Team Losi JRXS Type-R
or you could cover each wire individually and the ends where you solder the wire to. I think you should be able to find the right size of heat shrink at any electrical store, even home depot.
I need to redo my wiring anyways so I won't overlook it this time and use heat shrink tubing over each terminal.
motor tabs
or you could do something like this
tekin
After reading ideas, here is how I mounted the tekin RS..
Still have to balance the chassis, and possibly add some weight. Not sure how much, but this what I have done thus far. I am also thinking of adding heat shrink on the B, A, wires. I may also redo the C wire to match B and A
Do you think the wires will interfere with the belt?
When you push down on the belt does it touch the wires?
Trader Rating: 7 (89%+)
I got the speedpassion cirtix combo (ESC + 17.5)
what will be a good roll out to start with.
(losi type r, carpet, indoor, 2 cell lipo, 17.5 motor)
thanks a lot
thanks a lot
I have the same combo and my local track suggests an FDR of 3.5-3.7, regardless temp checks are needed.
I am glad there are companies who still throw love to the Type R! Looks great Mike!
