Old 09-03-2010, 08:42 AM   #12181
One way I was showed for measuring droop, was to measure how much the chassis was raised to the point the tire lifts from the set up board on that corner of the car. In other words, set your car to ride height, check one side at a time, lift chassis front or rear & when tire lifts, measure height chassis was lifted. Adjust droop screw & measure again, then do other side. I have checked how accurate this is & it is very close to how Losi recomends doing it, you just don't have to take off the tires.
flyintrtle is offline   Reply With Quote
Old 09-03-2010, 08:57 AM   #12182
Originally Posted by crusty View Post
dragonfire
i saw your car at the S.A titles and it looked awsome on the track congrats on the win!
did you use the outside or inside hole on the steering rack? Im looking to copy your set up for club racing there.
ps how did you fit twin 25 mmm fans on there i have some AE 25 mm fans but cant get them to fit
cheers chris
any info on top plate mods or any other mods you have done would be awsome also.
a pic of your car could maybe help me
The car was ok but I think it would have been better with an LTC-R body for better steering at those average speeds. I always run the kit setting for ackerman as I find it is the best balance of everything. Running the longer steering links gives more steering but makes it hard to get on power without losing the rear end. You can achieve better results by reducing the rear toe as the rear end bite holds up well even with very little toe.
The twin cooling fans are attached to an "L" shaped bit of graphite plate. There is a heatsink on the motor and I space the fans up just enough to clear the heatsink although I will very likely change this whole setup real soon. My new ESC is giving me spastic low motor temps so I would rather reduce the weight up high and towards the rear of the car.
I run a butchered upper deck (who doesn't with this car) but leave the front upper deck supports in. I have found the removing all the upper deck supports gives the chassis a lot of high speed understeer where as this works much better on average. I have attached a pic of everything so you can have a look for yourself.
Something new I have started doing is running the diff without the brass washer/spacer. I find the diff seems tighter and it seems to help keep the dirt out of the diff. I would be interested to hear if anyone else has found this as well.
Blade: Andro Treiber H 79g AN
FH: Donic Bluefire M3 Max Blk
BH: Donic Bluefire M2 Max Red
Powered by Falco
Dragonfire is offline   Reply With Quote
Old 09-03-2010, 10:08 AM   #12183
js058515's Avatar
The Losi way threw me off because it was different then the way the HUDY manual states. The HUDY manual is the same method that flyinturtle mentioned. I will use Dragons way next since I have setup wheels and should probably make use of them. Thanks for the input.
Last edited by js058515; 09-03-2010 at 03:03 PM. Reason: I must have been drunk when I was typing!
js058515 is offline   Reply With Quote
Old 09-03-2010, 10:59 AM   #12184
crusty's Avatar
thanks heaps dragonfire!
good stuff mate! the mark webber of rc
crusty is offline   Reply With Quote
Old 09-03-2010, 02:58 PM   #12185
Originally Posted by js058515 View Post
The Losi way threw me off because the way mentioned by flynturtle was how I went a out it. I will use Dragons way next since I have setup wheels and should probably make use of them. Thanks for the input.
Just out of curiousity was my way easy to understand for you & did it help? If it did, good
Old 09-03-2010, 03:04 PM   #12186
js058515's Avatar
I edited my original post, not sure what I was saying there. But thank you anyways.
Old 09-03-2010, 03:44 PM   #12187
Okay, just trying to help
Old 09-03-2010, 08:42 PM   #12188
Hardly... He can drive. Hope he gets the support he deserves now that he is clearly the stronger driver in the team for a championship victory.
Powered by Falco
Old 09-03-2010, 10:32 PM   #12189
Here is a explanation I did on another thread with respect to measuring droop using the same method utilized by Losi for the Type R. The only things you need are a flat surface, some droop blocks or something similar to raise the car and a ruler. This is similar to that used by Dragonfire.
Droop Suspension Setting
calvin is offline   Reply With Quote
Old 09-05-2010, 04:54 PM   #12190
js058515's Avatar
Are there any issues that can come up with the motor wires being so close to the diff mount? If they were to touch, will it cause any damage to the esc or motor or both.
Old 09-05-2010, 10:42 PM   #12191
FREAKAH's Avatar
Whoa that's close!
Can you bend the tabs a little?
I'm thinkin a motor spacer but it'll move the motor a couple mm's to the left.
Maybe something as simple as some black electrical tape on the bulkhead.
Second-Hand Racing
RACE WORLD HAWAII
Losi Type-R |Tamiya F104 PRO | Tamiya F103 | Mugen MTX-4R | AE FT GT2
FREAKAH is offline   Reply With Quote
Old 09-05-2010, 10:49 PM   #12192
js058515's Avatar
Yeah, electrical tape will do the trick! I didn't realize it until my brother mentioned it to me. Phew!
Old 09-06-2010, 12:39 AM   #12193
FREAKAH's Avatar
Make sure you use a high quality black tape like 3M's or else it'll just fall off and leave a sticky mess, especially with the heat from the motor.
Second-Hand Racing
RACE WORLD HAWAII
Old 09-06-2010, 09:13 PM   #12194
MaxRain's Avatar
I would use heat shrink if you don't need to change the motor for different classes.
Gordon "slow is fast"
Stock Car - Xray T3, Modified Car - Xray T4 '14; Xray X1; Tamiya M-06
My Youtube Channel: search "CARCAR videos" or follow this link https://www.youtube.com/channel/UC7fp4qynjJzlXw13ocDpVAg
Facebook: CARCAR
MaxRain is offline   Reply With Quote
Old 09-06-2010, 09:19 PM   #12195
js058515's Avatar
I was thinking that too, but I am not quite picturing how I would do it. Any ideas MaxRain?
[FS] Team Losi JRXS-Type R squarehead R/C Items: For Sale/Trade 9 07-20-2012 11:59 PM
Team Losi JRXS Type R gtxpro2 R/C Items: For Sale/Trade 18 09-11-2008 07:45 PM
WTB: Team Losi JRXS Type R shifter R/C Items: Wanted to Buy 1 07-03-2008 02:30 PM
Team Losi JRXS TYPE-R John Q R/C Items: Wanted to Buy 1 10-03-2007 05:55 PM
Team Losi JRXS Type R New In Box Canyon R/C Items: For Sale/Trade 0 06-20-2007 03:50 PM
