Old 04-01-2010, 08:05 AM   #11581
j.d.roost's Avatar
Trader Rating: 28 (100%+)
Originally Posted by Kwikvdub View Post
Anyone know where I can get the cooling fans that fit on top of the motor??........ Love to run the dual fans of the car pictured above.
Thanks!!
Alex,I just ordered these.
http://cgi.ebay.com/Muchmore-Racing-...item335b41a5a6
Just about burnt up that 21.5 last weekend .
j.d.roost is offline   Reply With Quote
Old 04-01-2010, 08:17 AM   #11582
Kwikvdub's Avatar
Trader Rating: 89 (100%+)
Send a message via AIM to Kwikvdub
Originally Posted by Greg Sharpe View Post
The bulkheads are made for any 25mm fan, which I think MuchMore makes, ask Kitchen, he's got some.
Thanks for the info Guys!!.......... Just ordered 2 fans from Stormer's and some spur gears....... Getting my Type R in tip top shape and ready for outdoor action.
Alex Valdes
TQRacing / 360 v2 RC Raceway
Kwikvdub is offline   Reply With Quote
Old 04-01-2010, 08:43 AM   #11583
Greg Sharpe's Avatar
Trader Rating: 15 (100%+)
Originally Posted by Evoracer View Post
Hey All, looking to get a JRXSR and without going through this LARGE thread could anybody provide some quick links to the mods or part changes you'd suggest before I run it. I'll be racing VTA on outdoor concrete with the 25.5/Havoc Pro and 2s Lipo. I'd like to use the ball diff and spool in front as they seem to do best on our track designs. The one way is useless. I'm using the Zippy 4000 hardcase packs which are pretty small and have the banana and balance plugs on top at one end.
Already aware of the Flying Fox and PRS parts but interested more in the factory parts that probably should be upgraded or specific mods that would make it stronger or easier to work on. Thanks !!!
This is one of the rare cars that doesn't need much of anything to make it 100% race ready. Beyond the Flyingfox layshaft, a couple McMasterCarr thrust bearing(s) for the diff(s) and maybe a set of swaybars is all I've ever needed for asphalt, carpet, TC, VTA, etc.... Great all purpose car that' inexpensive to run. But if you really want to make the car faster, you'll have to anodize all the aluminum iridescent green.
FS: Awesomatix A800A $325 shipped
Greg Sharpe is offline   Reply With Quote
Old 04-01-2010, 12:27 PM   #11584
YmeBP's Avatar
Trader Rating: 32 (100%+)
That is the kicker, years after the car was introduced you STILL don't need much to be competitive! I'd +1 greg, the mcmaster thrusts reduce maintenance (same for ANY touring car diff tho), and the sway bars help you slow weight xfer, other than that the only thing i'd even suggest would be stainless screws because they look nice and a fifth body mount becuase it keeps the body from cracking at the wheel wells better (comes in the kit install it!!). Oh and a parma hard bumper it helps save your front end.
www.skyrocketracing.com quality RC gear!
http://www.rctech.net/forum/racing-forum/555071-2011-skyrocket-invitational-blue-diamond-raceway-october-15-16-a.html <- Great race!
YmeBP is offline   Reply With Quote
Old 04-01-2010, 01:21 PM   #11585
j.d.roost's Avatar
+1
You need to post a pic of that thing Sharpe.
Do you think I should pop on the bars for Jackson?
Old 04-01-2010, 01:26 PM   #11586
Thanks!!
hi,
found these fan setups while browsing the speedtech website:
speedtechrc.com/store/ebproduct.asp?catmainid=792
i was personally looking at the r1 wurks pro dual.
platypus_s13 is offline   Reply With Quote
Old 04-01-2010, 01:28 PM   #11587
Trader Rating: 24 (100%+)
Well if Greg Sharpe says the car has to be green then so be it !! Just bought one off the classifieds. So where's your source for anodising and what kind of money we talkin. Let me know by PM if you'd like. And yes...I'm serious. I'm gonna hold you to that "faster" comment though.
Evoracer is offline   Reply With Quote
Old 04-02-2010, 07:47 AM   #11588
Trader Rating: 10 (92%+)
whats so special about the flyingfox layshaft?
captain stacker is offline   Reply With Quote
Old 04-02-2010, 08:07 AM   #11589
Trader Rating: 68 (100%+)
It allows you to run bigger lipos without modding and you can run any spur
steve eaves is offline   Reply With Quote
Old 04-02-2010, 08:26 AM   #11590
thanks for the quick reply
what is the biggest lipo you can fit with the standard losi set up?
And with the standard layshaft, are you only restricted in using losi spurs?
Old 04-02-2010, 09:29 AM   #11591
Not sure what the absolute biggest Lipo is, but I ran the TP 5000mAh 40C with 1mm spacers inside the pulleys on the stock layshaft until I got the FlyingFox layshaft.
The stock layshaft and right side pulley only accept Losi spurs (which are great IMO), but you can add a PRS spur gear adaptor to run any other spur. But quite frankly, the FlyingFox layshaft is just plain better because on top of allowing you to run any spur and fit bigger lipos, it's built in pulley also runs a bit more true.
Old 04-02-2010, 09:40 AM   #11592
+1
If I remember correctly, Fairtree and the Schreffinator would run a front swaybar at Jackson, and I always had good results with just a front bar as well (although that was mostly in VTA).
Notice the multi-colored shocks. Re-anodizing parts changes their dimensions ever so slightly, and my all green shock setup wouldn't stay threaded together.
Old 04-02-2010, 10:29 AM   #11593
j.d.roost's Avatar
Looks even better in person!
Sweeeet.
Why are you showing everyone your super secret/super fast 2wd setup?
Old 04-02-2010, 11:05 AM   #11594
Greg, thanks for the PM. The green looks great !!! I do actually have a legitimate reason for interest in that color.
Although if it makes you feel better I can tell everybody that you said it would make me faster !!
Old 04-02-2010, 12:15 PM   #11595
YmeBP's Avatar
Takes a good bit of slop out of that part of the car too. If you run mod you can use more than 2 screws to prevent your spur from flexing under load.
[FS] Team Losi JRXS-Type R squarehead R/C Items: For Sale/Trade 9 07-20-2012 11:59 PM
Team Losi JRXS Type R gtxpro2 R/C Items: For Sale/Trade 18 09-11-2008 07:45 PM
WTB: Team Losi JRXS Type R shifter R/C Items: Wanted to Buy 1 07-03-2008 02:30 PM
Team Losi JRXS TYPE-R John Q R/C Items: Wanted to Buy 1 10-03-2007 05:55 PM
Team Losi JRXS Type R New In Box Canyon R/C Items: For Sale/Trade 0 06-20-2007 03:50 PM
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
liljohn1064
