Old 12-15-2010, 09:37 PM   #12691
BrodieMan's Avatar
the steel LiPo tray does have a lip, can take a pic when I get home but I am pretty sure it's a little bit roomier than the plastic one.
Mark Richardson
Kawartha Radio Controlled Racers
Lakefield Hobby & Game. ExtremeRCforum
Schumacher Mi4cx CRC Gen-X 10 LE
BrodieMan is offline   Reply With Quote
Old 12-16-2010, 07:03 AM   #12692
jhwnissan's Avatar
Originally Posted by thefnshow View Post
quick q...i'm just getting around to put in a ballistic 17.5 motor and the solder tabs hit the bulkhead...is there some motor spacer that you guys are using to get this motor to not hit ? thanks
I just added a ton of washers to bring the motor out enough. That way I didnt have to mod the motor incase I had to send it back. It's my first brushless car and I run a 17.5 SpeedPassion
Josh Howard on RCNEWB.COM
Drawing rc car body madness in a Bunker....
Rare Losi R/C Belt Maker Extraordinaire
Need belts or parts? I can help.
SWs, RWs, XX-4s, XXX-S
jhwnissan is offline   Reply With Quote
Old 12-16-2010, 11:30 AM   #12693
BrodieMan's Avatar
Here you go.
Steel tray is the top one.
Mark Richardson
Old 12-16-2010, 11:40 AM   #12694
liljohn1064's Avatar
Trader Rating: 17 (100%+)
The plastic tray is wider by .5 mm or so. I can get packs in the plastic tray that don't fit in the metal tray.
John Higgins former student of The Ian Ruggles Negative Reinforcement Driving School. The "Team Principal".
liljohn1064 is offline   Reply With Quote
Old 12-16-2010, 03:47 PM   #12695
Default JRXS type R for sale
Here's a great deal
Losi JRXS type R
woodys3b is offline   Reply With Quote
Old 12-17-2010, 08:56 AM   #12696
Default lipo
awesome ! thanks for the pics ... if the plastic tray is wider then i'll stick w/that one...my batt is like .025 mm wider than what fits...i guess i'll have to dremel it flat !!!
dmakrc is offline   Reply With Quote
Old 12-17-2010, 08:58 AM   #12697
Default speed passion
hey jhwnissan, i run the 17.5t speed passion as well w/the FF layshaft and no issues, didnt need to use any washers...my pinion fits fine.
Old 12-20-2010, 04:35 AM   #12698
TCR
Default JRXS parts
Is anyone is Southern California running this car or in need of any parts.
I have a few things I would like to get rid of, I have no need for the parts.
I have spool, diff gears, suspension mounts, and a few other random things.
TCR is offline   Reply With Quote
Old 12-20-2010, 07:49 PM   #12699
Juanqui's Avatar
Is there a way to make the front camber adjustment like standard turnbuckles? I'm tired of releasing the ball cup and give it a spin to the desired camber angle. Has anyone made this mod on their cars that could help me!
Thanks!
Juanqui is offline   Reply With Quote
Old 12-20-2010, 08:52 PM   #12700
James khoo's Avatar
Trader Rating: 15 (100%+)
Send a message via Skype™ to James khoo
Hi,
Did anyone have a outdoor parking lot rubber tire set up?please email me at [email protected]
James
James khoo is offline   Reply With Quote
Old 12-20-2010, 08:54 PM   #12701
Trader Rating: 18 (100%+)
Thanks!
yup, i bought a set of turnbuckles from the older jrxs. used captured ends and put ballstuds on the hubs. easy as eating pie
Air Support for Team CPAURL
Team Powers
CKHobby.com
byohnd is offline   Reply With Quote
Old 12-20-2010, 09:48 PM   #12702
Thanks!
use a JR link. Basically it's just a longer turnbuckle, ball ends and ball studs.
cheapskate.brok is offline   Reply With Quote
Old 12-20-2010, 10:12 PM   #12703
outtafocus's Avatar
The JR link is the standard JRXS-R link.
What you need is the following to make the typical TC turnbuckle link.
http://losi.com/Products/Features.aspx?ProdId=LOSA1233
http://losi.com/Products/Features.aspx?ProdId=LOSA6532
http://losi.com/Products/Features.aspx?ProdId=LOSA6017
For further build and setup tips visit:
http://www.thard.co.uk/viewtopic.php?f=42&t=352
www.rcdepot.ca-Hobbywing-Tekno-TLR-Brass Knuckle Brush Worx
outtafocus is offline   Reply With Quote
Old 12-20-2010, 10:25 PM   #12704
If you use a standard link then you should already have a turnbckle setup. If using the jr's, trim down the ball cup a little then just install a standard very short turnbuckle. Its all very straight forward.
Blade: Andro Treiber H 79g AN
FH: Donic Bluefire M3 Max Blk
BH: Donic Bluefire M2 Max Red
Powered by Falco
Dragonfire is offline   Reply With Quote
Old 12-22-2010, 01:00 PM   #12705
[QUOTE=Dragonfire;8370616]If you use a standard link then you should already have a turnbckle setup. If using the jr's, trim down the ball cup a little then just install a standard very short turnbuckle. Its all very straight forward.[/QUOTE
That is a heck of an idea, I like it! Now if I can just find my Jr arms,,,,,
flyintrtle is offline   Reply With Quote
[FS] Team Losi JRXS-Type R squarehead R/C Items: For Sale/Trade 9 07-21-2012 12:59 AM
Team Losi JRXS Type R gtxpro2 R/C Items: For Sale/Trade 18 09-11-2008 08:45 PM
WTB: Team Losi JRXS Type R shifter R/C Items: Wanted to Buy 1 07-03-2008 03:30 PM
Team Losi JRXS TYPE-R John Q R/C Items: Wanted to Buy 1 10-03-2007 06:55 PM
Team Losi JRXS Type R New In Box Canyon R/C Items: For Sale/Trade 0 06-20-2007 04:50 PM
