Old 09-26-2010, 09:05 AM   #12286
Default servo horn hitting lipo batt
Hi guys, searched the thread and no one seemed to have this issue. Im using a spektrum servo w/aluminum servo horn. when i put the lipo in the tray, it's very tight and butting up against the horn. Anyone else having this issue ? I tried several of my hard packed lipos and they all butt up right against it. Do i need to get a low profile horn (if there's such a thing) ?? Oh im using the stock battery tray, plastic one.
dmakrc is offline   Reply With Quote
Old 09-26-2010, 12:32 PM   #12287
js058515's Avatar
I use the kit horn w/ a Futaba s9551 servo which is one of the few popular servos for TC. I have no issues and at all and haven't seen any "battery hitting servo" issues posted either.
Have you tried using the kit horn or another servo? I would start there.
js058515 is offline   Reply With Quote
Old 09-26-2010, 05:40 PM   #12288
I would say look at the spacing on your servo mounts. You get a couple of spacers that allow you to move the servo forward or backwards. Check this out and see if you can move it further forward.
Blade: Andro Treiber H 79g AN
FH: Donic Bluefire M3 Max Blk
BH: Donic Bluefire M2 Max Red
Powered by Falco
Dragonfire is offline   Reply With Quote
Old 09-28-2010, 02:36 PM   #12289
Default horn
Thanks for all the great advice !! I ended up not using the Losi horns and using an aluminum servo horn (futaba) ... had to turn the connector to the horn sideways, which now is interfering w/the turning radius. Anyone else encounter this ?
I guess i can always cut diamond hole in the top plate into a square, dont really want to. Or look for a longer servo horn, which means more $ / wait time on order.
Im using aluminum w/an ACE ds1313 metal gear servo, dun really wana use the stock plastic ones in case it strips the plastic horn.
Old 09-28-2010, 02:38 PM   #12290
Default Flying Fox stuff
Im also looking for some of the Flying Fox stuff if anyone has that they don't want ... PM me.
Old 09-28-2010, 02:53 PM   #12291
Nah the top of the servo horn should be right in the middle of the diamond in the top deck. You should have no problems doing this with the kit servo mounts.
Powered by Falco
Old 09-28-2010, 04:41 PM   #12292
Default servo horn
oh i agree. I just wanted an option to use my aluminum horn for reasons already stated.
Jus wondering if anyone else is doing that or is every1 using stock plastic horns ?
Old 09-28-2010, 04:57 PM   #12293
MikeXray's Avatar
Trader Rating: 73 (100%+)
If you attach the stock horn with a button head screw it will NOT strip out, I think you're making a lot fo work for yourself. We had at least 10 type-rs running foam smashing into boards with plastic horns.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 09-28-2010, 05:11 PM   #12294
Default horn
hmmm true eh ? jus didnt wana wait the 10 days to order new horns from Losi hahahaha...
either that or break out the dremel !!
Does anyone know any sites where i can order the flyfox stuff ? Their website is outa stock...
Old 09-28-2010, 05:38 PM   #12295
js058515's Avatar
Your waiting like a lot of us. Maybe in November we will be able to get our hands on the spool and outdrives.
Old 09-29-2010, 09:21 AM   #12296
jrxs-r's Avatar
Dragonfire--> ran a modified setup of yours tonight on carpet (standard top deck, harder rear springs (no bar), longer rear link) and it was quite nice to drive... :P Will continue to improve it to see how it goes.
Cheers,
Zack
___________________________________________________________________________
Proudly Sponsored by Stanbridges Hobbies
Serpent S411
jrxs-r is offline   Reply With Quote
Old 09-30-2010, 12:44 AM   #12297
You have a carpet track to race on now? Foam or rubber?
I am going down to ACT this weekend for club challenge. Its going to be a carpet/foam weekend although my TC is not the reason I am going. I have thrown a "theoretical" setup n it. If it goes well I will post it up for you.
Powered by Falco
Old 10-01-2010, 05:28 AM   #12298
jrxs-r's Avatar
Always had a carpet track here for a long time. Push-Pin carpet running rubber tyres (no additives). Sweep 24R with Sorex B Med inserts work a treat here. It is a basket ball court sized track, so its pretty tight and windy. Laptimes for 10.5 are around the 11.5-11.9 secs.
I will be trying out the EXOTEK top deck this coming Wednesday night, and will see how it goes.
BTW, has Paul still have any aluminium battery tray holders?
Cheers,
Zack
Serpent S411
Old 10-01-2010, 05:52 PM   #12299
raycerZ's Avatar
Originally Posted by TryHard View Post
Hey guys,
Just thought I'd post my setup from the last round of the BRCA nationals this past weekend.
Ed what type pf track do you guys race on?
raycerZ is offline   Reply With Quote
Old 10-01-2010, 06:27 PM   #12300
crabboy's Avatar
Trader Rating: 58 (98%+)
Fitted my new Exotek top deck last night the deck fitted up spot on but the small carbon screw plates the screw hole seems a bit small and two of them delaminated when I screwed the screw in. One good thing on the top deck is it has adjustable ackaman via another set of holes, will try it out over then next week or two and post on here my results.
Rhys
Rhys Marshall.
crabboy is offline   Reply With Quote
[FS] Team Losi JRXS-Type R squarehead R/C Items: For Sale/Trade 9 07-20-2012 11:59 PM
Team Losi JRXS Type R gtxpro2 R/C Items: For Sale/Trade 18 09-11-2008 07:45 PM
WTB: Team Losi JRXS Type R shifter R/C Items: Wanted to Buy 1 07-03-2008 02:30 PM
Team Losi JRXS TYPE-R John Q R/C Items: Wanted to Buy 1 10-03-2007 05:55 PM
Team Losi JRXS Type R New In Box Canyon R/C Items: For Sale/Trade 0 06-20-2007 03:50 PM
