Old 02-03-2003, 02:27 PM   #46
Brian McGreevy's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Brian McGreevy Send a message via Yahoo to Brian McGreevy
Yes see, it's not a price issue . However people will say that you can chunk foams easy and that raises costs. Well as i said in a previous post, if you are someone that cannot get through a race without hitting stuff mulitiple times, foams are not for you unless you have a nice budget.
USVTA Member #211
Yokomo BD7 (Mod TC), Corally Phi '07 (VTA)
Support Formula SAE - get kids into engineering!
Brian McGreevy is offline   Reply With Quote
Old 02-03-2003, 03:42 PM   #47
ShadowAu's Avatar
OK... here is My opinion based on 7 years of racing foams and at least 3 years running rubber tires
1) switching to foams will not make a bad driver good and won't make a bad setup suddenly transform but they CAN make a bad setup appear even worse
2) foams on a well setup car WILL be faster on the majority of surfaces
3) from personal experience adjustments like shock angles don't seem to make as much difference to the handling whereas springs can make huge differences and unless you carry around 50 different tension springs it can be a nightmare to get it exactly right. Ride height constantly changes so it has to be continoulsy adjusted as well as camber, droop, cg, roll-center whereas rubber tires don't need to be adjusted anywhere near as often. Also gearing constantly changes as tires wear.
4) A good setup basic setup can allow a reasonable driver to switch between foams and rubber without a huge change in car performance or handling... My TC3 used to be about 3 tenths of a second faster per lap on foams compared to rubber on bitumen... My TA04R is almost the same speed.
5) Pro drivers here in australia will true the daylights out of a foam tire before running it, espically nitro cars. Its not uncommon at title events to see these people true brand new ellgi's etc down to 58 or 59mm... which makes them good for about 2 runs and at $50 australian a set that gets just as scarey as rubber
In My humble opinion, control tires at title and large events, wether they be rubber OR foam, has been the most intelligent thing organisers of rc racing in this world have come up with... I know a lot of people don't like it but maybe those people should look at full sized racing and actually take notice of the difference it makes to the racing, making it closer and more dependant on driver skill and setup.
ShadowAu is offline   Reply With Quote
Old 02-03-2003, 09:20 PM   #48
KINGZJ's Avatar
Send a message via AIM to KINGZJ
I really don't know what you mean with your coment but if you would like to enlighten me please send me a p.m.
KINGZJ is offline   Reply With Quote
FOAM TO RUBBER 32819toon Electric On-Road 7 07-22-2008 07:49 PM
rubber and foam tiger266 Nitro On-Road 7 08-11-2005 03:52 PM
foam vs rubber Toma2525 R/C Items: For Sale/Trade 1 04-28-2005 11:02 PM
Foam or Rubber? pokpok Indonesia Racing 12 04-08-2004 10:41 PM
Foam Vs Rubber fastolfart Australian Racing 66 07-09-2003 03:04 PM
SEO by vBSEO 3.5.0
