Old 09-23-2011, 09:53 AM   #12976
J Lee's Avatar
Hello
I will try to compete in TC class at a new carpet track opening in New Rochelle, NY
here is my last setup sheet when I raced my Type-R last time on carpet.
lets try to bring this machine back to the podium!
File Type: pdf 2010 03 07 RCM Losi sedan set up_2.pdf (414.5 KB, 144 views)
J Lee is offline   Reply With Quote
Old 09-23-2011, 10:44 AM   #12977
DesertRat's Avatar
I managed to make my car go around the track very well on foam, but for some reason it doesn't much like rubber tire. Feels like driving on ice.
I race toy cars for fun. If I need to explain, you'll never understand.
Current rides: Diggity DC4 Chassis #10. Losi JRX-S Type R. CRC Xi, Xti, and Altered Ego Aluminum Chassis. Associated B4 based dirt oval late model, and B4 Buggy.
WTB: Carpet racing in Arizona.
DesertRat is offline   Reply With Quote
Old 09-25-2011, 05:34 PM   #12978
Default JRXS-R drives erratically
Well I got my JR back on the road today but when I give it too much throttle it spins in circles. If I go easy on the throttle it does fine. I just put a brand new set of HPI Vintage tires on it but it still wants to go drifting. I have a Castle Sidewinder Sport 4600KV 36T pinion with stock spur gear. I would like it to go straight so what do I need to check ? Differentials maybe ? Thanks
steve1 is offline   Reply With Quote
Old 09-25-2011, 10:13 PM   #12979
MaxRain's Avatar
yes, start with your differentials.
Gordon "slow is fast"
Stock Car - Xray T3, Modified Car - Xray T4 '14; Xray X1; Tamiya M-06
My Youtube Channel: search "CARCAR videos" or follow this link https://www.youtube.com/channel/UC7fp4qynjJzlXw13ocDpVAg
Facebook: CARCAR
MaxRain is offline   Reply With Quote
Old 09-26-2011, 09:03 AM   #12980
What do I look for ???
Old 09-27-2011, 10:28 AM   #12981
Wes Lawrence's Avatar
Hey guys!
I'm primarily an offroad racer but I have a nice used Type R I'm setting up for this weekend on carpet. Track is medium sized with medium traction. Any tips on setup, gearing (17.5 no timing with jaco blues), or what parts i should buy for spare? I'm gonna try to get the Xcelorin 3800 in the car by dremeling the steel tray today. Thanks for any help !
Alpha R/C Raceway
Wes Lawrence is offline   Reply With Quote
Old 09-27-2011, 10:45 AM   #12982
DesertRat's Avatar
Originally Posted by Wes Lawrence View Post
Hey guys!
You need a front spool, which for a JRXS your local hobby shop is as likely to have as a Faberge Egg or the Ark of the Covenant, so take apart the front diff, pull the balls out of the front pulley, blast it out with degreaser, find a piece of robust cardboard (I used a business card) and cut it out so it fits in the front pulley landing. Clean and roughen the rings, and then reassemble and tighten it down until it slips just a little bit when you torque it with your hands, you want it to slip before it breaks anything.
Check it after your first run, and if its still good this should calm the car down a lot, it fixed my cars tendency to have the back come around at high-speed turn-in.
Old 09-27-2011, 10:47 AM   #12983
MikeXray's Avatar
Trader Rating: 72 (100%+)
Hey guys!
Well first some questions, what's in the car?? do you have a spool up front or a diff? the spools were slipper spools and can easily be stripped, so you might only have 3 wheel drive. If it's a diff, chances are you're overpowering it as well, and need to get the spool setup.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 09-27-2011, 11:05 AM   #12984
It's diff front and rear. Is the spool discontinued? Or just hard to find?
Is there a way to get a gear diff in? What is the advantage of the spool?
THanks guys!
Alpha R/C Raceway
Old 09-27-2011, 12:01 PM   #12985
MikeXray's Avatar
THanks guys!
No gear diffs due to the wide diff layout they used on the car. The spool is just a different pulley, the part # in the back of the manual. Spool locks the front wheels together for better acceleration. Also replace the hub that the diff screws into, they strip.
Old 09-27-2011, 01:29 PM   #12986
jrp
jrp's Avatar
Trader Rating: 18 (100%+)
THanks guys!
Front One-Way, Rear Ball Diff.
stiff rear springs
LTC-R body
Buy as many front C hubs and steering blocks as you can afford, 4deg I think.
Car works better with the steel tray for battery even though it will be quite over the weight limit. CG is very high otherwise.
Spektrum - CRC - Horizon Hobbies - RC America - XRay - Prolevel RC - Max Power - SRC
- RC Gears for Android - Find it in the Android Market
jrp is offline   Reply With Quote
Old 09-29-2011, 06:27 PM   #12987
valk's Avatar
Send a message via ICQ to valk Send a message via AIM to valk Send a message via MSN to valk
I wonder how this compares to a TC5 in stock class. i like my tc5 but i wouldn't mind picking up another car to play with that's a little bit different.
the layout of this one looks pretty ideal.
valk is offline   Reply With Quote
Old 09-30-2011, 04:20 AM   #12988
Default Loose exiting corners
well after reading I can't wait to get home and see if I have the pulleys set for overdrive and to try to lock my front diff and see if it cures my problems my car is on rails except for corner exit if I get on it too fast it will loop out, I have been running oval and this car is amazing..love it
On another note I bought and additional jrx-s for parts but after receiving this car I can't tear it apart it looks brand new under the dust if anyone needs a really nice car I may sell this one the gloss is not even scuffed on chassis yet lol
AND OUR WORST PROBLEM BATTERIES HEREIS WHAT I AM RUNNING WITH ONLY MINOR TRIMMING OF BATTERY LID AND LIGHT PULLEY SANDING
VENOM 5000 2s 50c battery fit great after removing to raised areas on front of lipo tray really woke the car up amd it's heavy I can post part number if anyone needs it I found a online shop who has a great price on them moorehobbies.com
Thunderpower 5300 65c pro race fits good battery leads a little tight against my upper deck but I may try some other options with routing
calvord is offline   Reply With Quote
Old 09-30-2011, 07:13 AM   #12989
liljohn1064's Avatar
Trader Rating: 16 (100%+)
Send a message via AIM to liljohn1064 Send a message via MSN to liljohn1064 Send a message via Yahoo to liljohn1064
PARMA bumper. First thing you should make sure you have. It will save your hubs and arms up front. I've gotten to be good enough to keep the car off the wall most of the time, but still like to turn in early once in a while. This bumper has saved my front end more times than I care to count.
John Higgins
liljohn1064 is offline   Reply With Quote
Old 10-01-2011, 08:33 PM   #12990
Default Venom batt. #
[B]Calvord[/B ] What's the # on that Venom battery ?
[FS] Team Losi JRXS-Type R squarehead R/C Items: For Sale/Trade 9 07-21-2012 12:59 AM
Team Losi JRXS Type R gtxpro2 R/C Items: For Sale/Trade 18 09-11-2008 08:45 PM
WTB: Team Losi JRXS Type R shifter R/C Items: Wanted to Buy 1 07-03-2008 03:30 PM
Team Losi JRXS TYPE-R John Q R/C Items: Wanted to Buy 1 10-03-2007 06:55 PM
Team Losi JRXS Type R New In Box Canyon R/C Items: For Sale/Trade 0 06-20-2007 04:50 PM
