Old 03-20-2011, 08:30 AM   #12886
Originally Posted by BrodieMan View Post
What would be a good starting point for my FDR for a a tight carpet track, med-high bite, rubbers with a 10.5 Ballistic. Today I was running a 126T spur & 30T pinion, at work so I don't have the exact FDR, and it wasn't as quick as the 17.5 boosted cars. Maybe it's because I'm don't have boost and my LiPo's are only 20 & 25 C ??
BrodieMan, Novaks tech info on their website recomends to start your FDR at 5.5. Going to a 34t pinion will get you in that ballpark. I would also try going to a smaller spur. PRS has adapters so you can run more than the stock Losi spurs. Hope this helps.
flyintrtle is offline   Reply With Quote
Old 03-20-2011, 11:09 AM   #12887
BrodieMan's Avatar
Sweet, that helps heaps. I was at 7.6ish so 5.5 will definitely get me up to pace.
Mark Richardson
Kawartha Radio Controlled Racers
Lakefield Hobby & Game. ExtremeRCforum
Schumacher Mi4cx CRC Gen-X 10 LE
BrodieMan is offline   Reply With Quote
Old 03-20-2011, 04:49 PM   #12888
Ooops! Sorry BrodieMan, just redid my math & if your set on keeping the 126 spur then you would need a 41t pinion to get you in the ballpark. Fat finger syndrome on the calculator. For 17.5 class I'm geared a hair under 4 FDR & I have no problems with motor temps & the car runs fast.
Old 03-22-2011, 09:09 PM   #12889
BrodieMan's Avatar
I accidentally ordered 0 degree C-Hubs and two sets to boot. Will there be a big difference in steering going from 4 - 0 degrees? From what I understand turn in will improve, which I had plenty of anyways, mid and exit cornering will be reduced and straight line stability will decrease. Where should I start for changes to counter the difference? Front shock angle and dampening? The easy solution of course would be to order more 4 degree C-Hubs but I am really trying to cut back on RC expenses that are not absolutely necessary. Just when I had my setup really dialled too. Thanks guys.
Mark Richardson
Old 03-23-2011, 02:09 AM   #12890
Big Features's Avatar
You could always run shims under the front suspension brace. That will add "kick up" and caster to the wheel.
Mike Kling
Team Associated • REEDY Powered
JConcepts • TXD Skin Graphix
Big Features is offline   Reply With Quote
Old 03-24-2011, 04:04 AM   #12891
crabboy's Avatar
Trader Rating: 57 (98%+)
LOTS of parts and CAR sale.
Will post internationally, buyer to pay the shipping.
Rhys
http://www.rctech.net/forum/australi...lus-parts.html
Rhys Marshall.
crabboy is offline   Reply With Quote
Old 03-25-2011, 08:39 PM   #12892
Anyone still got a car for sale??
Mike Kling
Old 03-25-2011, 08:51 PM   #12893
squarehead's Avatar
R/C Tech Charter Subscriber
Trader Rating: 75 (100%+)
Send a message via AIM to squarehead Send a message via MSN to squarehead Send a message via Yahoo to squarehead Send a message via Skype™ to squarehead
Thumbs up
PM sent...
Everything depends.
Nothing is always.
Everything is sometimes.
squarehead is offline   Reply With Quote
Old 03-26-2011, 05:57 AM   #12894
KKKWAN's Avatar
here is mine
KKKWAN is offline   Reply With Quote
Old 03-26-2011, 06:50 AM   #12895
transplantlife's Avatar
Trader Rating: 43 (98%+)
anyone know where i can find one of these new in the box?
IM A SURVIOR OF A DOUBLE ORGAN TRANSPLANT KIDNEY/PANCREAS...PLEASE BE A ORGAN DONOR TO GIVE LIFE TO OTHERS!!
transplantlife is offline   Reply With Quote
Old 03-26-2011, 12:36 PM   #12896
BrodieMan's Avatar
Leading Edge Hobby shop in Kingston, Ontario still has three NIB JRX-S Type R's I believe they are $224
Mark Richardson
Old 04-03-2011, 01:00 PM   #12897
squarehead's Avatar
Thumbs up
My VTA car ran absolutely flawlessly all weekend at the USVTA Nationals, and was great just about out of the box early in the event. It really is an ideal spec or VTA chassis—easy to set-up, easy to work on, very well balanced and relatively inexpensive, to boot.
I made a 4-spring change and removed my swaybars, and the car was really perfect—I wish the driver was as good as the car was. The only real updates on the car from box stock are a front spool, standard front camber link instead of a JR link, steel LiPo tray and a hard Parma front bumper. The rear chassis supports were removed, as well.
I'm attaching a setup sheet as my car was raced yesterday. It's a setup that I will take to any track anywhere as a baseline. A great place to start for VTA guys on carpet, for those who have been looking for a good baseline.
Everything depends.
Nothing is always.
Old 04-03-2011, 10:16 PM   #12898
BrodieMan's Avatar
I'm not a big fan of VTA bodies but that one looks AWESOME. Nice job
Mark Richardson
Old 04-05-2011, 08:32 AM   #12899
squarehead's Avatar
Thanks, it turned out really nice. Looked great on the track, too.
Out of curiosity, can anyone contribute to a list of ROAR-approved hard case LiPo packs that fit in this car without any modification? So far, the only luck I have had is with the original Orion Platinum 4800 20C. Anything else out there less than 47mm wide?
Hacking and Dremmeling of the car should not be a prerequisite to being able to use contemporary LiPo packs in the JRXS Type R.
Everything depends.
Nothing is always.
Old 04-05-2011, 08:54 AM   #12900
jhwnissan's Avatar
Squarehead... I use lipos from a company called Fantom racing here in Michigan. The prices are great and my only complaint is I need to use shorter screws to keep it from getting nicked by those on the top deck. It's a 5400 25C battery that I use in our local 17.5 non boosted touring class. Here's a link and I believe you CAN order directly from them if you find you like them.
http://www.fantomracing.com/products...atteries+Packs
Here's what I use... http://www.fantomracing.com/proddeta...AN26210&cat=11
Hope that helps.
Josh Howard on RCNEWB.COM
Drawing rc car body madness in a Bunker....
Rare Losi R/C Belt Maker Extraordinaire
Need belts or parts? I can help.
SWs, RWs, XX-4s, XXX-S
jhwnissan is offline   Reply With Quote
[FS] Team Losi JRXS-Type R squarehead R/C Items: For Sale/Trade 9 07-20-2012 11:59 PM
Team Losi JRXS Type R gtxpro2 R/C Items: For Sale/Trade 18 09-11-2008 07:45 PM
WTB: Team Losi JRXS Type R shifter R/C Items: Wanted to Buy 1 07-03-2008 02:30 PM
Team Losi JRXS TYPE-R John Q R/C Items: Wanted to Buy 1 10-03-2007 05:55 PM
Team Losi JRXS Type R New In Box Canyon R/C Items: For Sale/Trade 0 06-20-2007 03:50 PM
