What is the best tamiya mini chassis M-03, M-03L or M-03M
Like the title says what is the best out of the 3.
The tighter the course the the shorter the chassis. The longer chassis are more control able. My advice, buy the M03L and the parts from the M03M that include the spacer, rear hub and front knuckles and then you will be able to run all three chassis and have the two degrees rear toe in (M03M rear hub). Make sure you get bearings and oil shocks.
