1/10 Tl01
1/10 Tl01
What can i actually tune up in this car apart for a new motors and new parts.????
if you have the LA set then you can change shock positions, camber, toe and all that junk. If not, you can rebuild your diff and put new grease in it. thats about all you can do without new parts.
upgrading
What do you think I sould buy for it ??? what is a good motor and any other gear i need to make it better.
There are a lot of hop up parts available for the TL-01 from Tamiya and the aftermarket. The long arm set will improve the car's handling and suspension tuning ability. You can also get speed-tuned gears, lightweight prop shaft and even a lightweight chassis. If you don't have ball bearings in the transmission and wheel hubs, get them.
I would limit the motor in the TL-01 to a stock motor.
Hey Devil,
Do a search in this site using tl01 as your search criteria. There is a lengthy tl01 thread already in progress. Also..check out www.tamiyausa.com....there is a great article about a hopped up tl01. You'll see it listed on the front page of the website. Plenty of us Tamiya junkies out there...don't be afraid to ask for advice. Good Luck
Thanx Man you are a LEGAND
just what i was lookin for you will now get a free pass to heaven
Free pass!!!
LOL seya
Free pass!!!
LOL seya
