Old 06-26-2010, 12:57 AM   #11926
I am wondering if any of the settings from the original Jrxs can be transitioned to the Type-r.
I drive on a rough outdoor asphalt track, pretty wide open, pretty decent grip for what it is. I have used the original jrxs there for a few years and have a setup I am pretty comfy with. Now that I have finally upgraded to a type-r are there any settings I can transfer over to the type-r?
I figure ride height/gearing should be a pretty safe bet - any comments on other settings to transfer over or should I just try a recommended asphalt setup?
TheSteve is offline   Reply With Quote
Old 06-26-2010, 10:25 AM   #11927
It shouldn't be a problem to just roll them over although the type r will be different it won't be a huge change.
Blade: Andro Treiber H 79g AN
FH: Donic Bluefire M3 Max Blk
BH: Donic Bluefire M2 Max Red
Powered by Falco
Dragonfire is offline   Reply With Quote
Old 06-26-2010, 06:08 PM   #11928
FREAKAH's Avatar
Originally Posted by FREAKAH View Post
So while changing out one of my spindle/hubs because of an oblong hole, when I press the bearing into the new spindle/hub it's very tight. It was like that on the other hubs that I changed but this one seems a bit tighter. It's making the bearing bind slightly on the shaft.
Anyone else notice that with the replacement parts?
Maybe the moulds are wearing down(is that possible?)?
Well, I tried a trick the 1/8 on-roaders supposedly do to free up the hinge pins in the suspension arms and it worked! I pushed both bearings in the hub and I then slowly heated the hub evenly with a heat gun till it was slightly hot to the touch and then let cool. I guess heating the plastic let's it expand and conform to the bearing. No more binding bearings! Worked like a charm.
Second-Hand Racing
RACE WORLD HAWAII
Losi Type-R |Tamiya F104 PRO | Tamiya F103 | Mugen MTX-4R | AE FT GT2
FREAKAH is offline   Reply With Quote
Old 06-27-2010, 04:29 AM   #11929
BennyBagems's Avatar
Trader Rating: 15 (100%+)
What brand bearings are you guys using to replace the ones in the kit?
Where is the best place to get them from?
BMAX 4 III - YZ-2 - S350BE-1
Ryper Hobbies - AKA - Arrowmax Tools - Yokomo Australia
Vice President GOMCC - http://www.gomcc.com.au
BennyBagems is offline   Reply With Quote
Old 06-28-2010, 12:20 PM   #11930
Boca Bearing - wwwdotbocabearingdotcom wide variety of sealed bearings etc. I sue them to replace my brushkess motor bearigns and helicopter shaft bearings
wdford is offline   Reply With Quote
Old 06-28-2010, 01:54 PM   #11931
YmeBP's Avatar
Trader Rating: 32 (100%+)
I've been using Avid's (http://www.avidrc.com/) steel and ceramics for my electric and gas cars and they've been great!
www.skyrocketracing.com quality RC gear!
http://www.rctech.net/forum/racing-forum/555071-2011-skyrocket-invitational-blue-diamond-raceway-october-15-16-a.html <- Great race!
YmeBP is offline   Reply With Quote
Old 07-04-2010, 09:29 PM   #11932
J@UNE's Avatar
I took my type-R out of retirement today. It was my first time on asphalt and the car was great!!!
Now, does anybody have pics of Lucas Urbain top deck from the world?
Jon Gagnon
DirtTrax - Team FLR
J@UNE is offline   Reply With Quote
Old 07-05-2010, 07:43 AM   #11933
YmeBP's Avatar
Some of the new parts have a tighter fit I've noticed that w/ the steering knuckles. The reason you may be binding is becuase your bearing is misaligned. see what you can do about pressing the bearing in straight and flat. It should spin freely even with a tight fit.
Old 07-05-2010, 08:29 AM   #11934
Its funny you mention that because I went down the road of working with the super flexy deck I made and then used the chassis setup to regain as much as I could of what you loose. The results were quite good. I found I could match or better the pace of some of the fast local drivers at my club with tyres that are historically 0.3-.05 sec a lap off the pace. I was quite surprised how good it could be. The best test will be in a few weeks time at Whalan where the track favors more of what I lost and less of what I have gained.
Powered by Falco
Old 07-05-2010, 11:12 PM   #11935
metalracer2's Avatar
Trader Rating: 20 (100%+)
Send a message via AIM to metalracer2
I'm selling my Type r, if any one is interested let me know
Losi Jrxs Type R
First you forget names, then you forget faces. Next you forget to pull your zipper up and finally, you forget to pull it down.
Team BOOZE CRUISEN!
Rides....
AE B4.1W AE T4.1
metalracer2 is offline   Reply With Quote
Old 07-06-2010, 08:40 AM   #11936
Trader Rating: 67 (100%+)
With all the talk of gear diffs will anyone come up with something for the type r.
steve eaves is offline   Reply With Quote
Old 07-06-2010, 09:01 AM   #11937
Greg Sharpe's Avatar
I sure hope so, but looking at the space we have to work with, I also highly doubt it. Somebody please prove me wrong......
If only endurance racing was a thing.
Greg Sharpe is offline   Reply With Quote
Old 07-06-2010, 09:49 AM   #11938
YmeBP's Avatar
Adding a gear diff to the Type-R wouldn't be that hard at all. It would require a new eccentric to be bigger than the current one but that's about it. The other option is to use small gears, like the 1/12 or 1/16 scale steel gears i've seen in past lives.
I'm guessing the interest in gear diffs is to play w/ oils to slow the diff action without the slip associated w/ balls. I'm wondering what that would feel like on an electric car. I know what it feels like on my nitro car but electric doesn't have the weight nitro does, any one driven an electric w/ fluid filled diff?
All in all the diffs are my biggest pain point right now . I've taken to cleaning and rebuilding them once a week now because my performance is SOOOO much better w/ a clean smooth diff than w/ a gritty one. I have a mcmaster thrust and a set of ceramic balls so i don't replace any parts just sand my rings flat on 600 or 400 grit sand paper clean thoroughly with denatured alcohol and rebuild w/ green slime on the balls and black grease on the thrust. I've also made it a habit to check the bearing in the diff once a week too. For whatever reason the losi ones seem to die a quick death.
A though just struck me ... anyone have an old losi hydradrive laying around they wish to donate? I wonder if we could retrofit that. If memory serves isn't rather small?
Old 07-06-2010, 09:50 AM   #11939
It will become a possibility if the revised chassis layout works out to be faster than the current layout.
Powered by Falco
Old 07-06-2010, 10:01 AM   #11940
I will look,i have some old stuff stored away,i would like to try a gear diff-At Novak this year in 17.5 i was tq until the last round ,which i was on a tq pace again when my diff let go-so it dropped me to 2nd maybe the durability of the gear diff would be the way to go.
[FS] Team Losi JRXS-Type R squarehead R/C Items: For Sale/Trade 9 07-21-2012 12:59 AM
Team Losi JRXS Type R gtxpro2 R/C Items: For Sale/Trade 18 09-11-2008 08:45 PM
WTB: Team Losi JRXS Type R shifter R/C Items: Wanted to Buy 1 07-03-2008 03:30 PM
Team Losi JRXS TYPE-R John Q R/C Items: Wanted to Buy 1 10-03-2007 06:55 PM
Team Losi JRXS Type R New In Box Canyon R/C Items: For Sale/Trade 0 06-20-2007 04:50 PM
