Old 10-30-2010, 09:14 PM   #12391
Question is this a better car in VTA than a tc3?
J. Barton
Associated B5M
Associated RC8B3E
smokefan is offline   Reply With Quote
Old 10-31-2010, 01:41 AM   #12392
I think its a better car than pretty much anything in any class, so yes. I have won most events I have run with it this year including a state title (10.5) and Muchmore Masters (also 10.5).
Blade: Andro Treiber H 79g AN
FH: Donic Bluefire M3 Max Blk
BH: Donic Bluefire M2 Max Red
Powered by Falco
Dragonfire is offline   Reply With Quote
Old 10-31-2010, 02:18 AM   #12393
transplantlife's Avatar
Trader Rating: 43 (98%+)
anyone have a good base line carpet set up? Thanks
IM A SURVIOR OF A DOUBLE ORGAN TRANSPLANT KIDNEY/PANCREAS...PLEASE BE A ORGAN DONOR TO GIVE LIFE TO OTHERS!!
transplantlife is offline   Reply With Quote
Old 10-31-2010, 12:10 PM   #12394
MikeXray's Avatar
Trader Rating: 73 (100%+)
Well for $200 new, its a heck of a lot "newer" than a TC3, but shaft drive IS a nice advantage in vta with the slow motor. Personally when I ran my type-r in VTA is was very hard to get the rear end to stick, it just had way too much front bite. We weren't chopping top decks back then though, so that may have helped.
I still feel like if someone were to make longer arms for the car it would probably be excellent, I had 3 of them over the years and have found other brand cars are just easier to be consistent with.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 10-31-2010, 02:20 PM   #12395
Thanks for the info. My son has a chance to get a Losi or a older x ray T1FK05 and he is trying to figure out which car would be better for him for VTA.
J. Barton
Associated B5M
Associated RC8B3E
Old 10-31-2010, 03:30 PM   #12396
Gergely's Avatar
Try this: http://www.petitrc.com/reglages/losi...sLosiJRXS.html
Gergely is offline   Reply With Quote
Old 10-31-2010, 04:09 PM   #12397
Jochim_18's Avatar
It will be hard to get parts for the FK05
Localrcracing.com - Your premiere source of Radio controlled Racing in central California.
Visaliahobbies.com * SkyRC * casterracingparts.com
Old 10-31-2010, 05:26 PM   #12398
Thats what I thought also. More than Likely he will be getting the Losi depending on the final deal.
J. Barton
Associated B5M
Associated RC8B3E
Old 11-01-2010, 04:41 AM   #12399
Trader Rating: 10 (92%+)
Default spool v's diff
so I'm currently building my car, and I was wondering what the feeling/handling would be of putting a diff at the front as per manual, as opposed to spool. I guess I will never find out until I try, but have never used a diff at the front of ANY car before.
I'm guessing more turn-in off power, more on power steering as well. Slightly less forward traction......
can anyone share their experiences?
captain stacker is offline   Reply With Quote
Old 11-01-2010, 05:22 AM   #12400
just gets better and better
how do I put the diff hub through if the losi spool pulleys center hole is too small? Dont tell me I have to bore a bigger hole? I would think the spool pulley would be an easy drop and fit.
Old 11-01-2010, 05:28 AM   #12401
Originally Posted by POOKYT View Post
You will have to either enlarge the center hole or very gently pry out the pads and place them in your new pulley. Be VERY carefull and gently work around the pads with a thin blade or screwdriver as those pads are VERY brittle.
Brant
dont worry, found my answer.
however, why did losi bother making these if you cannot use the spool pulleys, or are these for the older jrx-s?
Old 11-01-2010, 05:49 AM   #12402
dfiantii's Avatar
Trader Rating: 16 (100%+)
Send a message via AIM to dfiantii Send a message via Yahoo to dfiantii
I believe the white pulleys are the the older car when ordering parts make sure its made for the JRXS-R otherwise you might end up with the older cars parts. I made this mistake when I was stocking up on spares...
http://www.horizonhobby.com/Products...rodID=LOSA3329 (Spool)
http://www.horizonhobby.com/Products...rodID=LOSA3326 (Diff Pulley)
If you notice the spool pulley has no holes for the diff balls and the diff pulleys have round holes not square holes for the diff balls.... Seems like Horizon needs to get a phone call from you...
TT-01/Hitec MG/SP LPF V1.1/Trinity 7.5
Losi Type-R/JR Z8800S/SP GT 2.0
Exotek F1R/Savox 1251/Tekin RS
TLR 22 2.0
"ELECTRIFIED TO THE HILT"
dfiantii is offline   Reply With Quote
Old 11-01-2010, 07:45 AM   #12403
Captain...the white spool pulleys are definitely for the non-R version of the car. The correct spool pulleys (41 & 42 tooth) are black and fit perfectly on the diff hub!
Hope that helps!
Cheers,
Mike
Mike
Hyper_Mike is offline   Reply With Quote
Old 11-01-2010, 09:43 AM   #12404
oh yep, the black ones look like the correct ones. But when I was researching about spools for the type r in this thread, people was always referring to the white ones, and made no mention of the black ones you have listed. I'll just carefully remove the plates from the white ones and install them to the current ones.
Old 11-01-2010, 12:49 PM   #12405
superspeed's Avatar
For $200, it seems a good kit for the price. My local hobby shop is going to order couple from Horizon.
superspeed is offline   Reply With Quote
[FS] Team Losi JRXS-Type R squarehead R/C Items: For Sale/Trade 9 07-20-2012 11:59 PM
Team Losi JRXS Type R gtxpro2 R/C Items: For Sale/Trade 18 09-11-2008 07:45 PM
WTB: Team Losi JRXS Type R shifter R/C Items: Wanted to Buy 1 07-03-2008 02:30 PM
Team Losi JRXS TYPE-R John Q R/C Items: Wanted to Buy 1 10-03-2007 05:55 PM
Team Losi JRXS Type R New In Box Canyon R/C Items: For Sale/Trade 0 06-20-2007 03:50 PM
