HOW TO REPAIR A FOAM TIRE
Hi i had heard about a way to repair a foam tire.. Someone i had talked to told me about some special glue, to fix chucked tires. It is not suose to affect the tires performace.. they said once it is glued, then re trued you can't tell the difference... I forgot the name of this glue.. I have a few brand new jaco tires, with one run on them and i would like to repair them..
any inof would be apreciated..
Mark Payne's site http://www.12thrc.com/ has a tutorial on how to do this. It shows a 1/12th tire, but the same applies to all foam tires... good luck.
contact cement i beleive is the glue your thinking of
