Old 05-16-2010, 08:36 PM   #11761
Mugen10's Avatar
Send a message via Yahoo to Mugen10 Send a message via Skype™ to Mugen10
I have never had that problem.
Central Kentucky Racing
Xray T4
Mugen10 is offline   Reply With Quote
Old 05-16-2010, 08:51 PM   #11762
L.Fairtrace's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to L.Fairtrace
Originally Posted by BennyBagems View Post
My car performed well yesterday, felt nice and consistent, still has some push which I am struggling to eliminate. One problem I keep having is the LCDs keep chewing up, they seem to wear the rubber seal that hold the pins in, then the pin flies out, I have brand new front c-hubs, so they shouldn't be a problem.
Does anyone else have this problem? I'm going through rebuild kits like they are going out of fashion.
Are you using the losi shrink tube? The thick clear stuff? And also are you grinding out the inner part of the c hub so they clear ? Cause in 2.5 years of running this car I never once had a problem with lcds and I would run them basically untouched for months at a time or until I had a problem.
T.O.P Racing - Awesomatix USA - EaMotorsports - BSR Racing Tires - Orca - TQ Wire - Solaris Racing Tires - Side Piece Racing
Horsham RC. Where champions practice Failing. I'm your everything.....
L.Fairtrace is offline   Reply With Quote
Old 05-16-2010, 09:14 PM   #11763
Mike Haynes's Avatar
Sounds like your using too long of a screw in the bottom of the knucle.
Team Associated - Reedy Power - Sweep - Protoform - TQ Wire - Lacher paint
Mike Haynes is offline   Reply With Quote
Old 05-16-2010, 09:25 PM   #11764
BennyBagems's Avatar
Trader Rating: 15 (100%+)
I'm the only one running losi at our track unfortunately.
I'll try a shorter screw in the bottom and i have a set of hubs that have been dremeled out, will give them a try.
BMAX 4 III - YZ-2 - S350BE-1
Ryper Hobbies - AKA - Arrowmax Tools - Yokomo Australia
Vice President GOMCC - http://www.gomcc.com.au
BennyBagems is offline   Reply With Quote
Old 05-16-2010, 10:10 PM   #11765
metalracer2's Avatar
Trader Rating: 20 (100%+)
Send a message via AIM to metalracer2
what does the type r go for used?
First you forget names, then you forget faces. Next you forget to pull your zipper up and finally, you forget to pull it down.
Team BOOZE CRUISEN!
Rides....
AE B4.1W AE T4.1
metalracer2 is offline   Reply With Quote
Old 05-16-2010, 10:14 PM   #11766
YmeBP's Avatar
Trader Rating: 32 (100%+)
Looks like we are going to have some decent Type-R representation at the NC State race!
I'll keep you guys posted on our results !!
www.skyrocketracing.com quality RC gear!
http://www.rctech.net/forum/racing-forum/555071-2011-skyrocket-invitational-blue-diamond-raceway-october-15-16-a.html <- Great race!
YmeBP is offline   Reply With Quote
Old 05-16-2010, 10:30 PM   #11767
I picked mine up on these forums for $190 posted to Aus.
Old 05-19-2010, 05:09 PM   #11768
TryHard's Avatar
Well, quick report back from the past weekend... sufice to say, not the most inauspicous start with the new car.. but more down to a simple lack of time with it than anything else. By the time we got our heads round the issues, it was finals times, so a bit late... but the lap times were there
Anyway, ended up on the following setup which should be a pretty good base to work on for the rest of the season. Pushes a little into the corners at the moment, but have full saturday of testing planned, so should be able to dial that out.
Ed
Old 05-19-2010, 06:55 PM   #11769
Ed,
Id advise going to the #1 location on the steering rack, and put a 1 degree front pivot on, you will be very happy with the results
Old 05-19-2010, 09:47 PM   #11770
Default JR verse Non JR link
Hi there.
I'm sure it has been debated at length else where in this thread,
but can you guys give me the theory/explaination of JR verse NonJR top links.Longer and lower or shorter and taller top outter links.
and why,if so, these roll center changes effect the JRXS-R differently to other chassis.
Thanks in advance.
JRX-S, 2X JRXS-R, NTC3, X1-CR, RC18T
Fastredrover is offline   Reply With Quote
Old 05-20-2010, 01:01 AM   #11771
FREAKAH's Avatar
Ed
Have you tried stiffer springs. The Losi seems to like stiffer springs compared to most other cars.
Second-Hand Racing
RACE WORLD HAWAII
Losi Type-R |Tamiya F104 PRO | Tamiya F103 | Mugen MTX-4R | AE FT GT2
FREAKAH is offline   Reply With Quote
Old 05-20-2010, 01:09 AM   #11772
Pablo Diablo's Avatar
Send a message via Skype™ to Pablo Diablo
Originally Posted by Fastredrover View Post
Hi there.
Thanks in advance.
My opinion: by taking off your JR link you have a link so short that you get a lot of camber gain. This is probably why those who like the standard link like it. Normally shorter links give more reactivity, less roll and a bit less mid corner grip. But we all know the losi doesn't always follow whats normal.
I have found that I get more overall front grip with the JR link. I think a lot has to do with the conditions though. In OZ we normally run in low grip asphalt. In the USA I am told there can be so much grip that marshals have to be carefull not to lose their shoes! Most people from the US seem to say that running a standard link increases steering.
Paul H
Losi Type R | Xray T3 | CRC Gen XL | CRC Gen X 10 ME(Messiah Edition) | Black Diamond
www.FlyingFoxRC.com | Advanced Electronics | Team CRC | Factory Messiah
Pablo Diablo is offline   Reply With Quote
Old 05-20-2010, 03:42 AM   #11773
JRXS_chris's Avatar
Ed, try a thicker sway on the rear. I had a nightmare last year running the type r in the nats. There was no-one running one so gave up on it for this season.
JRXS_chris is offline   Reply With Quote
Old 05-20-2010, 05:13 PM   #11774
Do any of you Aus guys have a nice setup for low grip asphalt?
Old 05-21-2010, 05:05 AM   #11775
TryHard's Avatar
Cheers for the suggestions guys, I'll be adding them to the rather long list of items to test this weekend! Still learning the car, plenty to go through
Ed
[FS] Team Losi JRXS-Type R squarehead R/C Items: For Sale/Trade 9 07-21-2012 12:59 AM
Team Losi JRXS Type R gtxpro2 R/C Items: For Sale/Trade 18 09-11-2008 08:45 PM
WTB: Team Losi JRXS Type R shifter R/C Items: Wanted to Buy 1 07-03-2008 03:30 PM
Team Losi JRXS TYPE-R John Q R/C Items: Wanted to Buy 1 10-03-2007 06:55 PM
Team Losi JRXS Type R New In Box Canyon R/C Items: For Sale/Trade 0 06-20-2007 04:50 PM
