Old 10-24-2010, 06:35 AM   #12346
Drsmooth, is that an exotek topdeck? Or is that your own design? I remember a few posts back you said you wanted more chassis flex, just curious.
flyintrtle is offline   Reply With Quote
Old 10-24-2010, 09:14 AM   #12347
mira5489's Avatar
Hi All,
Just ordered mine & would like to know what is the biggest capacity lipo that i can fit in this kit without modifling? Any recommendation? thanks you very much!!! Appreciate your help!!
Team Losi Racing - Dynamite - ECX racing - Hope - Team Orion - Nitro-x - Spektrum
Taiping Track Operator : Email: [email protected] / HP: 012-5120309
mira5489 is offline   Reply With Quote
Old 10-24-2010, 09:26 AM   #12348
Default lipo
not sure if u mean physical dimensions or S rating. I recommend getting a low profile servo as i found that it is a tight fit w/a regular servo. The horn keeps rubbing against the back of my lipo. I changed to a Futaba S9551 and now, all my lipos can fit.
dmakrc is offline   Reply With Quote
Old 10-24-2010, 11:02 AM   #12349
BrodieMan's Avatar
Could not resist the $199 price tag, will have my new JRX-S Type R on wednesday
What would be a decent all around tire for cold weather?? Going to be running indoor on a very smooth underground parking lot and am not sure if I should go with foams or rubber? Will be racing carpet once and a while so I will find out what the club runs but for now I just want a tire that will last a while, have decent traction and is reasonably inexpensive. Also wondering if the Protoform R9-F is a good body for carpet racing? Can't wait for Wednesday
Mark Richardson
Kawartha Radio Controlled Racers
Lakefield Hobby & Game. ExtremeRCforum
Schumacher Mi4cx CRC Gen-X 10 LE
BrodieMan is offline   Reply With Quote
Old 10-24-2010, 01:21 PM   #12350
Gergely's Avatar
Default Exotek topdeck
Hi all,
I had the chance the run with the new Exotek topdeck today. All I can say is woooow, the result is impressing if you are using rubbers. The setup needs to be changed completely but in the end you will get a better steering and easier to drive car.
Gergely is offline   Reply With Quote
Old 10-24-2010, 01:36 PM   #12351
3rd-dan's Avatar
What Setup would be recommended?
Cheers Mike
3rd-dan is offline   Reply With Quote
Old 10-24-2010, 01:44 PM   #12352
Gergely's Avatar
I've just sent you an email. If you just change the topdeck the first impression will be huge push, but if you compensate it with some adjustments then
Old 10-24-2010, 03:04 PM   #12353
I ran my type-r for the first time today, I've had it for a few years, but only recently had the opportunity to run it.
I ran the old JRXS years with some awesome results, but this car feels way better already.
Only one problem though, I can get the diff tight without it stripping the outdrive, the diff wasn't even close to not slipping before it stripped. I don't understand why they don't have a captured nut like the old car.
I managed to do a 'track repair' by using belleville washers, which meant the screw past all the way through the outdrive, with the spring it doesn't seem to come far enough through, I still don't think its right though.
Any ideas chaps?
J A M I N is offline   Reply With Quote
Old 10-24-2010, 03:38 PM   #12354
drsmooth's Avatar
Trader Rating: 33 (100%+)
This is of my own design. Designed this for the Micro RS4 about 6 years ago & it worked great on that car. So I thought it would work great on the Type R too. It did! No tweaks or setup changes were required. Just gave the car more on power steering. Just made a sweet car super sweet.
Here's the original.
Till next time.......
KEEP ON RACING!
drsmooth is offline   Reply With Quote
Old 10-24-2010, 04:02 PM   #12355
yeah, I'm interested to know about the dimensions too! Thanks!
Current cells are between 23mm ~25mm height
cheapskate.brok is offline   Reply With Quote
Old 10-25-2010, 08:12 AM   #12356
Gergely's Avatar
Hello Jamin,
It's very much depends on how you build diff. Also on the grease you are using. If you look closely the 2 sides of the diff rings are different. One has a more round edge inside while the other is more sharp. I use this sharp side against the balls and also of course sand them on a flat surface to be sure they are perfectly flat. I suggest to use AE clear grease on the balls and black on the thurst. Finally, use Tamiya AG grease 54032 between the diff house-brass ring-diff ring. With this method you can achieve the same tightness with much less load on the balls. Hope this helps.
Any ideas chaps?
Old 10-25-2010, 02:44 PM   #12357
mojoman's Avatar
Originally Posted by mira5489 View Post
Hi All,
The Thunder Power 40c 50c and the brand new 65c all use the same case and all will fit without any modifications.
Casey Castleman
Team Driver: OHP / Jaco / Razor Graphix / Thorpewood
RIP The Coliseum at HobbyTown USA Frederick, MD
mojoman is offline   Reply With Quote
Old 10-25-2010, 02:50 PM   #12358
Big Midget's Avatar
Trader Rating: 99 (100%+)
Are low profile steering servo's a must have with the JRXS Type R?
Dee & Mee Hobbies
Fastlane Raceway-wwwfastlanehobbies.com
Topeka On-Road Racing-Jake's R/C Pro-Am Topeka,Ks
www.ZigPhoto.com,RickyRacer Lidz,Absolute Tattoo,Fuzzy Dice Decals
Big Midget is offline   Reply With Quote
Old 10-25-2010, 02:55 PM   #12359
mojoman's Avatar
No, there are shims provided with the kit to space out the servo from the battery. I'm using a clunky futaba 9451 and have been for a while.
Casey Castleman
Old 10-25-2010, 03:48 PM   #12360
Big Midget's Avatar
Thanks for the reply mojoman.
Dee & Mee Hobbies
[FS] Team Losi JRXS-Type R squarehead R/C Items: For Sale/Trade 9 07-21-2012 12:59 AM
Team Losi JRXS Type R gtxpro2 R/C Items: For Sale/Trade 18 09-11-2008 08:45 PM
WTB: Team Losi JRXS Type R shifter R/C Items: Wanted to Buy 1 07-03-2008 03:30 PM
Team Losi JRXS TYPE-R John Q R/C Items: Wanted to Buy 1 10-03-2007 06:55 PM
Team Losi JRXS Type R New In Box Canyon R/C Items: For Sale/Trade 0 06-20-2007 04:50 PM
