Old 12-02-2013, 06:27 PM   #13306
DesertRat's Avatar
Ebay can occasionally provide a non-abused specimen. The small spur gears are getting hard to find, which if you want you can blame on me as I hoarded them when they went on clearance.
I race toy cars for fun. If I need to explain, you'll never understand.
If everything is under control... go faster.
WTB: Carpet racing in Arizona.
It is obvious and intuitive to the most casual of observers that RC racing is better than golf.
DesertRat is offline   Reply With Quote
Old 12-04-2013, 06:37 PM   #13307
morris's Avatar
Trader Rating: 40 (100%+)
So I was digging thru a old bag of parts that I found.
And never guess what I found....
N.i.p. Flying fox layshaft.
Score..just purchased a type r from a friend for really cheap.gonna freshen it up a little and use it in vta...
Still looking for a place that has parts.
AE/VIPER/XPERT/DIRTCHEAPRC.COM/JCONCEPTS
A big thx to all the tracks that I race at:cause if it wasnt for these guys..we wouldnt have a place to race our r/c cars!!!
morris is offline   Reply With Quote
Old 12-04-2013, 09:55 PM   #13308
DesertRat's Avatar
Lucky
You can get a good bearing set for like 18 bucks from Boca. Be sure to lock the front diff, just taking the balls out and replacing the thrust bearing with a stack of washers works great, but you probably knew that.
Old 12-05-2013, 06:05 AM   #13309
liljohn1064's Avatar
Trader Rating: 16 (100%+)
Send a message via AIM to liljohn1064 Send a message via MSN to liljohn1064 Send a message via Yahoo to liljohn1064
I have 2 with both the FF layshaft and front spool. This car needs to make a comeback. I have enough parts to run them for years. Stocked up on everything but the front plastic drive cups.
John Higgins
liljohn1064 is offline   Reply With Quote
Old 12-05-2013, 06:58 AM   #13310
Tech Legend
Cain's Avatar
Trader Rating: 210 (100%+)
Few changes and i could be on point with the newer stuff. the concept of running the battery pack down the middle to me at least looks ideal. All the weight centered.
Few minor annoyances with the vehicle from the time it was made but they could do it for sure.
As for parts, ebay would be my suggestion. Some places sell a variety of NIB parts dirt cheap there.
< Team Associated RC10B6D x 2>
< Tekno SCT410.3 x 2>
< Durango DEX410V5>
Old 12-12-2013, 08:27 PM   #13311
i had 3 of them i sold on here about 2 yrs ago...with more parts than a hobby shop could carry......wished i would of have just kept them.
I can confirm this statement. I purchased this collection from you. I love these cars, but sorry that you have regrets. I run usgt and tc competitively with them and the type r's are still winning (often) at our track here in ohio.
Augie28 is offline   Reply With Quote
Old 12-24-2013, 12:34 PM   #13312
RC Bombshells's Avatar
Trader Rating: 130 (100%+)
Default Finally one available
Just posted my spare up for grabs. Worth it considering the battery mounted on board and some spares. Hope it finds a good home.
Losi JRX-S R Roller
R/C BOMBSHELLS Custom Paint by Rocco
www.rcbombshells.com
www.facebook.com/rc.bombshells
RC Bombshells is offline   Reply With Quote
Old 12-24-2013, 01:05 PM   #13313
nrtv20's Avatar
I wish I had one just because I love TLR
http://www.trautengineering.com/ http://www.toledooneeighthracers.com/
http://www.youtube.com/user/nrtv20
One Eigth Racers of Toledo; Hobby Stop West Track; "The Gate" NORCAR
FUTABA 2.4G FASST, Spec-R S1, Speed Passion SP-1, Sakura D3 FWD, Kyosho Evolva M3, Team Losi XX-4, Caster EX1.5R, HPI Wheelie King Crawler, Quanum Aquaholic, Joysway Wildcat
nrtv20 is offline   Reply With Quote
Old 01-19-2014, 09:26 PM   #13314
Trader Rating: 57 (100%+)
Does anyone still use this car for 17.5 rubber tire sedan. I use one for vta but was thinking of using it for the sedan class. Any pointers or setups I could start with thanks
Radical Motors
gotnitroonline.com
In Memory of Shaun Neary
lucky 13 raceway
robertsmalibu is offline   Reply With Quote
Old 01-20-2014, 11:59 AM   #13315
DesertRat's Avatar
One setup suggestion I found necessary is getting the most rear toe-in you can. My car ran the 2-degree arm mount and the 1-degree hub for three total, which solved a lot of problems with the car being loose.
Other than that, the diff will be crucial, my car was always diff-sensitive and performed best when the diff was as free as possible.
Old 07-11-2014, 04:16 PM   #13316
Hi does anyone have a front oneway or rear FF spool that they are will to part with or know where if anywhere that I could purchase these parts?
PLMK
Thank You!
Arsenal2012 is offline   Reply With Quote
Old 07-12-2014, 12:34 AM   #13317
DesertRat's Avatar
PLMK
Thank You!
I would not recommend a front one-way as I think it would ruin the cars handling and almost nobody runs a one-way in rubber tire TC anymore, but I have seen several for sale on Ebay, for like $55!
As far as the Flying Fox layshaft goes, unless one pops up as used or New Old Stock they are all gone. It's not the end of the world, there is still adapters available from PRS: http://www.precisionracingsystems.co...S-Adapter.html which let you run normal spur gears, and that is really all you can do with the FF layshaft anyway as a LiPo over about 4500mah is too thick to fit under the rear bulkhead, it just spaced the pullies out a hair wider to fit a lipo between them back when LiPos were 3700mah full size packs. The best way I have run my car is with a LiPo plate and the ESC mounted on the plate behind the battery. Full size LiPos are really not possible...
For an occasional discussion of old touring car racing or a picture of my car as described above, see this thread:
Old TC Cars - Still Racing Competitively
Old 07-12-2014, 06:59 AM   #13318
MikeXray's Avatar
Trader Rating: 72 (100%+)
Actually we had a killer one way setup on the type-r on carpet rubber tire, I'm sure its out there somewhere, it was a mike haynes setup from 360 RC. The one ways wouldn't last though, which was a problem, they would blow out one of the bearings, and you would need a new unit..
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 07-14-2014, 01:07 PM   #13319
DesertRat's Avatar
I think I found the setup in question:
http://www.rctech.net/forum/4007343-post6122.html
It actually looks pretty cool, front swaybar with no rear and the heavy front spring, I could see it working on medium-high bite. I always thought a one-way would make the back end come around pretty hard.
Old 09-22-2014, 04:44 AM   #13320
rsr14's Avatar
Hi guys,
It seems like the c-hubs are in short supply and out of production. What are you guys doing for replacements? I read that the TC3 c's work with some slight modification. I this the best solution or is there another current part that would work? If the tc3 part works I was considering an aluminum part to increase durability. Any info would be greatly helpful.
autometricsmotorsports.com
rsr14 is offline   Reply With Quote
[FS] Team Losi JRXS-Type R squarehead R/C Items: For Sale/Trade 9 07-21-2012 12:59 AM
Team Losi JRXS Type R gtxpro2 R/C Items: For Sale/Trade 18 09-11-2008 08:45 PM
WTB: Team Losi JRXS Type R shifter R/C Items: Wanted to Buy 1 07-03-2008 03:30 PM
Team Losi JRXS TYPE-R John Q R/C Items: Wanted to Buy 1 10-03-2007 06:55 PM
Team Losi JRXS Type R New In Box Canyon R/C Items: For Sale/Trade 0 06-20-2007 04:50 PM
SEO by vBSEO 3.5.0
