Old 09-12-2010, 08:03 PM   #12241
Jerry P's Avatar
Trader Rating: 44 (100%+)
Originally Posted by Mike Haynes View Post
As far as i know losi has no plans to redesign a 1/1o touring car. I do not speak directly with anyone at losi however, so i'd advise shooting an email over to them for the most up to date info.
The only other person who was using a type r at vegas was Brian Lutz, he made the stock a main with it but had some bad luck and broke out.
I used a Losi too. just happened that my Top was a little easier to drive.
Great job out there man. Just remeber the famous quote "that is a losi, Ha ha" You truly make the losi look amazing race after race.
Jerry P
Awesomatixusa - Side Piece Racing - LRP - Sweep Racing Tires - Mike L Designs - TQ Wires - Crispy Critters Raceway
www.awesomatixusa.com
Jerry P is offline   Reply With Quote
Old 09-12-2010, 09:14 PM   #12242
Trader Rating: 21 (100%+)
I got my car figured out for the last round only to blow out and cost me some spots on the grid. I was following the train at the start of the A and got sent to the boards when there was a mistake in front of me. The car didn't feel right after that and I had major driver failure.
The car is still a contender as Mike proved in superstock. Nice drive buddy!
Thanks to pops
TLR, Fantom, Horizon, Spektrum, Trackside
Brian L is offline   Reply With Quote
Old 09-13-2010, 12:06 AM   #12243
FREAKAH's Avatar
Well, i'd advise Losi/Horizon to put you on their payroll right away!
Great job Mike!
Second-Hand Racing
RACE WORLD HAWAII
Losi Type-R |Tamiya F104 PRO | Tamiya F103 | Mugen MTX-4R | AE FT GT2
FREAKAH is offline   Reply With Quote
Old 09-13-2010, 05:25 AM   #12244
Jerry P's Avatar
Great job Mike!
Yeah that's going to happen soon because losi is so into inroad. If its not 1/8 off road or a toy they really don't care. Haynes is a hell of a wheel and he sure got it done with the type r.
Jerry P
Old 09-13-2010, 05:44 AM   #12245
Well, after about two weeks I have finished my Type R build. This was the longest, toughest and ultimately most satisfying build I’ve ever done. Man, what a nice looking car – no batteries hanging off one side, counterbalanced by a motor hanging off the other side waiting to get rocked in a racing incident. Nice, sleek design.
With this car I was also making the transition to LiPo/Brushless and this is where the fun started. At the time of my car purchase I also bought a Tekin RS Pro/Redline combo and an Integy LiPo with bullet connections. When I do a build on a car that’s new to me I always do a trial build to get a feel for the overall car and identify areas I want to concentrate on in the final build. To my surprise when I bolted in the Redline motor there was almost zero room for gearing adjustment due to interference with the left rear inner pivot block; and of course the LiPo was a problem in the lay shaft area, battery tray and access to the bullet connections.
After about an hour work with a Dremel cutting wheel on the pivot block I was able to create enough clearance to enable enough adjustment to use up to a 42T pinion with the stock 128T spur. A bit of advice to anyone trying this is to be careful cutting as this is a fairly expensive piece. I would also advise purchasing another set of inner pivots and making adjustments on this set also with the idea of using one set for high roll center and one set for low roll center. The cutting will get into the threads and you probably don’t want to rely on these threads in the alternate configuration.
The next area was the lay shaft. I know everyone recommends the Flying Fox product, but this wasn’t an option for me. I put a washer between the pulley and shim on each end of the lay shaft then Dremeled out a slot in the A3327 drive hub to accommodate a shorter pin (part # A6406) such as used on the other pulley. The slot should be deep enough to offer a good fit for power transmission purposes and allow free rotation of the lay shaft. This now locks the lay shaft to the hub rather than the spur gear. I would advise putting the slot in the lined up position of the original pin. The next thing is to cut off some of the nub in the middle of the spur gear to allow it to be able to be fitted on the shaft. Only cut off enough to allow the C clip to be installed. Unless long term racing proves different, I think I’m going to like the mod.
The next area was to Dremel the sides of battery tray to fit the battery. Even after doing this I still need to loosen the top deck in order to install the battery. I think I’ll leave it this way for the time being since loosening the top deck is easy with the above deck steering layout and I plan to leave the battery in the car and not exchange batteries anyway. Finally I had to Dremel the top deck to allow access to the battery posts.
When I went to do my initial in car charge the charge leads would not extend down fully onto the battery posts due to interference with the top deck and I was concerned about a possible short circuit between the two posts. I didn’t want to Dremel out any more of the top deck in this area so I made an adapter by soldering a male bullet connector to the end of a female bullet barrel and applied heat shrink for protection.
Well, hopefully I’m ready for a shake down cruise next weekend!
My thoughts, hope this can help any other new comers.
One question for you old timers. In the Outdoor Rubber Setup sheet it mentions 2 O rings above the bladder in the shock setup. Any insight and O ring part numbers would be appreciated.
calvin is offline   Reply With Quote
Old 09-13-2010, 07:21 AM   #12246
I don't think anyone puts anything above shock bladders much anymore.
Blade: Andro Treiber H 79g AN
FH: Donic Bluefire M3 Max Blk
BH: Donic Bluefire M2 Max Red
Powered by Falco
Dragonfire is offline   Reply With Quote
Old 09-13-2010, 09:06 AM   #12247
jrxs-r's Avatar
Originally Posted by Dragonfire View Post
Paul is making a new design though I am not sure when they will be done. I believe he wants some ready for the NSW state titles at the end of OCT so they should be ready by then.
Here is my setup for the SA state titles last weekend. Car seemed to be the equal of anything out there on the track when driven cautiously. I am not sure if it could have gone faster as it just wasn't needed. Note this setup was for a asphalt surface that has been painted to enhance its grip. It was also sugar watered as well.
Tried your setup with a couple of minor variations to suit the track and my driving style.... Found that the high roll centers in the rear works quite well, and suits my driving style quite well. Managed to finish 3rd with a cogging LRP SXX SS.... took a lot of driving to keep in front! :P can't wait for my RS Pro to come back from Tekin!!
You heading to the Nationals in Nov?
Cheers,
Zack
___________________________________________________________________________
Proudly Sponsored by Stanbridges Hobbies
Serpent S411
jrxs-r is offline   Reply With Quote
Old 09-13-2010, 10:32 AM   #12248
MaxRain's Avatar
Well, after about two weeks I have finished my Type R build. This was the longest, toughest and ultimately most satisfying build Iíve ever done. Man, what a nice looking car Ė no batteries hanging off one side, counterbalanced by a motor hanging off the other side waiting to get rocked in a racing incident. Nice, sleek design.
With this car I was also making the transition to LiPo/Brushless and this is where the fun started. At the time of my car purchase I also bought a Tekin RS Pro/Redline combo and an Integy LiPo with bullet connections. When I do a build on a car thatís new to me I always do a trial build to get a feel for the overall car and identify areas I want to concentrate on in the final build. To my surprise when I bolted in the Redline motor there was almost zero room for gearing adjustment due to interference with the left rear inner pivot block; and of course the LiPo was a problem in the lay shaft area, battery tray and access to the bullet connections.
After about an hour work with a Dremel cutting wheel on the pivot block I was able to create enough clearance to enable enough adjustment to use up to a 42T pinion with the stock 128T spur. A bit of advice to anyone trying this is to be careful cutting as this is a fairly expensive piece. I would also advise purchasing another set of inner pivots and making adjustments on this set also with the idea of using one set for high roll center and one set for low roll center. The cutting will get into the threads and you probably donít want to rely on these threads in the alternate configuration.
The next area was the lay shaft. I know everyone recommends the Flying Fox product, but this wasnít an option for me. I put a washer between the pulley and shim on each end of the lay shaft then Dremeled out a slot in the A3327 drive hub to accommodate a shorter pin (part # A6406) such as used on the other pulley. The slot should be deep enough to offer a good fit for power transmission purposes and allow free rotation of the lay shaft. This now locks the lay shaft to the hub rather than the spur gear. I would advise putting the slot in the lined up position of the original pin. The next thing is to cut off some of the nub in the middle of the spur gear to allow it to be able to be fitted on the shaft. Only cut off enough to allow the C clip to be installed. Unless long term racing proves different, I think Iím going to like the mod.
The next area was to Dremel the sides of battery tray to fit the battery. Even after doing this I still need to loosen the top deck in order to install the battery. I think Iíll leave it this way for the time being since loosening the top deck is easy with the above deck steering layout and I plan to leave the battery in the car and not exchange batteries anyway. Finally I had to Dremel the top deck to allow access to the battery posts.
When I went to do my initial in car charge the charge leads would not extend down fully onto the battery posts due to interference with the top deck and I was concerned about a possible short circuit between the two posts. I didnít want to Dremel out any more of the top deck in this area so I made an adapter by soldering a male bullet connector to the end of a female bullet barrel and applied heat shrink for protection.
Well, hopefully Iím ready for a shake down cruise next weekend!
The next thing I would suggest is to grind down the axles to the nut to prevent catching on something and breaking a c-hub
Gordon "slow is fast"
Stock Car - Xray T3, Modified Car - Xray T4 '14; Xray X1; Tamiya M-06
My Youtube Channel: search "CARCAR videos" or follow this link https://www.youtube.com/channel/UC7fp4qynjJzlXw13ocDpVAg
Facebook: CARCAR
MaxRain is offline   Reply With Quote
Old 09-13-2010, 01:44 PM   #12249
Default new
so i just bought one of these, maybe shoulda gone w/the team xray t2'008 ?? I don't see Losi selling any more touring cars so the support / parts maybe limited in the future ??
Just comparing this to a company that makes exclusively touring cars ... ur guys's thoughts ?
Im just a local club/for fun racer ..
dmakrc is offline   Reply With Quote
Old 09-13-2010, 02:38 PM   #12250
MaxRain's Avatar
you don't have to worry about parts, there is still a steady supply online..
Facebook: CARCAR
Old 09-13-2010, 02:39 PM   #12251
liljohn1064's Avatar
Trader Rating: 16 (100%+)
Send a message via AIM to liljohn1064 Send a message via MSN to liljohn1064 Send a message via Yahoo to liljohn1064
There is plenty of parts support and at about 1/3 the cost of X-ray.
John Higgins
liljohn1064 is offline   Reply With Quote
Old 09-13-2010, 07:43 PM   #12252
Greg Sharpe's Avatar
Trader Rating: 15 (100%+)
Jason Schreffler approves this message.
If only endurance racing was a thing.
Greg Sharpe is offline   Reply With Quote
Old 09-13-2010, 10:41 PM   #12253
FREAKAH's Avatar
Yeah, I stopped using the two o-rings above the bladder cause it makes my shocks leak.
Second-Hand Racing
RACE WORLD HAWAII
Old 09-14-2010, 06:43 AM   #12254
Yeti35's Avatar
Why do I get the feeling this was in reference to the IIC race where he was leading, tapped a board and was done?
JRXS Type R, I have four of them!! ;) ( Yes, I still have them!!)
22 2.0
22T 2.0
Yeti35 is offline   Reply With Quote
Old 09-14-2010, 06:48 AM   #12255
I am planning too but it is very likely that it will be with a 12th scale only. Unless I have a lot of stuff sorted by then it will only be for one class and the 12th is 10 times the fun.
Powered by Falco
[FS] Team Losi JRXS-Type R squarehead R/C Items: For Sale/Trade 9 07-20-2012 11:59 PM
Team Losi JRXS Type R gtxpro2 R/C Items: For Sale/Trade 18 09-11-2008 07:45 PM
WTB: Team Losi JRXS Type R shifter R/C Items: Wanted to Buy 1 07-03-2008 02:30 PM
Team Losi JRXS TYPE-R John Q R/C Items: Wanted to Buy 1 10-03-2007 05:55 PM
Team Losi JRXS Type R New In Box Canyon R/C Items: For Sale/Trade 0 06-20-2007 03:50 PM
