Old 12-14-2010, 02:39 AM   #12676
the losi is not ideal for VTA. Can't run low FDRs
cheapskate.brok is offline   Reply With Quote
Old 12-14-2010, 02:53 AM   #12677
Are you kidding?
Blade: Andro Treiber H 79g AN
FH: Donic Bluefire M3 Max Blk
BH: Donic Bluefire M2 Max Red
Powered by Falco
Dragonfire is offline   Reply With Quote
Old 12-14-2010, 03:05 AM   #12678
Originally Posted by Dragonfire View Post
Are you kidding?
No offense. Well i wanted to originally but now the zero s is out so....
how do you guys run FDRs 5 and below? Losi's smallest spur is 116T, and I just refuse to make an effort to get those layshafts you guys have been talking about.
I can't imagine how much rear bulkhead material I have to grind just to get newer 6200mahs to fit in Oh well, still luv my losi anyway
Old 12-14-2010, 03:31 AM   #12679
kwiksi's Avatar
Trader Rating: 104 (100%+)
Send a message via AIM to kwiksi
Why would someone need to use a 6200mah batt?
David Perez
Big thanks in 2017 to
Serpent/Desoto Racing - Jconcepts - Maclan Racing - Schelle Racing Innovations - Exotek Racing - PT Racing Oils - 92Zero Designs
kwiksi is offline   Reply With Quote
Old 12-14-2010, 03:49 AM   #12680
mini696's Avatar
I'll find a way to make it work, I have to, its the class our club is moving to.
D8, GO 5Port
Ve8, RX8 1900, Promatch 5100 4S
SC10, Hobbywing EzRun
mini696 is offline   Reply With Quote
Old 12-14-2010, 04:36 AM   #12681
Yeti35's Avatar
You can get it to work if you have a PRS adapter or one of the new layshafts. I ran 4.0 all the time in 13.5 before boost speedo's were a big deal. I ran 64 pitch spurs though. 112/51 will put you at 4.02 FDR with 64 pitch spurs/pinions.
JRXS Type R, I have four of them!! ;) ( Yes, I still have them!!)
22 2.0
22T 2.0
Yeti35 is offline   Reply With Quote
Old 12-14-2010, 08:42 AM   #12682
You can also help yourself by using the 41T diff pulley on both differentials.
i.e. a 112/51 as previously illustrated will put you at 3.91
calvin is offline   Reply With Quote
Old 12-14-2010, 11:24 AM   #12683
YmeBP's Avatar
Trader Rating: 32 (100%+)
The type-r is one of the most potent VTA cars out there because of the turn in it has and the short arms. As for the FDR i was able to get to 4.2 w/ stock kevlar 118 and larger pinions. in VTA i've run two back to back 8min heats w/ the same 5600 and still had 20% left in the pack, you must have a huge track to need a 6xxx lipo.
www.skyrocketracing.com quality RC gear!
http://www.rctech.net/forum/racing-forum/555071-2011-skyrocket-invitational-blue-diamond-raceway-october-15-16-a.html <- Great race!
YmeBP is offline   Reply With Quote
Old 12-14-2010, 12:06 PM   #12684
jhwnissan's Avatar
I'm running a 3.6 with the PRS adapter. It's the best.
Josh Howard on RCNEWB.COM
Drawing rc car body madness in a Bunker....
Rare Losi R/C Belt Maker Extraordinaire
Need belts or parts? I can help.
SWs, RWs, XX-4s, XXX-S
jhwnissan is offline   Reply With Quote
Old 12-14-2010, 12:36 PM   #12685
Default batt
ok so i see a lot of pplz doing diff things w/gearing .. has anyone noticed any effect by using a diff batt ? higher C rating ?
I just got my 6500mah, maxamps, 150c rated batt. itching to try it tommorrow.
dmakrc is offline   Reply With Quote
Old 12-14-2010, 05:56 PM   #12686
Packs like that are generally considered to he softer unless you run mod. A 40c would have more punch.
The main reason you get the FF layshaft is it spreads the pulleys so they don't hit your lipo. It saves you sanding down pulleys to do the same thing.
Powered by Falco
Old 12-14-2010, 08:30 PM   #12687
Trader Rating: 21 (100%+)
quick q...i'm just getting around to put in a ballistic 17.5 motor and the solder tabs hit the bulkhead...is there some motor spacer that you guys are using to get this motor to not hit ? thanks
thefnshow is offline   Reply With Quote
Old 12-14-2010, 11:06 PM   #12688
Trader Rating: 68 (100%+)
No,i just bent the tabs and fit no problem.
SpeedZone Batteries
steve eaves is offline   Reply With Quote
Old 12-14-2010, 11:06 PM   #12689
thats funny
SpeedZone Batteries
Old 12-15-2010, 07:15 PM   #12690
Default steal lipo tray
Hi guys, jus wondering on the steel lipo tray, does it have a lip ? the lip on the factory tray is too small .... dun wana have to dremel .. hahaha
a pic of the inside would be appreciated.
[FS] Team Losi JRXS-Type R squarehead R/C Items: For Sale/Trade 9 07-20-2012 11:59 PM
Team Losi JRXS Type R gtxpro2 R/C Items: For Sale/Trade 18 09-11-2008 07:45 PM
WTB: Team Losi JRXS Type R shifter R/C Items: Wanted to Buy 1 07-03-2008 02:30 PM
Team Losi JRXS TYPE-R John Q R/C Items: Wanted to Buy 1 10-03-2007 05:55 PM
Team Losi JRXS Type R New In Box Canyon R/C Items: For Sale/Trade 0 06-20-2007 03:50 PM
