Old 04-07-2011, 07:59 PM   #12916
Trader Rating: 62 (100%+)
I ran these in my Type r with a little work they fit. I've had the same 2 packs since 12/2008 and they're still going strong http://www.amainhobbies.com/product_...5C-74V-5000mAh
The Wease is offline   Reply With Quote
Old 04-11-2011, 03:01 PM   #12917
DesertRat's Avatar
Default This post gives me hope
This thread makes me feel better about my JRXS-R, i thought I was the only one who needed to mount the speed control on the wrong side of the car from where Losi says to put it.
I race toy cars for fun. If I need to explain, you'll never understand.
Current rides: Diggity DC4 Chassis #10. Losi JRX-S Type R. CRC Xi, Xti, and Altered Ego Aluminum Chassis. Associated B4 based dirt oval late model, and B4 Buggy.
WTB: Carpet racing in Arizona.
DesertRat is offline   Reply With Quote
Old 04-23-2011, 08:20 PM   #12918
jayh50's Avatar
Default Final drive ratio
Just curious, In stock 17.5 tc, what pinion and spur are you running on a large semi technical track?
CUSTOM WORKS GBX2, GBX3, LOSI 22 Buggy, 22 SCT, LOSI 8IGHT E BUGGY.
GO FAST, TURN RIGHT, LEFT, RIGHT, LEFT, OHH CRAP!!!!!!!!!!!!
TURN IT OVER, TURN LEFT, RIGHT, LEFT, RIGHT, LOL
jayh50 is offline   Reply With Quote
Old 04-23-2011, 08:52 PM   #12919
Big Features's Avatar
Depents on what motor and how much timing you are running.
I'm running 3.91 FDR with an eXpress Motorsports D3 with 15 degrees of timing.
Mike
Mike Kling
Team Associated REEDY Powered
JConcepts TXD Skin Graphix
Big Features is offline   Reply With Quote
Old 04-23-2011, 09:55 PM   #12920
jayh50's Avatar
Default gear ratio
Mike
Right now I have a Tekin 17.5 no timing or boost
Old 04-24-2011, 07:24 AM   #12921
I would start with around a 3.90 FDR and check temps and performance.
45/96 is a good start
Mike Kling
Old 04-27-2011, 01:53 PM   #12922
PizzaDude's Avatar
Default 41t pulley
How often did/or do you guys run the 41t pulley to overdrive your car?
Any insights etc will be most appreciated.
Kind regards,
Pizza
PizzaDude is offline   Reply With Quote
Old 04-27-2011, 03:26 PM   #12923
Kind regards,
Pizza
I run it all of the time. It adds a ton of steering.
Mike Kling
Old 04-27-2011, 04:19 PM   #12924
drsmooth's Avatar
Trader Rating: 33 (100%+)
"I run it all of the time. It adds a ton of steering."
+1
Till next time.......
KEEP ON RACING!
drsmooth is offline   Reply With Quote
Old 04-27-2011, 05:51 PM   #12925
PizzaDude's Avatar
What does it do with rear end grip if it ads soooo much steering?
Sacrifices rear grip, or does it pull the rear with it....or something?
Old 04-27-2011, 06:57 PM   #12926
It digs the front and and the rear has no choice but to follow. It makes the front end more arressive without making the rear loose. Look at settle from Fairtrace, Shreffler, and Haynes. They use heavy sway bars and minimum rear toe.
Mike Kling
Old 04-27-2011, 09:07 PM   #12927
Airflow's Avatar
Default Hi...
I'm selling my brandnew unassembled JRXS type R kit for $180.
Excluding shipping cost... I live in the Philippines.
PM me for inquiries, thanks.
Airflow is offline   Reply With Quote
Old 04-28-2011, 01:19 AM   #12928
PizzaDude's Avatar
First off, thanks for the input you guys.
I get that.
If this only has advantages without disadvantages then, why isn't every tourer being setup/developed like this.
Come on, there has to be a downside as well...isn't there?
Old 04-28-2011, 02:55 AM   #12929
BrodieMan's Avatar
I use overdrive as well. On the small tracks I race on it's great, you can really power through the corners. I also use overdrive on my XXX4. Not sure why it isn't more common in TC because it does have it's advantages.
Mark Richardson
Kawartha Radio Controlled Racers
Lakefield Hobby & Game. ExtremeRCforum
Schumacher Mi4cx CRC Gen-X 10 LE
BrodieMan is offline   Reply With Quote
Old 04-28-2011, 02:59 AM   #12930
PizzaDude's Avatar
Can you think of the effect on a large track?
[FS] Team Losi JRXS-Type R squarehead R/C Items: For Sale/Trade 9 07-21-2012 12:59 AM
Team Losi JRXS Type R gtxpro2 R/C Items: For Sale/Trade 18 09-11-2008 08:45 PM
WTB: Team Losi JRXS Type R shifter R/C Items: Wanted to Buy 1 07-03-2008 03:30 PM
Team Losi JRXS TYPE-R John Q R/C Items: Wanted to Buy 1 10-03-2007 06:55 PM
Team Losi JRXS Type R New In Box Canyon R/C Items: For Sale/Trade 0 06-20-2007 04:50 PM
