Old 08-09-2010, 07:06 AM   #12061
Trader Rating: 66 (100%+)
I haven't raced in 7 weeks because i've been looking for a topdeck, mine broke. Finally my lhs found one for me on a locator from another hobby shop going out of buisiness, now I can put it back together and start racing again!
If you can't race it or sleep with it, it ain't worth having!
Gwoodrc is offline   Reply With Quote
Old 08-09-2010, 07:49 AM   #12062
js058515's Avatar
Forgive me as I am new to the Type R, but are any of you guys looking at the Litemodz CVD as an upgrade for the Type R? Is it even an option now or in the future?
js058515 is offline   Reply With Quote
Old 08-09-2010, 07:58 AM   #12063
The factory LCD's and RCD's are great. I wouldn't bother,
Blade: Andro Treiber H 79g AN
FH: Donic Bluefire M3 Max Blk
BH: Donic Bluefire M2 Max Red
Powered by Falco
Dragonfire is offline   Reply With Quote
Old 08-09-2010, 09:39 AM   #12064
vabroom's Avatar
Originally Posted by JRXS_chris View Post
While they're at it can we have a nice Lipo battery tray with lug holes made in CF?
You can try this, if you can find it:
http://www.speedtechrc.com/store/ebp...id=547&id=6662
RC racing is still trying to prove that two solid objects can be in the same place, at the same time.
vabroom is offline   Reply With Quote
Old 08-09-2010, 09:44 AM   #12065
Yeti35's Avatar
I have one of those that came with a car I bought from someone here. I never used it.
JRXS Type R, I have four of them!! ;) ( Yes, I still have them!!)
22 2.0
22T 2.0
Yeti35 is offline   Reply With Quote
Old 08-09-2010, 01:03 PM   #12066
drsmooth's Avatar
Trader Rating: 33 (100%+)
I know it's after the fact, but I bought my top plate here.
http://www.horizonhobby.com/Products...rodID=LOSA4304
Till next time.......
KEEP ON RACING!
drsmooth is offline   Reply With Quote
Old 08-09-2010, 03:14 PM   #12067
vabroom's Avatar
Wow, they are starting to make replacement parts again!?! Time to blow the dust off and get ready for carpet.
Old 08-09-2010, 03:25 PM   #12068
Anyone have a setup sheet for medium, tight asphalt, rubber tires? Need a starting point. Bought the car used, added electronics and am racing. No idea current setup, has issues with spin out, looks like chassis in rear may be hitting occasionally and causing spin out. Want to set car to baseline and start new adjustments with known measurements.
AE SC-10
HPI Blitz ESE (17.5 ROAR)
HPI Blitz RTR
HPI E-Firestorm
Traxxas Stampede
Chip73 is offline   Reply With Quote
Old 08-09-2010, 05:35 PM   #12069
Try_Hard has a setup posted a page or so back. That would be a good starting point.
Powered by Falco
Old 08-09-2010, 06:49 PM   #12070
Chip, I occasionally have problems with the rear of the car spinning out & having no traction out of corners. It has been my experiance is that it's usually becase the rear diff needs to be at the minimum cleaned, balls & rings cleaned, along with pulley itself. When those are clean with a fresh application of diff grease, my rear end is as planted as the best of them!
As far as setups are concerned, you can never go wrond with any of Mike Haynes set ups!
flyintrtle is offline   Reply With Quote
Old 08-09-2010, 07:25 PM   #12071
I will start with the diff. Fortunetly I just purchased everything to rebuild the diffs.
AE SC-10
HPI Blitz RTR
HPI E-Firestorm
Traxxas Stampede
Old 08-10-2010, 02:44 AM   #12072
FREAKAH's Avatar
Here's my current set-up which is based off of STLNST's 07' Speedworld set-up...
FRONT:
Toe: 0
Ride Height: 5.5mm
Camber: -1
Caster: 4
Droop: 1mm above ride height
Front Pivot: 0
Roll Center: Low
Arm Spacing: Middle
Shock Position: 2
Steering Rack: 2 spindle ackerman: 1
Camber Link: 1
Camber Ball Stud: JR Low
Sway Bar: .040
Drive: Losi Slipper Spool
Pulley: 41 overdrive spool
Diff Height: High
Hex Width: .165
Shocks: 40 oil, 56 Piston, 15# Spring, 2 o-ring above stock bladder, no rebound.
REAR:
Toe: 2
Ride Height: 5.5mm
Droop: 2mm above ride height
Camber: -1
Hub: 0
Rear Pivot: 1
Roll Center: .030 shims under blocks
Arm Spacing: Foward
Shock Position: 1
Camber Link: 2/B
Camber Link: Stock
Sway Bar: None
Diff Height: Low
Hex Width: .225
Shocks: 35 oil, 56 piston, 17.5 spring, two o-ring above stock bladder, no rebound.
Tires: Sorex 36R-40R
Track Temp: 130-150 degrees
I very seldom stray from this setup. The latest change I did was change the rear inner camber link position from the #5 hole up to the #2 hole.
Second-Hand Racing
RACE WORLD HAWAII
Losi Type-R |Tamiya F104 PRO | Tamiya F103 | Mugen MTX-4R | AE FT GT2
FREAKAH is offline   Reply With Quote
Old 08-10-2010, 06:50 AM   #12073
FRONT:
Toe: 0
Ride Height: 5.5mm
Camber: -1
Caster: 4
Front Pivot: 0
Roll Center: Low
Arm Spacing: Middle
Shock Position: 2
Camber Link: 1
Sway Bar: .040
Pulley: 42
Diff Height: High
Hex Width: .165
REAR:
Toe: 2
Ride Height: 5.5mm
Camber: -1
Hub: 0
Rear Pivot: 1
Arm Spacing: Foward
Shock Position: 1
Camber Link: 2/B
Camber Link: Stock
Sway Bar: None
Diff Height: Low
Hex Width: .225
Thanks. I am rebuilding the car this week with ne electronics so I will reset and give this a try. I am very new to on road so it is a OJT thing for me.
AE SC-10
HPI Blitz RTR
HPI E-Firestorm
Traxxas Stampede
Old 08-10-2010, 07:03 AM   #12074
MikeXray's Avatar
Trader Rating: 73 (100%+)
FRONT:
Toe: 0
Ride Height: 5.5mm
Camber: -1
Caster: 4
Front Pivot: 0
Roll Center: Low
Arm Spacing: Middle
Shock Position: 2
Camber Link: 1
Sway Bar: .040
Pulley: 42
Diff Height: High
Hex Width: .165
REAR:
Toe: 2
Ride Height: 5.5mm
Camber: -1
Hub: 0
Rear Pivot: 1
Arm Spacing: Foward
Shock Position: 1
Camber Link: 2/B
Camber Link: Stock
Sway Bar: None
Diff Height: Low
Hex Width: .225
Doesn't this setup make the rear a lot wider than the front? the car is not loose?
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 08-10-2010, 08:45 AM   #12075
MikeR's Avatar
Trader Rating: 15 (100%+)
I am sure you will post up once that Lipo Top plate comes in right?
Top Plate
Yes- testing is going well. Working on v2 prototype and should go into production next week Should be in the shop later this month!
www.exotekracing.com ☆ASSOCIATED☆DURANGO☆HPI☆HB RACING☆KYOSHO☆LOSI/TLR☆SERPENT☆TAMIYA☆XRAY☆
A picture with your post, when trouble shooting, will probably get more rctech help than without...
MikeR is offline   Reply With Quote
[FS] Team Losi JRXS-Type R squarehead R/C Items: For Sale/Trade 9 07-20-2012 11:59 PM
Team Losi JRXS Type R gtxpro2 R/C Items: For Sale/Trade 18 09-11-2008 07:45 PM
WTB: Team Losi JRXS Type R shifter R/C Items: Wanted to Buy 1 07-03-2008 02:30 PM
Team Losi JRXS TYPE-R John Q R/C Items: Wanted to Buy 1 10-03-2007 05:55 PM
Team Losi JRXS Type R New In Box Canyon R/C Items: For Sale/Trade 0 06-20-2007 03:50 PM
