Old 09-08-2011, 08:54 PM   #12961
Default steel battery tray
Hi I was wondering if anyone has purchased the steel Lipo batt tray from Losi? It's supposed to allow the use of more common Lipo batt. I wonder if it's thicker and maybe has longer screws. I would love to be able to install a better batt selection. Thanks
steve1 is offline   Reply With Quote
Old 09-08-2011, 09:11 PM   #12962
In my experience it would be very hard (impossible) to not be grossly overweight using the metal lipo tray. When weight limits were higher for Touring the metal tray worked well to get the car up to weight. With the newer lower weight limits you'd pretty much have to use the plastic lipo tray. Now if you're talking VTA, with very high weight limits, the metal tray would be just the ticket!
Cheers,
Mike
Mike
Hyper_Mike is offline   Reply With Quote
Old 09-09-2011, 09:03 AM   #12963
squarehead's Avatar
R/C Tech Charter Subscriber
Trader Rating: 75 (100%+)
Send a message via AIM to squarehead Send a message via MSN to squarehead Send a message via Yahoo to squarehead Send a message via Skype™ to squarehead
The dimensions are virtually identical to the plastic lipo tray, it's just heavier to put weight in the car as low as possible. Has nothing to do with lipo battery fit issues in the JRXS-R (the issues are all between the top pulley spacing in the rear).
It's an absolute MUST in a VTA car. Would be tremendously difficult to neatly get to the weight minimum without it. My car took 125-odd grams of weight to get to 1550g for VTA. 1420g minimum in rubber tire classes, so without really trying (and with the steel lipo tray, stainless screws, VTA tires & wheels, Protoform VTA body), my car started out at 1425g. It would definitely NOT be impossible to get it underweight with the 2010 rules.
dc
Everything depends.
Nothing is always.
Everything is sometimes.
squarehead is offline   Reply With Quote
Old 09-09-2011, 12:31 PM   #12964
liljohn1064's Avatar
Trader Rating: 16 (100%+)
Originally Posted by DesertRat View Post
It is cheaper to rehash cars you already have instead of buying new ones, new doesn't necessarily mean faster.
Agreed, newer is not faster. I'm a huge advocate of running other peoples "used up" equipment. I have 3 perfectly fast and durable TC3s for VTA. I was just trying to say that if someone wanted/needed a new chassis, this one would be a great platform. Losi never even attempted to tweak the design during its production run. I'm still a little aggravated about Losi's choice to discontinue this car, but because the motivation is sales based and not results based production stopped. I'm sure they had their reasons.
John Higgins former student of The Ian Ruggles Negative Reinforcement Driving School. The "Team Principal".
liljohn1064 is offline   Reply With Quote
Old 09-09-2011, 12:51 PM   #12965
DesertRat's Avatar
I agree, after all Losi is in the business of making money and staying in business. I wonder if and when they are going to make another touring car, might not as Associated, Xray, Tamiya, and the rest seem to have the market curbed.
I race toy cars for fun. If I need to explain, you'll never understand.
Current rides: Diggity DC4 Chassis #10. Losi JRX-S Type R. CRC Xi (retired), CRC Altered Ego Aluminum Chassis. Associated B4 based dirt oval late model.
WTB: Carpet racing in Arizona.
DesertRat is offline   Reply With Quote
Old 09-09-2011, 02:08 PM   #12966
Thanks for the replies. I guess I'll stay with the stock plastic. So hard to find a Lipo that fits without it rubbing on the pulleys. Thanks again
Old 09-09-2011, 02:17 PM   #12967
Trader Rating: 17 (100%+)
Default gear adaptor
I think this may be the ticket for all those without flyingfox layshaft or u can modify the pulley(make the screw go deeper) and use shorter screw. http://www.precisionracingsystems.co...S-Adapter.html.
What do you guys think using a crc 4200 shorty lipo and move the esc behind the battery? like a pan car! think about running my new type r with shorty lipo and mini servo and give up my tcx.
cup racer is offline   Reply With Quote
Old 09-20-2011, 10:12 PM   #12968
d-bo's Avatar
Send a message via Yahoo to d-bo
Well guys i picked up a jrx-s type r for cheap and i love the way the thing looks and cant wait to get it out and race it.tho since its the end of the outdoor season ill have to run it indoor on carpet with rubber tires in the 17.5 blinky class. My question is whats a good starting set up for this car for carpet and rubber tires? the tires will be top solaris med and any info on the gearing would be great to thanks for your help.
d-bo is offline   Reply With Quote
Old 09-22-2011, 01:24 AM   #12969
Can anyone tell me what tray I can use so that I can run a Losi lipo - the standard plastic lipo one is too narrow, or do people dremel/hack it to fit?
Anyone tried a short pack? Or does that make the car too much underweight?
Team Losi XXX-CR | XXXT-CR | JRXS-R | JRXS | XX-CR | XXT | XXT-CR G+ | Mini-8ight | TLR22 | TLR 22T
J A M I N is offline   Reply With Quote
Old 09-22-2011, 07:58 AM   #12970
The battery tray is too narrow? The Losi lipo should be a direct fit. I've had problems with batteries taller than 23mm not clearing the rear bulkhead. What is the width of the battery you're talking about?
Old 09-22-2011, 08:06 AM   #12971
It seems the Losi 3800 Lipo is 46.9mm wide, the 6000 Lipo is 46.5mm.
The 3800 does not sit flush because of the raised edges of the tray, its not that far out, but enough to warp the tray if you force it in.
The 6000 is 25mm tall, so I guess that will foul elsewhere...?
Old 09-22-2011, 08:07 AM   #12972
The PRS spur adapter is a nice piece as are the layshafts. The layshaft helps accommodate larger batteries without rubbing. The spur adapter allow use of non-losi spurs only. Like you said, there is a tip for shaving the back of the pulley in the thread somewhere. I don't think you'd be able to mount the electronics unless you added some kind of shelf for them. If you race where the battery must come out and in a sack to charge, the tray needs to be able to be removed. I just ordered a Speedtech 3800 shorty for the same reason. I'm thinking more along the lines of adjustable weight distribution though.
Old 09-22-2011, 05:55 PM   #12973
drsmooth's Avatar
Trader Rating: 33 (100%+)
These are the batteries I use. Fit the tray with a little room to spare. I have four of these mounted to four of the plastic trays. Four screws out, four screws in. Battery change done. They also perform great too. My win to loss ratio for this summer is around 80%win to 20% losses. No to shabby!
http://www.hobbyking.com/hobbyking/s...arehouse_.html
Till next time.......
KEEP ON RACING!
drsmooth is offline   Reply With Quote
Old 09-22-2011, 06:20 PM   #12974
NICE, those packs are an excellent fit and for high turn motors, absolutely what the doctor ordered. Good find!
Old 09-23-2011, 12:53 AM   #12975
It seems that the Losi batteries are are little wider..quite ironic that Losi batteries dont fit the the Losi car...
[FS] Team Losi JRXS-Type R squarehead R/C Items: For Sale/Trade 9 07-20-2012 11:59 PM
Team Losi JRXS Type R gtxpro2 R/C Items: For Sale/Trade 18 09-11-2008 07:45 PM
WTB: Team Losi JRXS Type R shifter R/C Items: Wanted to Buy 1 07-03-2008 02:30 PM
Team Losi JRXS TYPE-R John Q R/C Items: Wanted to Buy 1 10-03-2007 05:55 PM
Team Losi JRXS Type R New In Box Canyon R/C Items: For Sale/Trade 0 06-20-2007 03:50 PM
