Old 09-21-2010, 08:26 AM   #12271
JRXS_chris's Avatar
Originally Posted by js058515 View Post
Did u do this mod to keep your JR links? If so do have a brand/link suggestion on what links you used. I like the JR links, but hate the lack of ease for adjustability. I have dealt with worse stuff in life so I know I can survive.
Yeah, I use both depending on track conditions etc.
I used a spare pair of turnbuckles I found in my pit box. I think they are actually camber link ones from the original JRXS. They were pretty short in length. The main thing is to find ones with a narrow adjuster nut, you can always trim the actual threads down.
JRXS_chris is offline   Reply With Quote
Old 09-21-2010, 07:23 PM   #12272
MikeXray's Avatar
Trader Rating: 73 (100%+)
Originally Posted by L.Fairtrace View Post
You know what else helps with turn in......?
A Tcx from what I understand.
The turn in is not the problem, its the flippy ova that is
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 09-21-2010, 08:52 PM   #12273
If you are having traction roll problems then try low rollcenters or longer upper links (jr on front).
Blade: Andro Treiber H 79g AN
FH: Donic Bluefire M3 Max Blk
BH: Donic Bluefire M2 Max Red
Powered by Falco
Dragonfire is offline   Reply With Quote
Old 09-22-2010, 06:19 AM   #12274
MikeXray's Avatar
I have moved on from the platform, lets just say I still think the arms are too short on this car to not have the problem on super high bite tracks. You can make it go away, but you will give up something to get there.
Old 09-22-2010, 09:05 AM   #12275
jrxs-r's Avatar
Fitted the EXOTEK top decks to my Rs this past few days, and I have to say that the finish of the decks were not as good as the standard decks. Where the holes/cutouts are on the decks, the 2 I have show signs of the top most layer being peeled back/broken away. One of them wasn't too bad, but the other one was very obvious. I finished them off by sanding and CA'ing the edges in hope that the delamination would not continue through the rest of the deck.
The CF battery tray screw holders were very tight to cut a thread into, and in the process I had 2 delaminate on me too. I would recommend to anyone getting the EXOTEK top deck to keep the aluminium ones and cut them down to size.
Will be trying them out on rubber/carpet and rubber/asphalt in the next comin weeks.
Cheers,
Zack
___________________________________________________________________________
Proudly Sponsored by Stanbridges Hobbies
Serpent S411
jrxs-r is offline   Reply With Quote
Old 09-22-2010, 12:50 PM   #12276
JRXS_chris's Avatar
I always prep my CF before use but thanks for the heads up!
Old 09-22-2010, 01:52 PM   #12277
TryHard's Avatar
Hey guys,
Just thought I'd post my setup from the last round of the BRCA nationals this past weekend.
Made the B in 10.5t, might not sounds great, but it's by far my best result of the year. Managed to get setup that seemed pretty well balanced, with good turn in and mid-corner rotation... if only the diff hadn't of gone bang in the finals, might have finished better than tenth
Cheers
Ed
Old 09-23-2010, 07:03 AM   #12278
Does anyone know the latest on the Flying Fox V2 spool?????
Murray is offline   Reply With Quote
Old 09-23-2010, 11:44 AM   #12279
js058515's Avatar
He is almost there! I had the same question and PM'd Paul, I won't quote his ETA, but hopefully by November.
js058515 is offline   Reply With Quote
Old 09-24-2010, 03:48 PM   #12280
crabboy's Avatar
Trader Rating: 58 (98%+)
I have always run the flying fox spool and it works great but in mod it strips the plastic clip in out drives nearly every run, i tried one of the Losi slipper spools and it works just as good BUT i have not stripped one plastic out drive, might be worth a try if you cant get a FF spool.
Rhys
Rhys Marshall.
crabboy is offline   Reply With Quote
Old 09-24-2010, 04:45 PM   #12281
js058515's Avatar
From what FF said, your gonna have a nice fix for those outdrives. He will be producing both the V2 Spool and replacement outdrives for our Type R's.
Crabboy, which Losi Spool are you referring to? I have seen the Losi One-way but did not want to go that route.
Rhys
Old 09-24-2010, 06:47 PM   #12282
crabboy's Avatar
Its a normal Losi diff BUT you use a Losi slipper pulley, the pulley runs plastic slipper pads instead of balls, then the diff is built as a normal diff.
Yeah the new FF spool is going to run delrin cups instead of plastic which will be great, if it ever happens.
Rhys
Rhys Marshall.
Old 09-25-2010, 12:48 AM   #12283
FREAKAH's Avatar
I always thought the stock outdrives were machined out of delrin.
Second-Hand Racing
RACE WORLD HAWAII
Losi Type-R |Tamiya F104 PRO | Tamiya F103 | Mugen MTX-4R | AE FT GT2
FREAKAH is offline   Reply With Quote
Old 09-25-2010, 02:08 AM   #12284
Pablo Diablo's Avatar
Send a message via Skype™ to Pablo Diablo
They are. There just isn't enough surface area where they key into the spool to hold the forces a spool can sometimes generate. My new outdrives will have about 3 time the area in the key to solve that. Part of the plan is for these new outdrives to be backwards compatible with older spools and kit diffs. Mine will be less expensive than the Losi outdrives too. These are parts that should be replaced very often, but at $5 a pop people probably use them longer than is ideal. Once they get a notch in them from the drive shaft pin, handling will be compromised.
I attempted to use a completely different material for the outdrives. the prototypes worked well but when I went to have them produced, the wasted material kept shutting down the machine. It was a very disappointing day indeed to abort production after waiting a while for the machine to be available. I really am close now to go again with Delrin.
I am also going to start producing a new ball diff that uses a bearing between the pulley and diff hub. This should help the car a lot on low to medium grip when getting on the power. i will post some pics of the prototype soon.
Sorry for the delays but it is very close now.
Paul H
Losi Type R | Xray T3 | CRC Gen XL | CRC Gen X 10 ME(Messiah Edition) | Black Diamond
www.FlyingFoxRC.com | Advanced Electronics | Team CRC | Factory Messiah
Pablo Diablo is offline   Reply With Quote
Old 09-25-2010, 06:53 PM   #12285
san.'s Avatar
Trader Rating: 59 (100%+)
Losi CVD 's, carriers and spindles for sale:
Losi JRX LCD's, arms and rear carriers
Awesomatix USA||Roche RC USA||Sanwa
san. is offline   Reply With Quote
[FS] Team Losi JRXS-Type R squarehead R/C Items: For Sale/Trade 9 07-20-2012 11:59 PM
Team Losi JRXS Type R gtxpro2 R/C Items: For Sale/Trade 18 09-11-2008 07:45 PM
WTB: Team Losi JRXS Type R shifter R/C Items: Wanted to Buy 1 07-03-2008 02:30 PM
Team Losi JRXS TYPE-R John Q R/C Items: Wanted to Buy 1 10-03-2007 05:55 PM
Team Losi JRXS Type R New In Box Canyon R/C Items: For Sale/Trade 0 06-20-2007 03:50 PM
