Old 01-21-2012, 08:45 PM   #13006
Looking at getting a JRXS-R to run in VTA. Is there anybody out there running VTA with this car? If so what roll out are you running? A basic chassis setup would be great. I am going to be running on low to med traction carpet. Also what fan is everybody running on this car?
Thanks for the help.
Chris
ChrisR40 is offline   Reply With Quote
Old 01-21-2012, 08:57 PM   #13007
Trader Rating: 50 (100%+)
Send a message via MSN to Jaz406
Chris
Mike Haynes had a great VTA setup for the type R
Jaz406 is offline   Reply With Quote
Old 01-26-2012, 11:48 AM   #13008
dfiantii's Avatar
Trader Rating: 16 (100%+)
Send a message via AIM to dfiantii Send a message via Yahoo to dfiantii
i guess skyrocket has given up looks like the website is down or gone. Guess i won't get that layshaft.
TT-01/Hitec MG/SP LPF V1.1/Trinity 7.5
Losi Type-R/JR Z8800S/SP GT 2.0
Exotek F1R/Savox 1251/Tekin RS
TLR 22 2.0
"ELECTRIFIED TO THE HILT"
dfiantii is offline   Reply With Quote
Old 01-26-2012, 02:33 PM   #13009
Lessen's Avatar
Send a message via MSN to Lessen
Chris
I'm run this car in VTA. I race at a track that is 90x40 and I'm running 3.80 final drive ratio. We generally have pretty good grip so I don't know how much help my setup would be for you. I'm also fairly new to this racing thing so anything I say really can be taken with a grain of salt. My setup evolved from one of the setups in the back of the manual so I basically started from scratch last spring.
FRONT / REAR
Toe: 0 /3
Ride Height: 5.0/5.2
Camber: 2/1
Kick/dive/squat: 0/.070 pro squat
Caster: 6
Droop: 3.5/4
Pivot: 0/2
Roll Center: Low/High
Arm Spacing: Mid/Forward
Shock Position: 1/3 & outer
Rack: Aft
Ackerman: Outer
Camber Link: 1/5 & outer
Sway bar: -/030
Drivetrain: diff .5 out/diff 1 out
Diff height: High/High
Hex: stk/stk
Shocks: 17.5 & 40wt/30 & 30wt
Spur: 106
Pinion: 51
I run the steel bottom tray, a Cirtix ESC with 28g opposite the speed control to balance & only sauce the inner half of front tires. This is how my car ended the day last weekend but it's still a work in progress as is my driving. Mostly it changes due to my driving learning curve so it may be complete rubbish for you
"Nothing in the world can take the place of persistence. Talent will not; nothing is more common than unsuccessful men with talent. "
Lessen is offline   Reply With Quote
Old 01-26-2012, 06:37 PM   #13010
Thanks Lessen
What lipo's are you running in the losi?
Looking for something for under $50.00
Old 01-26-2012, 06:48 PM   #13011
Lessen's Avatar
Just a Losi sport pack LOSB9861 I believe is the part number. It's nothing special. Besides, the battery is no game changer in VTA. It's actually kind of overpriced IMO but it gets the job done. I'm not lacking in the HP department in this class (nobody is really) I just need to keep working on my driving and setup. Let me know how that works for you if you try it out. I'm going to the track Saturday and plan to try a few things out.
Old 01-26-2012, 07:16 PM   #13012
markiemark's Avatar
Trader Rating: 23 (100%+)
The owner of sky rockets name is ymebp on here or check out the racing forum and look for the blue diamond 2012 thread he is in there.
~ ~Blue Diamond Park Raceway~~
~~~~D Main Champ~~~~
markiemark is offline   Reply With Quote
Old 01-28-2012, 08:21 PM   #13013
matt*strike's Avatar
Trader Rating: 41 (100%+)
Crc and promatch also make shorty batteries like the losi I'm sure there is more
Also I was told buy a few veteren drivers that I could shave the case on a larger lipo to help with the clearance issues
Team Redline O.G.
Alpha Raceway ---Carbondale, IL
matt*strike is offline   Reply With Quote
Old 01-28-2012, 11:01 PM   #13014
Lessen's Avatar
I've been considering picking up a pair of shorty packs for my TC ride. You can fit a pack that is 25mm thick if you slide it just forward enough to clear the rear bulkhead. I personally fit a Power Push shorty pack today at the track. Install it so the leads are rearward and you don't have to mod the upper deck to plug in.
Old 01-29-2012, 07:54 AM   #13015
Lessen's Avatar
Chris
I made some fairly significant changes to that setup throughout the day yesterday and I'm starting to get closer to challenging the front runners locally. My car dips and dives A LOT more than the fellas I'm chasing but on paper it's nearly just as fast.
Old 01-29-2012, 01:11 PM   #13016
dfiantii's Avatar
Can you post a pic of that pack in your Type R and out of it?
TLR 22 2.0
Old 01-29-2012, 02:22 PM   #13017
Lessen's Avatar
I havn't bought it yet or I would. I might pick up a pair in two weeks for the next local club race.
Old 01-29-2012, 02:24 PM   #13018
I use a losi shorty and it works great
I place the battery all the way forward in the metal tray and then dremeled the top plate just a hair for the connectors
I heard exoteck had a lipo top tray
Team Redline O.G.
Old 01-29-2012, 03:26 PM   #13019
Lessen's Avatar
Yeah, it wouldn't take much dremel work to get it that way. Maybe a mm at most I'm guessing?
Yes, Exotek makes a top chassis plate but it does not mount to the 4 aluminum braces. That's one way to save a little weight although the chassis probably "works" more on track.
Old 01-29-2012, 04:33 PM   #13020
Probably pass on that then I'm really liking the way it drives now
Team Redline O.G.
[FS] Team Losi JRXS-Type R squarehead R/C Items: For Sale/Trade 9 07-20-2012 11:59 PM
Team Losi JRXS Type R gtxpro2 R/C Items: For Sale/Trade 18 09-11-2008 07:45 PM
WTB: Team Losi JRXS Type R shifter R/C Items: Wanted to Buy 1 07-03-2008 02:30 PM
Team Losi JRXS TYPE-R John Q R/C Items: Wanted to Buy 1 10-03-2007 05:55 PM
Team Losi JRXS Type R New In Box Canyon R/C Items: For Sale/Trade 0 06-20-2007 03:50 PM
