Old 09-06-2006, 07:10 PM   #1
Default Tamiya Gears
Hi all,
I've got a question about Tamiya pinion and spur gears.
Is Tamiya's "04 module" the same as "48 pitch"? The 04 module gears come standard in Tamiya kits (i think?) but I want to buy some 48 pitch pinions. Will they work? or will I have to buy either Tamiya 04 pitch pinions or 48 pitch spurs to go with the 48 pitch pinions?
if the latter is the case, would I be better off buying 64 pitch spurs and pinions?
also, what is a good aray of gears to start off with?
thommo09 is offline   Reply With Quote
Old 09-06-2006, 07:25 PM   #2
subaru73's Avatar
Trader Rating: 41 (100%+)
Default tamiya gears
you will be better off buying 64 pitch gears it will give you a better chance of getting the correct ratio.as far as gearing what type of motor and size of track do you race on?
Tamiya 419 Tamiya evo5 ms,Tamiya Ta05r Tamiya FF04 rm01 Tamiya Ff03R
Ko proppo K.I.Y radio lrp speed control
Cfx paint works Fantom Racing Ko Proppo apex Rc tq hobbies acer racing Hebki design works
subaru73 is offline   Reply With Quote
Gears for Tamiya TB IV infanterene Electric On-Road 4 06-30-2007 11:10 PM
1/10th Pan Car Setup - CORALLY C10X - Gears, Gears, Gears? paul73rc Oval, Larger Scales and More 4 04-06-2007 09:10 PM
Tamiya Gears thommo09 Rookie Zone 6 09-07-2006 04:10 PM
Tamiya Gears thommo09 Australian Racing 5 09-07-2006 01:30 AM
wtb: Tamiya 0.4 pinion gears 18t-26t Carbon_Ta04 Australia Wanted to Buy 0 06-10-2006 06:26 AM
SEO by vBSEO 3.5.0
