Old 01-31-2003, 02:55 PM   #1
Send a message via AIM to ZER01
Removing Anodization
Anyone know the steps in order to remove the anodization off of aluminum. About all I know is you need "easy-off" the oven cleaner but how long do you let it set, what do you use to take off the easy-off(water?). Any help would be greatly appreciated.
ZER01 is offline   Reply With Quote
Old 01-31-2003, 03:07 PM   #2
fasterdanu's Avatar
why would you want to do that if your looking to make somthing shiny just get a very corse polish for metals like brasso and that sort of thing then pull out your demmel (or if you don't have one a drill put on your buffer bit and spin away guy's like doing this on nitro's it's also prety good for breaking in bushings.
fasterdanu is offline   Reply With Quote
Old 01-31-2003, 03:14 PM   #3
seaball's Avatar
R/C Tech Charter Subscriber
Send a message via Yahoo to seaball
perhaps easy off, but i use a lye solution. it's a chemical to clean out drains. it's very aggressive. i mix a teaspoon or so into a 1/2 filled coffee mug and watch it fizz and get warm, then drop in my aluminum and stir as the solution turns the color of the anodizing. soon i have silver or greyish parts! they need rubbed or polished afterwards, but it sure beats sanding off the anodizing.
it's available at supermarkets. also, be careful not to breath in the fumes and don't let it sit on your skin too long. not too healthy.
that's one way.
*** The Gate II - Home of Mike Wise ***
seaball is offline   Reply With Quote
Old 01-31-2003, 11:22 PM   #4
TheBarber's Avatar
Send a message via AIM to TheBarber
i personally used Hot hydrochloric acid to remove my anodize. then polished the parts with my dremel. the acid only took 2 seconds to remove the anodize.........but if you cant find someone with access to the (i.e. machine houses that do plating), household oven cleaner works.
TheBarber is offline   Reply With Quote
Old 01-31-2003, 11:31 PM   #5
CGR's Avatar
The best way I have found is a bead blaster, but not everyone has one.
CGR is offline   Reply With Quote
Old 02-01-2003, 12:09 AM   #6
Use the stinky kind of Easy Off, not the no smell one. The time it takes depends. You need to keep an eye on the part. I'd look every couple minutes. Once the color is gone take it out and wash with water. The part will look dark. You need to polish it out. You might need to wet sand with 400 then 600 then 1000 grit sand paper and finally some aluminum polish like Mother's mag polish.
If you leave the part in too long it'll eat away the aluminum!
Do it in a well ventilated (outside) area!
Have fun.
Sydewynder is offline   Reply With Quote
Old 02-01-2003, 12:12 AM   #7
RCTech Member #2
TSR6's Avatar
Send a message via ICQ to TSR6
Agreed! I like the finish the glass bead leave on the AL. I did a tuned pipe a while back.
RCTech Member #2
The postings and views expressed on this site are my own and do not necessarily reflect the positions, strategies, or opinions of any company I may be employed by.
TSR6 is offline   Reply With Quote
Old 02-01-2003, 12:23 AM   #8
dynoman007's Avatar
Send a message via MSN to dynoman007 Send a message via Skype™ to dynoman007
Default alum
just remember that oven cleaner will change your tolerances a lil if it a part with a tight clearence i have done many parts all different ways and the tolerances always change a lil ....
i have had certain types of degreasers that would take off regular types of decorative anodsing just experiment with them the strongest were the ones i found in dollar stores ..go figure..
the best method of polishing afterwards is the bricks found at a few stores and added to a fast wheel on a larger style bench grinder.... i know that sears sells the bricks for polishing i have never found anything better .............mothers polish and a dremel is a lot of work i promise lol
dynoman007 is offline   Reply With Quote
Old 02-01-2003, 11:37 AM   #9
I anodized a piece of aluminum for a chemistry project. I removed the anodizing with a wire brush on a dremel. Didnt take long at all.
Heres something Ive been wondering about for a while, how would I remove anodizing from Threaded shocks? I dont think easy off would work, because you have to sand it. I suppose I would have to use HCl? What concentration?
RC Paperboy is offline   Reply With Quote
Removing anodization? edseb Electric On-Road 20 10-15-2004 10:33 PM
removing tire from rim lachlan90 Nitro On-Road 10 02-08-2004 02:28 PM
removing tire from rim lachlan90 Electric On-Road 8 01-20-2004 01:27 AM
Removing CA Calvin Ng Electric On-Road 1 08-03-2003 10:54 PM
Removing of E-Clip? F&K Singapore R/C Racers 6 01-29-2002 07:49 AM
SEO by vBSEO 3.5.0
