Old 01-17-2011, 09:08 PM   #12736
Originally Posted by Airflow View Post
Hi, first time building my new JRXS R.
How come the shocks were not smooth? It's really tight the first time
I installed it in the shock body. How do you smoothen out the action?
Thanks.
Originally Posted by hacker View Post
I had the same problem with one of my 2 kits.
the piston is too big, I would take take a bit off with some emery paper.
Originally Posted by James khoo View Post
Yes,me.
But sand it down a bit,not too much,just do test by fitting into shock body to check.
As above sand them down a bit and you will be fine. I suggest you grab one shock with all the guides assembled in the lower half, add just a touch of oil to one shock shaft, then use it to test out each piston making sure it moves up and down freely. You only have to do this once and it will be sweet from then on.
Blade: Andro Treiber H 79g AN
FH: Donic Bluefire M3 Max Blk
BH: Donic Bluefire M2 Max Red
Powered by Falco
Dragonfire is offline   Reply With Quote
Old 01-20-2011, 01:53 AM   #12737
Got a new item to play with today from Mr FlyingFoxRC.. Should see an end to many problems associated with the poor materials of the kit outdrives....
Powered by Falco
Old 01-20-2011, 02:52 AM   #12738
hacker's Avatar
Trader Rating: 140 (100%+)
whats wrong with the kit outdrives?
at least with the losi spool its got some 'give' in it.
hacker is offline   Reply With Quote
Old 01-20-2011, 04:01 AM   #12739
Depending on your qaulity of driving they.can strip. It was probably never a problem with the original diff.design, which leaves alot to be desired too...
Powered by Falco
Old 01-21-2011, 02:44 PM   #12740
WIITA's Avatar
Trader Rating: 41 (100%+)
Hey there guys, I'm sure this has been asked on here before but I just picked up a jrxs-r from a guy at the club and would like to know what lipo battery with bullet connectors would fit the best in this car? I have the lipo tray already. the bigger the mah the better, Thanks kindly!!!
Team CRC / Sanwa / Team scream / Genesis RC / Hobbywing / TQ Wire / Schelle / MIP / RC^2 / TEKNO / BoomRC
WIITA is offline   Reply With Quote
Old 01-21-2011, 03:08 PM   #12741
dfiantii's Avatar
Trader Rating: 16 (100%+)
Send a message via AIM to dfiantii Send a message via Yahoo to dfiantii
Thumbs down
Congrats on the new parts but I am STILL waiting on my layshaft. Been on back order since November...
TT-01/Hitec MG/SP LPF V1.1/Trinity 7.5
Losi Type-R/JR Z8800S/SP GT 2.0
Exotek F1R/Savox 1251/Tekin RS
TLR 22 2.0
"ELECTRIFIED TO THE HILT"
dfiantii is offline   Reply With Quote
Old 01-21-2011, 08:23 PM   #12742
Dude I have you beat! I had a spool on order for over a year before I said to heck with it & got a layshaft instead!!
flyintrtle is offline   Reply With Quote
Old 01-23-2011, 11:50 PM   #12743
dfiantii's Avatar
Who did you order from?
TLR 22 2.0
Old 01-24-2011, 06:05 AM   #12744
Super Moderator
Marcos.J's Avatar
Trader Rating: 174 (100%+)
i think i have one of these Flyingfox spools laying around if anyone one wants it
Old 01-24-2011, 07:16 AM   #12745
Krazykeith's Avatar
Trader Rating: 15 (100%+)
Send a message via AIM to Krazykeith
pm sent
Krazykeith is offline   Reply With Quote
Old 01-24-2011, 07:15 PM   #12746
James khoo's Avatar
Send a message via Skype™ to James khoo
Guys please help me out.
My setting;
Front,
40wt oil
17.5lb spring
low roll
diff high
droop 10mm
0.004 swaybar.
shock position 2
Rear,
35wt oil
15lb spring
low roll
diff low
droop 10mm
0.004 swaybar
Shock position 3/outter
I'm using rubber tire on asphalt.Tekin RS pro ESC and redline 10.5t
The car has steering during enter corner,but at apex it understeer and exit tail loose.
Modification has been done on the upper deck for more flex.
James khoo is offline   Reply With Quote
Old 01-24-2011, 08:07 PM   #12747
My setting;
Front,
40wt oil
17.5lb spring
low roll
diff high
droop 10mm
0.004 swaybar.
shock position 2
Rear,
35wt oil
15lb spring
low roll
diff low
droop 10mm
0.004 swaybar
You made it rwd? I don't see the belt for the front end.
rc10t3b4 is offline   Reply With Quote
Old 01-24-2011, 08:19 PM   #12748
James khoo's Avatar
Sorry the pic is just show the upper deck modification.
I was running spool.
Old 01-24-2011, 08:25 PM   #12749
James khoo's Avatar
Can it be that my droop setting are too high?10mm?or i need to lower it to 8mm?
Old 01-24-2011, 08:57 PM   #12750
If that is total suspension travel then yes it seems to be a fair bit too much. I normally run 1-2mm droop at the front and 2-3mm droop at the rear (over ride height). You seem to be running 4-5mm front and rear.
Powered by Falco
[FS] Team Losi JRXS-Type R squarehead R/C Items: For Sale/Trade 9 07-20-2012 11:59 PM
Team Losi JRXS Type R gtxpro2 R/C Items: For Sale/Trade 18 09-11-2008 07:45 PM
WTB: Team Losi JRXS Type R shifter R/C Items: Wanted to Buy 1 07-03-2008 02:30 PM
Team Losi JRXS TYPE-R John Q R/C Items: Wanted to Buy 1 10-03-2007 05:55 PM
Team Losi JRXS Type R New In Box Canyon R/C Items: For Sale/Trade 0 06-20-2007 03:50 PM
