shops - XPS - Rapala
A. Rhodes is offline   Reply With Quote
SEO by vBSEO 3.5.0
