Old 02-12-2012, 08:40 PM   #13066
DesertRat's Avatar
Originally Posted by MasterPlan View Post
Thanks for the information and honesty. I to use a GTB speedo and a novak FM reciever. My other losi will use the new electronics. So I may go with the 4000mah short pack with micro spectrum and tekin RS Pro. I will see if I can get it all on the tray.
If you stand the GTB up on its edge you can pull it off... come to think of it, I could do that with my Havoc if I had a shorty LiPo.
I race toy cars for fun. If I need to explain, you'll never understand.
Current rides: Diggity DC4 Chassis #10. Losi JRX-S Type R. CRC Xi, Xti, and Altered Ego Aluminum Chassis. Associated B4 based dirt oval late model, and B4 Buggy.
WTB: Carpet racing in Arizona.
DesertRat is offline   Reply With Quote
Old 02-16-2012, 02:05 AM   #13067
matt*strike's Avatar
Trader Rating: 41 (100%+)
Any of you guys looking to pick up an extra type r let me know I'm thinking of letting mine go and I got tons of spares
Team Redline O.G.
Alpha Raceway ---Carbondale, IL
matt*strike is offline   Reply With Quote
Old 02-16-2012, 03:59 AM   #13068
jayh50's Avatar
Default type r
I may know of someone at our local track that was looking for one. How much and what do you want to sell with it?
CUSTOM WORKS GBX2, GBX3, LOSI 22 Buggy, 22 SCT, LOSI 8IGHT E BUGGY.
GO FAST, TURN RIGHT, LEFT, RIGHT, LEFT, OHH CRAP!!!!!!!!!!!!
TURN IT OVER, TURN LEFT, RIGHT, LEFT, RIGHT, LOL
jayh50 is offline   Reply With Quote
Old 03-10-2012, 10:40 AM   #13069
Ray Kindstrom's Avatar
Trader Rating: 146 (100%+)
He's mine. I used a Kinetic with a shorty on the steel tray. I had to shave some of the metal off of the steel tray in order for the shorty to fit flat. I also cut 2 slots on the tray so that I can tape the pack down. It will be easier to remove the upper deck to exchange lipos than to remove the tray. I will add more pics when I complete the electronics install. I plan on running 17.5/13.5 this summer to get ready for the 2012 Paved On-Road Nats.
I'm in need of a starting asphalt setup and I'm looking for an Exotec upper deck. If you have either please post info or PM me.
Ray Kindstrom is offline   Reply With Quote
Old 03-10-2012, 01:12 PM   #13070
dfiantii's Avatar
Trader Rating: 16 (100%+)
Send a message via AIM to dfiantii Send a message via Yahoo to dfiantii
Here is my question for that layout you have there Ray. Are you going to be running boosted 17.5/13.5 or blinky and if your running boosted how do you fit a fan on the esc. I have a type r to and i don't see that much space in there for the esc you have. Granted I am running a speed passion esc.
TT-01/Hitec MG/SP LPF V1.1/Trinity 7.5
Losi Type-R/JR Z8800S/SP Cirtix Stock/Novak 25.5
Exotek F1R/Savox 1251/Tekin RS/21.5
"ELECTRIFIED TO THE HILT"
dfiantii is offline   Reply With Quote
Old 03-10-2012, 02:14 PM   #13071
Lessen's Avatar
Send a message via MSN to Lessen
I have a two of these cars and cannot comprehend why you would want to remove the battery from the top. You're removing at least eight screws rather than the four that hold in the tray from below. I just unhooked and removed my battery and it took a grand total of 25.9 seconds (and that includes the tenths that it took me to tap the stopwatch). I can pretty much guarantee you can't do it that quickly from the top and eliminate any chance that you may affect your corner loads and tweak upon reinstallation. That's just my two cents though.
"Nothing in the world can take the place of persistence. Talent will not; nothing is more common than unsuccessful men with talent. "
Lessen is offline   Reply With Quote
Old 03-10-2012, 06:31 PM   #13072
All the classes I will be running will be "blinky". If I need a fan I will install on on the side of tha chassis and point it at the esc. It's a tight fit....but it fits.
Good points. But I don't need to remove the battery in 29sec. I'm sure it will take hours between rounds. The speedo is mounted to the lipo tray. Not wanting to unsolder or unplug the speedo everytime I want to change the pack. It's easier to remove the upper deck. Everytime (and I mean everytime) I take my car to my pit I always loosen the upper deck. Loosening the upper deck help curb any tweak caused during a run. I remove tires and loosen the upper deck. When I tighten down the upper deck I always tighten it on a flat surface and usually have someone pressing down on both shock towers while I snug things up. This helps keep the lower deck flat....which keeps the car more consistent between runs. Hitting a board or tube will alter a cars setup or cause tweak. So my taking the upper deck off the car won't hurt a thing. Also all I need to do is remove the screws and swing the deck out of the way....no need to remove the steering linkage from the servo arm.
Old 03-11-2012, 08:49 AM   #13073
Lessen's Avatar
Yeah, I figured the steering linkages more than likely would be able to allow it enough movement to get the next pack in there. Everybody has their own pit program and I can see your points as well. I routinely check my ride heights at 4 points as well as wheel loads but I've generally only check chassis flatness during my beginning of day prep. Personally, I don't feel the need to loosen the top deck if not necessary but I can certainly see the benefit of regularly checking the main chassis. As a matter of fact I recently shimmed my bulkeads ever so slightly because it was tweaked just a bit and was making it difficult to get balanced properly.
Old 03-11-2012, 08:55 AM   #13074
Greg Sharpe's Avatar
Trader Rating: 15 (100%+)
What part of your pit program uses that hammer to the left of your car?
FS: Awesomatix A800A $325 shipped
Greg Sharpe is offline   Reply With Quote
Old 03-11-2012, 09:07 AM   #13075
hanulec's Avatar
Trader Rating: 23 (100%+)
id recommend you look for a setup from Mike Haynes from 2010 at Jackson RC. his type-r was really good that summer. he had the lightest springs i've ever seen on a car....
FJ / ROAR #2-122945 / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 03-11-2012, 07:08 PM   #13076
jayh50's Avatar
Default type r
Thats not a hammer, that is a "Fine adjusting tool", used in the most delicate adjustments. Like when you just cant get the setup just right, and you have worked on it for weeks, THATS WHEN YOU PICK UP THE FREAKING HAMMER AND JUST........... oops, I mean fine adjusting tool and do some minor tweaking. Whew, almost lost it for a moment. LOL
Old 03-11-2012, 07:30 PM   #13077
vabroom's Avatar
In my experience, never have a hammer within reach while working on your car big scale or small scale. Saves you alot of grief.
RC racing is still trying to prove that two solid objects can be in the same place, at the same time.
vabroom is offline   Reply With Quote
Old 03-12-2012, 04:40 AM   #13078
I did say it was a tight fit! The hammer is used for fine adjustments.
Finished the electronics install at the track yesterday. Our outdoor season doesn't really start until the end of April, but I was able to get it on the outdoor track for a few laps. Everything worked fine. Now I need to work on the setup and gearing.
Old 03-12-2012, 10:56 AM   #13079
DesertRat's Avatar
You haven't seen precision hammering unless you watched people re-seat the old brushed stock motor bushings
Old 03-12-2012, 11:14 AM   #13080
jhwnissan's Avatar
Anyone interested in an old Dave Johnson car? I used it for a few 17.5 races, but ultimately it was way too fast for my talent level. It would be a roller with extra belts and components. Should I just throw this up on ebay? I really like to see it go to a good home. It fits lipos well and has a spur gear adaptor on it. Thoughts? BTW.. thanks to all on here that were helpful in helping set this car up.
Josh Howard on RCNEWB.COM
Drawing rc car body madness in a Bunker....
Rare Losi R/C Belt Maker Extraordinaire
Need belts or parts? I can help.
SWs, RWs, XX-4s, XXX-S
jhwnissan is offline   Reply With Quote
[FS] Team Losi JRXS-Type R squarehead R/C Items: For Sale/Trade 9 07-20-2012 11:59 PM
Team Losi JRXS Type R gtxpro2 R/C Items: For Sale/Trade 18 09-11-2008 07:45 PM
WTB: Team Losi JRXS Type R shifter R/C Items: Wanted to Buy 1 07-03-2008 02:30 PM
Team Losi JRXS TYPE-R John Q R/C Items: Wanted to Buy 1 10-03-2007 05:55 PM
Team Losi JRXS Type R New In Box Canyon R/C Items: For Sale/Trade 0 06-20-2007 03:50 PM
