Old 12-03-2012, 03:46 PM   #13216
Tech Legend
Cain's Avatar
Trader Rating: 219 (100%+)
Thanks. I may give that a look then and just balance it out with my scales.
Right now I got a Speed Passion GT2.0 Pro ESC on its side on the spur gear side. With that I had to do a variety of zip ties to get the wires to clear properly
Got pics of your setup?
Also, how much ESC overhang on the chassis do you guys find acceptable?
< Team Associated RC10B6D x 2>
< Tekno SCT410.3 x 2>
< HB Racing D413 x 2>
Old 12-06-2012, 05:48 PM   #13217
Hi Guys,
I found a bunch of NIP 4* and 6* caster/steering blocks in my garage this evening. 4x4* and 3x6* $20 shipped if anyone wants them. Have several type-r size bearings I'll throw in as well. Shoot me a pm if interested.
Spektrum - Dynamite - Horizon Hobbies - MaxPower - RCAmerica - Alpha Raceway
skipstr is offline   Reply With Quote
Old 12-08-2012, 08:48 PM   #13218
Originally Posted by skipstr View Post
Hi Guys,
Parts are gone guys, thanks to all that responded.
Old 12-16-2012, 08:31 AM   #13219
Tech Legend
Cain's Avatar
did some 17.5 blinky running this past weekend with sweeps blue tires. Will post more actual setup info, but have a general question.
The vehicle was good, was one of the few without traction rolling issues but noticed that depending on how sharp the turn was, I could get slight lift on the inside rear wheel. It was only on a very fast 180ish turn.
In general, what do you find you do to eliminate that?
All in all, the vehicle was great. I just need to up my power a bit but forgot how much fun 1/10 touring was. And usually being an AE fan, I enjoyed the losi JRX-S Type R. wish losi would make a run with this again.
Old 12-16-2012, 01:50 PM   #13220
morris's Avatar
Trader Rating: 40 (100%+)
could be a few things.
but what comes to mind...how much droop are you running?
AE/VIPER/XPERT/DIRTCHEAPRC.COM/JCONCEPTS
A big thx to all the tracks that I race at:cause if it wasnt for these guys..we wouldnt have a place to race our r/c cars!!!
morris is offline   Reply With Quote
Old 12-16-2012, 03:32 PM   #13221
Tech Legend
Cain's Avatar
went to no droop in the rear and I believe 5mm up front. Did the no droop in the rear based on a VTA setup sheet I saw. I think that did help a lot.
Old 12-16-2012, 03:38 PM   #13222
Lessen's Avatar
Send a message via MSN to Lessen
I would think if you're lifting the inner rear that you are overloading the outer front on entry. Does the car have a ton of steering in general?
"Nothing in the world can take the place of persistence. Talent will not; nothing is more common than unsuccessful men with talent. "
Lessen is offline   Reply With Quote
Old 12-16-2012, 04:02 PM   #13223
Tech Legend
Cain's Avatar
yup, loads of steering. would going to a stiffer front spring help?
Old 12-16-2012, 07:06 PM   #13224
Lessen's Avatar
Possibly.
I might try to settle the RR down before a FR suspension change. If your RR shocks are not already mounted at the innermost position(at the tower) I'd try that alone real quick to see if that keeps the rear from rolling more than necessary. Basically, I think you want to head toward the direction of keeping more weight on the inner rear from entry thru to corner center. If that makes the steering a bit more stable & predictable but still not enough, then I'd try stiffer FR springs.
Old 12-16-2012, 07:35 PM   #13225
Tech Legend
Cain's Avatar
thanks for the info. Will give that a look.
By the way, I noticed when checking out my vehicle that its drivetrain has gotten really tight, won't free roll like it was before. Anything I should look into as possible areas where it could be binding?
Old 12-16-2012, 07:42 PM   #13226
morris's Avatar
try running 2mm over ride height front and back.
run ur rear camber link at the furthest hole and the longest link.this will help keep the rear of the car planted.
what pistons you running and what spring combination?
Old 12-16-2012, 07:45 PM   #13227
Tech Legend
Cain's Avatar
Got the camber link on the rear longest setting as well as lowest setting on the tower. Definitely generated more grip.
I am running the red pistons front and rear (thats what the car came with) 10.5 springs on the rear, 15's up front.
Shocks on the rear as inner most hole on the tower, outer hole on the a-arm.
Front shocks are outer hole on the tower.
didn't have time to change oils but I believe they are 40W up front, 35W rear.
Got the 57 pistons (black) on order as I believe the setup I wanted to use had these up front.
Old 12-17-2012, 04:23 AM   #13228
Lessen's Avatar
That all sounds exactly like my general setup. I'd try 17.5 front springs for sure.
Are you running sway bars? Depending on track conditions, my car worked the best overall with an .030 up front with the links mounted so about 5-6mm of the bar extends past the link.
Old 12-17-2012, 08:35 AM   #13229
Tech Legend
Cain's Avatar
not running any sways as the setup didn't have any listed will see what I got in the parts bin.
Do you know offhand what the screw sizes that work in the fan mounts?
Old 12-17-2012, 09:39 AM   #13230
DesertRat's Avatar
Long-ish 2-56 screws fit in the fan mounts, the type-R was made back when Losi still did standard size screws.
I race toy cars for fun. If I need to explain, you'll never understand.
Current rides: Diggity DC4 Chassis #10. Losi JRX-S Type R. CRC Xi, Xti, and Altered Ego Aluminum Chassis. Associated B4 based dirt oval late model, and B4 Buggy.
WTB: Carpet racing in Arizona.
DesertRat is offline   Reply With Quote
[FS] Team Losi JRXS-Type R squarehead R/C Items: For Sale/Trade 9 07-21-2012 12:59 AM
Team Losi JRXS Type R gtxpro2 R/C Items: For Sale/Trade 18 09-11-2008 08:45 PM
WTB: Team Losi JRXS Type R shifter R/C Items: Wanted to Buy 1 07-03-2008 03:30 PM
Team Losi JRXS TYPE-R John Q R/C Items: Wanted to Buy 1 10-03-2007 06:55 PM
Team Losi JRXS Type R New In Box Canyon R/C Items: For Sale/Trade 0 06-20-2007 04:50 PM
