Old 01-24-2011, 09:36 PM   #12751
James khoo's Avatar
Trader Rating: 15 (100%+)
Send a message via Skype™ to James khoo
Originally Posted by Dragonfire View Post
If that is total suspension travel then yes it seems to be a fair bit too much. I normally run 1-2mm droop at the front and 2-3mm droop at the rear (over ride height). You seem to be running 4-5mm front and rear.
Will give it a try.Thanks
James khoo is offline   Reply With Quote
Old 01-25-2011, 12:46 AM   #12752
dfiantii's Avatar
Trader Rating: 16 (100%+)
Send a message via AIM to dfiantii Send a message via Yahoo to dfiantii
Originally Posted by James khoo View Post
Sorry the pic is just show the upper deck modification.
I was running spool.
I am scratching my head at the lack of a front belt. Yes I would say your droop is way to much and if your driving without the front belt put it back on. lol
TT-01/Hitec MG/SP LPF V1.1/Trinity 7.5
Losi Type-R/JR Z8800S/SP GT 2.0
Exotek F1R/Savox 1251/Tekin RS
TLR 22 2.0
"ELECTRIFIED TO THE HILT"
dfiantii is offline   Reply With Quote
Old 01-25-2011, 04:07 AM   #12753
James khoo's Avatar
Ha ha ha,can't imaging driving without front belt.
Old 01-25-2011, 04:14 AM   #12754
He did say he runs it with a spool (4wd) but had the belt off for photo.
Blade: Andro Treiber H 79g AN
FH: Donic Bluefire M3 Max Blk
BH: Donic Bluefire M2 Max Red
Powered by Falco
Dragonfire is offline   Reply With Quote
Old 01-25-2011, 09:01 AM   #12755
Trader Rating: 14 (100%+)
James, are you "driving" it into and out of the corners??? With a front spool, you have to really be on the throttle especially during sweepers. I would try to drop that rear sway bar, or go to something smaller. Check that diff also.
DuckStang is offline   Reply With Quote
Old 01-25-2011, 03:04 PM   #12756
I used to have a similar problem with car being sideways on exit. Definately check the rear diff, that was my problem.
flyintrtle is offline   Reply With Quote
Old 01-25-2011, 05:15 PM   #12757
James khoo's Avatar
My diff is tight and smooth,it just that car seen to get back from roll slower and look like 3 wheel,the front 1 wheel is of ground.
Example:turning at left hand,the left front tire looked lift up or unload.
Old 01-25-2011, 05:43 PM   #12758
play with droop. I run sakura zero springs now.
cheapskate.brok is offline   Reply With Quote
Old 01-29-2011, 11:05 AM   #12759
How good are these spools and plates???
http://www.amainhobbies.com/product_...ey-Plate-JRX-S
I tried tightening the front diff until I screwed up the thrust bearing. Does this plate require a thrust bearing???
Old 01-30-2011, 03:33 AM   #12760
They work. Never had a problem with the thrust bearing though.
Old 01-30-2011, 04:42 AM   #12761
do not remove the two diff plates on the outdrives. The diff screw should come to a halt when tightened.
Old 01-30-2011, 09:48 AM   #12762
Default caster
ok, i can't find a picture of the caster blocks for my jrxs type-r. Can someone show me a pic ? is it the same but labelled "spindle carrier" in the manual ? and how do you adj it from 4 to 6degrees? people always telling me to ditch this and get an xray !!! argggg!!
dmakrc is offline   Reply With Quote
Old 01-30-2011, 11:25 AM   #12763
dfiantii's Avatar
You can't manually make the adjustment from 4 to 6 degrees. You have to buy a 6 degree one listed below or a 4 degree also listed below.
https://www.ssl-stormerhobbies.com/c...ns&pn=LOSA9763
http://www.stormerhobbies.com/cgi-bi...pl?pn=LOSA9762
You can go the route of xray if you like but you will pay for it...
TLR 22 2.0
Old 01-30-2011, 08:36 PM   #12764
Default awesome
that's what i thought. y would they not call it caster blocks ? instead of calling then spindles/carriers ?
Old 01-31-2011, 03:37 PM   #12765
squarehead's Avatar
R/C Tech Charter Subscriber
Trader Rating: 75 (100%+)
Send a message via AIM to squarehead Send a message via MSN to squarehead Send a message via Yahoo to squarehead Send a message via Skype™ to squarehead
If anyone is looking for spares or a cheap VTA roller or two, I have 2 backup JRXS-Rs for sale here.
Also anyone have a Flying Fox spool that they would like to part with (V1 or V2)?
Everything depends.
Nothing is always.
Everything is sometimes.
squarehead is offline   Reply With Quote
[FS] Team Losi JRXS-Type R squarehead R/C Items: For Sale/Trade 9 07-20-2012 11:59 PM
Team Losi JRXS Type R gtxpro2 R/C Items: For Sale/Trade 18 09-11-2008 07:45 PM
WTB: Team Losi JRXS Type R shifter R/C Items: Wanted to Buy 1 07-03-2008 02:30 PM
Team Losi JRXS TYPE-R John Q R/C Items: Wanted to Buy 1 10-03-2007 05:55 PM
Team Losi JRXS Type R New In Box Canyon R/C Items: For Sale/Trade 0 06-20-2007 03:50 PM
