Old 12-10-2010, 04:50 PM   #12646
Originally Posted by outtafocus View Post
It has been far to quiet in here the past few days.
Whats new?? someone has to be trying something out.
it's so good there's nothing much to comment
cheapskate.brok is offline   Reply With Quote
Old 12-11-2010, 03:29 AM   #12647
Ok, here's what I've been working on. For what it's worth........
I'm using a stick pack 4200 Lipo battery. The wires come out of the middle of the end of the pack like a NiMH stick pack. Because of this, I have to put the pack in the car so that the wires come out at the back of the car and exit up between the motor and the lay shaft. This requires me to move the pack as far forward in the car as possible. I tried to use the metal bottom plate but found the plastic one works better for this. I machined the front of it just a little so the pack could be moved forward a few mm and then stuck the pack to the battery tray with Parma double sided servo tape. Now, the battery fits in easily and there is about 1-2mm space between the top of the pack and the bottom of the top plate.
So, this isn't a big deal in itself but there are some real advantages to this that have nothing to do with the type of battery I'm using. First is that the plastic bottom plate allows the chassis to flex more than the metal one. I don't want to buy the Exoteck top plate because it won't help me with my battery. All it will do for me is take some of the stiffness out of the chassis. The plastic bottom plate does the same thing. Also, by sticking the battery to the tray with servo tape, it does not contact the top plate. This also helps with chassis flex. Now the chassis is free to move as it was designed to do. Next is by using the plastic battery tray, you get the ability to add weight to the bottom of the car on centerline. Those lead stick on weights fit perfectly between the ribs in the tray. Just stick them to the bottom of the battery. Now you can add weight as needed towards the front or rear of the car and it's as low as you can get.
I know the metal batter tray is cool, but in my opinion, this setup's advantages outweigh that.
woodys3b is offline   Reply With Quote
Old 12-11-2010, 03:26 PM   #12648
dfiantii's Avatar
Trader Rating: 16 (100%+)
Send a message via AIM to dfiantii Send a message via Yahoo to dfiantii
Has anyone received any updates as to the status of the Layshafts. My order has been backdated since 11/12/10
TT-01/Hitec MG/SP LPF V1.1/Trinity 7.5
Losi Type-R/JR Z8800S/SP GT 2.0
Exotek F1R/Savox 1251/Tekin RS
TLR 22 2.0
"ELECTRIFIED TO THE HILT"
dfiantii is offline   Reply With Quote
Old 12-11-2010, 05:11 PM   #12649
outtafocus's Avatar
Mine took just a little over a month.
I ordered mine at the end of Oct. and received it at the beginning of Dec.
Have patients it will come. I doubted my order also.
www.rcdepot.ca-Hobbywing-Tekno-TLR-Brass Knuckle Brush Worx
outtafocus is offline   Reply With Quote
Old 12-12-2010, 04:05 AM   #12650
Default Steering servo arm swap
I use a Futaba servo. Just stripped another one at the track yesterday. Rather than buy another set which includes arms for lots of other servos, I thought maybe someone out there uses a different servo and has a bunch of Futaba arms laying around.
So, who wants to swap their unwanted Futaba arms for something you can use?
Old 12-12-2010, 04:14 AM   #12651
From FF or elsewhere?
Blade: Andro Treiber H 79g AN
FH: Donic Bluefire M3 Max Blk
BH: Donic Bluefire M2 Max Red
Powered by Falco
Dragonfire is offline   Reply With Quote
Old 12-12-2010, 04:26 PM   #12652
Well I am about 75% complete on my 1st build. I have a HiTec 645 servo that I was going to use but it's too big. Won't fit. I also have a Traxxas # 2080 servo new in the bag . Anyone think this would work ?
Also I could use some suggestion on a motor and ESC ?? I'm just going to run the car on the street for now, no racing. Thanks
steve1 is offline   Reply With Quote
Old 12-12-2010, 04:59 PM   #12653
Dragonfire, I ordered a FF spool from SkyRocket Batteries here in the states, August of 09 & it was on back order. I spoke with Skyrocket 4 months ago & it's still on backorder. I said okay, send me the FF layshaft instead. Guess what? That's on backorder!
flyintrtle is offline   Reply With Quote
Old 12-12-2010, 05:54 PM   #12654
Yeah there is a story behind that. I suggest cancelling your order and get one from FF them selves. There was a bag with about 50 layshafts at his.place the other day. I also believe he is.looking for a person to produce the spool v2 and its outdrives. The previous person has proven to be overload withother work and has no time to produce them.
Powered by Falco
Old 12-12-2010, 06:10 PM   #12655
Pablo Diablo's Avatar
Send a message via Skype™ to Pablo Diablo
More Layshafts are on the way to Skyrocket as we speak. Anyone with a Layshaft on backorder with them are now best waiting rather than cancelling and ordering direct. I find out in about 2hrs from now the exact time for manufacturing the new spool. I will post again after that.
Paul H
Losi Type R | Xray T3 | CRC Gen XL | CRC Gen X 10 ME(Messiah Edition) | Black Diamond
www.FlyingFoxRC.com | Advanced Electronics | Team CRC | Factory Messiah
Pablo Diablo is offline   Reply With Quote
Old 12-12-2010, 06:45 PM   #12656
outtafocus's Avatar
I will be interested in one of the new spools.
As will many others.
I just put the Losi type spool in my car yesterday, with the plastic pads on the pulley. I hope it will work ok in 17.5 touring stock. I tightened the diff as much as I could but I think Im so close to stripping the outdrive I dont want to go any more.
I also did a a whole bunch of setup work, Im hoping this car will handle way better after the new year. I cant race again till then.
Old 12-12-2010, 07:36 PM   #12657
dfiantii's Avatar
I am still waiting for my layshaft. I at least would like to get a weekly update on my order same thing I am experiencing with AXIOMMOTORS. Spoke to the owner after a month yesterday was told my order was delivered yesterday but I spoke to my wife she said she never got it. I guess the deal was to good to be true was ordering a package what would put ceramic balls and thrust in my Type R. Still waiting on a tracking number from AXIOM.
TLR 22 2.0
Old 12-13-2010, 03:09 AM   #12658
Does anyone know of an aftermarket metal servo arm for the Type-R?
Old 12-13-2010, 08:18 AM   #12659
outtafocus's Avatar
A weekly update on your order. Now that is funny.
Old 12-13-2010, 09:10 AM   #12660
MikeXray's Avatar
Trader Rating: 73 (100%+)
I was telling a racer at our track for the rear turnbuckle issue, get these:
http://www.lunsfordracing.com/mm5/me...egory_Code=3MM
20mm turnbuckles with RPM ballcups, the stock turnbuckle is too short to run the long length.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
[FS] Team Losi JRXS-Type R squarehead R/C Items: For Sale/Trade 9 07-20-2012 11:59 PM
Team Losi JRXS Type R gtxpro2 R/C Items: For Sale/Trade 18 09-11-2008 07:45 PM
WTB: Team Losi JRXS Type R shifter R/C Items: Wanted to Buy 1 07-03-2008 02:30 PM
Team Losi JRXS TYPE-R John Q R/C Items: Wanted to Buy 1 10-03-2007 05:55 PM
Team Losi JRXS Type R New In Box Canyon R/C Items: For Sale/Trade 0 06-20-2007 03:50 PM
