Old 08-25-2006, 05:43 PM   #1
chrism86's Avatar
Default Anyone had/have a corally c4 need help!!
Ive got a corally c4. car runs great. However the back wheels have hardly anypower and all the power is at the front wheels. THe back diff seems fine and it does work, but it just doesnt have power when on the ground. Im assumming it needs adjusting? Can this be done without taking it all apart.
How would i do this?
Or is it a possibility the back diff is done for?
if anyone could help that would be great.
Ive tried searching for a manual but couldnt fine one : (
thanks to anyone who can help
chrism86 is offline   Reply With Quote
Old 08-26-2006, 02:52 AM   #2
corallyman's Avatar
Trader Rating: 97 (100%+)
Check to see if your rear diff screw has snapped. If it broke it might seem to work while you are holding your car, but when placed on the ground it would slip and hardly run.
Team ORCA / ORCA USA / Pro Spec
Serpent America / Team Serpent S411 ERYX / On Point Racing OP12C, S120 / Xceed Products
Hangar 30 / Seattle RC Racers
Fasttrax Racing Series / NORA On Road Series
corallyman is offline   Reply With Quote
Old 08-27-2006, 12:48 AM   #3
imr's Avatar
I had a c4 in the past.
The two pinions on the axle where the spur is mounted can be too loose.
You can tighten it and check now and then.
You can adjust the friction so it acts like a oneway on the belt.
I made a small hole in the left and the right pinion, where they come together, and then put a small (diff)ball in between so when you press the pinions together there is no more movement because the ball blocks the two pininons.
Hope you understand what I mean, my english is not good enough to explain more
imr is offline   Reply With Quote
Old 08-27-2006, 01:35 AM   #4
Posts: n/a
I think from memory the c4 had a center oneway on the shaft in the middle of the car it allowed adjustment to the center oneway. Check and make sure thatthe adjustment nut is tight and is all on the right way.
Corally RDX Stroker Ace R/C Items: For Sale/Trade 6 01-18-2008 08:43 PM
Corally RDX Andy__+ Australia For Sale/Trade 10 07-04-2006 02:28 AM
Corally RDX Brad_C R/C Items: For Sale/Trade 9 05-26-2006 06:42 AM
Corally RDX Bmainer#3 R/C Items: For Sale/Trade 12 05-24-2006 06:32 PM
corally c4.1 Ooj Australian Racing 3 04-26-2004 11:11 AM
SEO by vBSEO 3.5.0
