Old 08-23-2010, 03:18 PM   #12136
js058515's Avatar
Thank you Ed!
js058515 is offline   Reply With Quote
Old 08-23-2010, 04:14 PM   #12137
Trader Rating: 66 (100%+)
Default Topdeck
Ed, that topdeck sure looks thin between the batt terminal and the servo horn! I run my car also with no uprights, but was experimenting one night and installed the uprights and that is where my topdeck broke. Be carefull!
If you can't race it or sleep with it, it ain't worth having!
Gwoodrc is offline   Reply With Quote
Old 08-23-2010, 05:33 PM   #12138
crabboy's Avatar
Trader Rating: 58 (98%+)
It happened to me the other day in that same thin area, im running lipos that have the wires coming out of the top of the pack and you need to open that area up on the top deck, i see some lipos have the leads coming out from the side, that would be better for us so we could leave the top deck with more thickness in that area.
We have got state titles on this weekend with a few JRXS Rs running, makes a change from only having one Losi running at a meet.
Rhys Marshall.
crabboy is offline   Reply With Quote
Old 08-23-2010, 10:09 PM   #12139
Originally Posted by TryHard View Post
For thoose interested, some pics of my car (excuse the grass!)... really not anything special in terms of layout. Electrics used;
ESC: De-cased Mamaba Max Pro
Servo: Spektrum 6040 (Full size)
Reciever: Spektrum micro Pro
Motor: X12 10.5
PT: MRT iPT
Cells: IP5000 50C
Extra: Castle CC-BEC
Shell's generally a Speed6 LWT, although it's a little beefed up with some internal bracing, and fender mender on the front arches... thankfully it's gonna be able to see out the season!
I never thought of using one big fan like that... Going to buy one right now!
Anyway there must be some trick in your setup as my car has lighter gear but weighs more. Possible your electronics are lighter than you think.
Blade: Andro Treiber H 79g AN
FH: Donic Bluefire M3 Max Blk
BH: Donic Bluefire M2 Max Red
Powered by Falco
Dragonfire is offline   Reply With Quote
Old 08-23-2010, 10:13 PM   #12140
You need to have a close look at packs before you buy em. Packs with bullet plugs right on the very edge of the battery like SMC will work better. Packs like the reedy's have them a long way inboard so you have problems. IP's are somewhere in between.
Powered by Falco
Old 08-24-2010, 12:37 AM   #12141
crabboy's Avatar
I bought some Thunder Power Lipos on some ones recomendation and they are all Deans plugs with 12 gauge wire, cant do anything about that.
Rhys
Rhys Marshall.
Old 08-24-2010, 02:59 AM   #12142
FREAKAH's Avatar
Just noticed Horizon Hobby re-posted the old vid for the Type R earlier this month.
You Tube Type R vid
Hmm....a good sign?
Second-Hand Racing
RACE WORLD HAWAII
Losi Type-R |Tamiya F104 PRO | Tamiya F103 | Mugen MTX-4R | AE FT GT2
FREAKAH is offline   Reply With Quote
Old 08-24-2010, 04:18 AM   #12143
JRXS_chris's Avatar
Great result by Mr. Delves this weekend. I watched him and he was flying! Ed, we'd like to see a setup please!
That's it now for my Nationals season with the XRAY, looking at a top 30 place overall, I'll be very happy with that!
I have to make the decision now on what to race over the winter and into next season. Probably the Losi as it's so much quicker on carpet.
JRXS_chris is offline   Reply With Quote
Old 08-24-2010, 05:30 AM   #12144
jasons56's Avatar
I am getting really excited for our carpet season to start up again and dust off the Type R.
So excited, I bought another. This one came with short arms on it. Would they be out of the question on a rubber tire car?
http://www.youtube.com/user/ZenRacing
jasons56 is offline   Reply With Quote
Old 08-24-2010, 05:49 AM   #12145
Rhys
Thats what I run and they are fine.... Very good batteries.
Powered by Falco
Old 08-24-2010, 10:40 AM   #12146
js058515's Avatar
Which Thunder Powers are you running Dragon? No work needed to top brace with this right?
Old 08-24-2010, 11:19 AM   #12147
That was my problem, I was running a reedy 5000 and the bullets were to close and had to dremel to much material away on the topdeck. Now that I got a new topdeck, I also got a new lipo that has the bullets very close to the edge so there was no need to dremel that area this time
Old 08-24-2010, 12:01 PM   #12148
Default JRXS Type R
If you are looking for one, I have just decided to sell all of my stuff. I never got into the on road stuff, just off road. I have a crap ton of new extra parts and a nice car. Most parts on car are red anodized. My e-mail is ggflyguy@aol.com and I will make you a great deal on everything. I will do roller with or without extra parts or almost ready to run minus battery and steering servo. It currently has a spektrum receiver, GTB ESC, and 17.5 novak brushless. I also have a spare diff and one way, three old but decent bodies, and new parts are still in packages.
New parts
8353 Logo Stickers
6951 Carbide Balls 3/32
9763 FRS Spindles 6 Deg EA3
3018 HD Thrust Bearing Set
9686 Alum .165 Wheel Hexs
6916 3/16 x 3/8 Ball Bearings
2-9762 FR Spindles/Carriers 4 Deg EA3
2-2908 Monster Diff SQR Spring/Screw Set
2-3968 118T/64P Kevlar Spur Gears
3329 42T Spool Pulley and Plate
6931 Bearings
3344 LCD Drive Shaft Set
3319 Diff Outdrive
3070 Tranny Drive Rings
9696 Outer Pivot Block 1 Deg
3317 Diff Tube
3338 RCD Drive Shaft Set
3066 Super Slick Assembly Grease
3328 41T Pulley and Plate
3326 Diff Pulley Set 41&42t
4320 Battery Foam
3970 128t/64p Kevlar Spur
1217 FR Susp Arms
3318 Diff Hub
9759 8 Deg Fr Spindles & Carriers GR
4239 Body Post & Bumper Set (opened)
3039 Diff Drive Rings
ggflyguy is offline   Reply With Quote
Old 08-26-2010, 06:33 AM   #12149
Trader Rating: 68 (100%+)
Are you willing to seperate parts?
SpeedZone Batteries
steve eaves is offline   Reply With Quote
Old 08-26-2010, 09:54 AM   #12150
Trader Rating: 42 (100%+)
Default JRXS-R
I bought one of Greg Sharps cars last winter. I'm not racing RC anymore so it's for sale. Car, parts ,2 bodies, 6 sets of used Jaco blues $185 shipped.
check my ad on here I also have 17.5 and WGT car.
Mike
miket3 is offline   Reply With Quote
[FS] Team Losi JRXS-Type R squarehead R/C Items: For Sale/Trade 9 07-20-2012 11:59 PM
Team Losi JRXS Type R gtxpro2 R/C Items: For Sale/Trade 18 09-11-2008 07:45 PM
WTB: Team Losi JRXS Type R shifter R/C Items: Wanted to Buy 1 07-03-2008 02:30 PM
Team Losi JRXS TYPE-R John Q R/C Items: Wanted to Buy 1 10-03-2007 05:55 PM
Team Losi JRXS Type R New In Box Canyon R/C Items: For Sale/Trade 0 06-20-2007 03:50 PM
