Old 08-10-2010, 04:57 PM   #12076
Keith Billanti's Avatar
Trader Rating: 15 (100%+)
Does anyone still have arms for the JRXS FMC? I gave one of my old sleds to a little buddy of mine- hoping to get him into racing- unfortunately, I also gave all of the parts i had for that car to Kropy at the 07' nats..
Needs a front arm (and spares im sure).. hate to think this is a pile of parts that will never run again..
OUT
Keith Billanti is offline   Reply With Quote
Old 08-10-2010, 07:51 PM   #12077
Greg Sharpe's Avatar
Not only does Horizon have them in stock, but it's not terribly difficult to mount the Type-R arms on the old FMC/MMC/PRO/funnylookingstubbyarmedcar. I still run mine in VTA and when I ran out of short arms.....I used a Makita drill and a Type-R chassis to drill two holes per arm to accommodate the Type-R inner hingepin blocks. I didn't drill the third hole because it overlapped with the existing holes. That's it, ten minute mod, arms for life, happy kid again.
Why don't we endurance race more often?
Greg Sharpe is offline   Reply With Quote
Old 08-11-2010, 12:31 AM   #12078
FREAKAH's Avatar
Originally Posted by MikeXray View Post
Doesn't this setup make the rear a lot wider than the front? the car is not loose?
Yes, it makes the rear wider than the front. Had those hexes on from when I bought it used back in '08, and I never tried anything narrower in the rear as I never really felt the need to. I dunno, maybe the wider rear helps stabilize the Losi's slightly heavy ass.
I also actually ran the setup with the 0 degree rear block for quite a while until recently because of the high track temps, and I probably will go back to the zero rear block when the temps go back down later this year.
And, believe it or not, i'm also using some of my 8+yr old Sorex tires tires from my nitro rubber sedan days. Just need 3-4 laps to scrub off the old rubber to reveal the suprisingly still great rubber underneath.
I think I need to mention that I ran the setup in the "timing enhanced " 17.5 class, and I pretty confident this setup will handle Mod. The track I run on is a tight, slightly dusty, untreated sealed asphalt surface.
Second-Hand Racing
RACE WORLD HAWAII
Losi Type-R |Tamiya F104 PRO | Tamiya F103 | Mugen MTX-4R | AE FT GT2
FREAKAH is offline   Reply With Quote
Old 08-11-2010, 04:59 AM   #12079
DOOD-- i searched Horizon and losi parts house..
I couldnt even find stuff for the R... thanks man!
Keith
OUT
Old 08-11-2010, 07:25 AM   #12080
Keith
You are doing it wrong then. Use the "Parts by vehicle" option. They have tons. I just ordered from there.
AE SC-10
HPI Blitz ESE (17.5 ROAR)
HPI Blitz RTR
HPI E-Firestorm
Traxxas Stampede
Chip73 is offline   Reply With Quote
Old 08-11-2010, 07:25 AM   #12081
Trader Rating: 21 (100%+)
Keith
Let me know if u can't find any arms. I think I may have some yet. Will check my parts box.
Thanks to pops
TLR, Fantom, Horizon, Spektrum, Trackside
Brian L is offline   Reply With Quote
Old 08-11-2010, 08:22 AM   #12082
Trader Rating: 66 (100%+)
Keith
Stormer, a-main, and losi parts house have lots of parts available.
If you can't race it or sleep with it, it ain't worth having!
Gwoodrc is offline   Reply With Quote
Old 08-11-2010, 08:32 AM   #12083
Administrator
Matt M.'s Avatar
Trader Rating: 26 (100%+)
guys, i know this isnt the place to put stuff up for sale, but i found some old type r parts laying around all nip
1, oneway
2, pair of front dog bones
3, 4 front axles
4, 2 lcd rebuild kits
make me an offer, i dont need them
MAtt
Team Tekin-Proline Racing-Motiv-92zero Designs-Jim Neubert Paint Design-LiveRC.com-TFR-Team Dirt Heaven-Gravity RC-Trackside
UNLESS someone like you cares a whole awful lot,nothing is going to get better. It's not. Dr. Seuss
Matt M. is offline   Reply With Quote
Old 08-12-2010, 09:47 AM   #12084
FREAKAH's Avatar
Originally Posted by FREAKAH View Post
Here's my current set-up which is based off of STLNST's 07' Speedworld set-up...
FRONT:
Toe: 0
Ride Height: 5.5mm
Camber: -1
Caster: 4
Droop: 1mm above ride height
Front Pivot: 0
Roll Center: Low
Arm Spacing: Middle
Shock Position: 2
Steering Rack: 2 spindle ackerman: 1
Camber Link: 1
Camber Ball Stud: JR Low
Sway Bar: .040
Drive: Losi Slipper Spool
Pulley: 42
Diff Height: High
Hex Width: .165
Shocks: 40 oil, 56 Piston, 15# Spring, 2 o-ring above stock bladder, no rebound.
REAR:
Toe: 2
Ride Height: 5.5mm
Droop: 2mm above ride height
Camber: -1
Hub: 0
Rear Pivot: 1
Roll Center: .030 shims under blocks
Arm Spacing: Foward
Shock Position: 1
Camber Link: 2/B
Camber Link: Stock
Sway Bar: None
Diff Height: Low
Hex Width: .225
Shocks: 35 oil, 56 piston, 17.5 spring, two o-ring above stock bladder, no rebound.
Tires: Sorex 36R-40R
Track Temp: 130-150 degrees
I very seldom stray from this setup. The latest change I did was change the rear inner camber link position from the #5 hole up to the #2 hole.
Sorry but I need to make a correction.
I used a 41 tooth overdrive spool front pulley instead of the listed 42 tooth.
Second-Hand Racing
RACE WORLD HAWAII
Old 08-13-2010, 05:05 AM   #12085
Not that my simple paint jobs are anything special but I quite like how this body turned out when it was all stickered up. So I though I would post a pic before I destroy it! Hopefully an A final winning design for this weekends big race.
Blade: Andro Treiber H 79g AN
FH: Donic Bluefire M3 Max Blk
BH: Donic Bluefire M2 Max Red
Powered by Falco
Dragonfire is offline   Reply With Quote
Old 08-13-2010, 07:24 AM   #12086
Kwikvdub's Avatar
Trader Rating: 90 (100%+)
Send a message via AIM to Kwikvdub
Ahhh, bright colors. Looks tight!!...... Good luck this weekend!!
I also have a big race this weekend and hoping to put my Losi in the A!!
....... For the rest of you, Happy Racing!!...... Long live Losi Type R!
Alex Valdes
TQRacing / 360 v2 RC Raceway / Team Downgrade Designs
Kwikvdub is offline   Reply With Quote
Old 08-13-2010, 09:49 AM   #12087
It did come out looking good! What type of wing is that on the body? Oh & good luck this weekend!
flyintrtle is offline   Reply With Quote
Old 08-13-2010, 02:39 PM   #12088
drsmooth's Avatar
Trader Rating: 33 (100%+)
Nice job dragonfire. Just got mine ready to go. Now if I can just get the local track to stop canelling their races so I can try her out.
Team Losi JRXS Type-R-jrx-s.jpg   Team Losi JRXS Type-R-jrxsr.jpg   Team Losi JRXS Type-R-ltcr.jpg
Till next time.......
KEEP ON RACING!
drsmooth is offline   Reply With Quote
Old 08-14-2010, 01:00 AM   #12089
FREAKAH's Avatar
Ok, I need a couple more lipos since i'll be running two cars(17.5 "RC"GT & Open). I already have two Fantom 5000 40C and one Thunder Power 5000 40C. I really want to buy more TP manufactured packs like the Fantom and Xcelorin because of their performance and reliability, but I was wondering what else fits. I was kinda eyeing the Intellec IP's with the wire coming out the side.
So anyway, what 5000mah+ / 40C+ packs are you using and what packs do you know fits without dremeling?
Thanks in advance!
Second-Hand Racing
RACE WORLD HAWAII
Old 08-14-2010, 02:48 AM   #12090
Thanks in advance!
I have been told that the new IP's have a new chemical in them that improves their voltage, but it makes them more unstable. How long do you want them for?
Powered by Falco
[FS] Team Losi JRXS-Type R squarehead R/C Items: For Sale/Trade 9 07-20-2012 11:59 PM
Team Losi JRXS Type R gtxpro2 R/C Items: For Sale/Trade 18 09-11-2008 07:45 PM
WTB: Team Losi JRXS Type R shifter R/C Items: Wanted to Buy 1 07-03-2008 02:30 PM
Team Losi JRXS TYPE-R John Q R/C Items: Wanted to Buy 1 10-03-2007 05:55 PM
Team Losi JRXS Type R New In Box Canyon R/C Items: For Sale/Trade 0 06-20-2007 03:50 PM
