Old 03-12-2010, 10:52 AM   #11551
Pablo Diablo's Avatar
Send a message via Skype™ to Pablo Diablo
Originally Posted by YmeBP View Post
On behalf of Flying Fox and Skyrocket thanks for all your patience and support!
-Tory
Tory, I would like to thank you for your patience during the long wait for the new batch. For anyone who has had to wait, thankyou and please understand that the delays have been in no way the fault of Skyrocket.
We are now producing parts in much larger numbers to prevent these delays from happening. The Spools and Outdrives are not far away and the new outdrives will be great. So far in testing, none have failed. They can be used in the diffs as well and should be slightly less in cost than the origional Losi parts.
Paul H
Losi Type R | Xray T3 | CRC Gen XL | CRC Gen X 10 ME(Messiah Edition) | Black Diamond
www.FlyingFoxRC.com | Advanced Electronics | Team CRC | Factory Messiah
Pablo Diablo is offline   Reply With Quote
Old 03-14-2010, 09:09 PM   #11552
rallyebmx's Avatar
Trader Rating: 21 (100%+)
I switched my front diif to be low and it seems like my main belt is now rubbing on the chassis right as it leaving the slot that is cut in the chassis for pulley clearance. Am I doing something wrong or do i have to change something
I run foam carpet with no traction compound. I also run the stock 42 pulleys
cpaurl
rallyebmx is offline   Reply With Quote
Old 03-14-2010, 09:14 PM   #11553
No that sounds right to me. I had to file the edge of the slot to clear the belt.
Paul H
Old 03-14-2010, 09:27 PM   #11554
rallyebmx's Avatar
Ah thanks. I did start to dremel it, but figured i'd ask. Your spool dropped me almost a 1/2 second per lap consistently on the not so common foam tire with no traction compound set up. Spools are now the must have at the track!
cpaurl
Old 03-14-2010, 09:58 PM   #11555
Greg Sharpe's Avatar
Trader Rating: 15 (100%+)
Can I have the full size image of your avatar?
Why don't we endurance race more often?
Greg Sharpe is offline   Reply With Quote
Old 03-14-2010, 10:38 PM   #11556
rallyebmx's Avatar
Ha- she was claiming '7 foot woman'
cpaurl
Old 03-14-2010, 10:54 PM   #11557
YmeBP's Avatar
Trader Rating: 32 (100%+)
I had to file mine as well. I'm running foam on carpet w/ 2 diffs and had to file front and back.
On the chassis I run outside on asphalt i file it a little more than the foam ones to allow for rocks.
www.skyrocketracing.com quality RC gear!
http://www.rctech.net/forum/racing-forum/555071-2011-skyrocket-invitational-blue-diamond-raceway-october-15-16-a.html <- Great race!
YmeBP is offline   Reply With Quote
Old 03-15-2010, 11:16 AM   #11558
Kwikvdub's Avatar
Trader Rating: 91 (100%+)
Send a message via AIM to Kwikvdub
I went to order some parts on Losi House and did not see a menu for Type R parts........ Did they stop making or carring parts??......... Any other places have parts??....... I orderd from Stormer's and got what I needed but wanted to know of other places.
........Feels good to get back on board with Losi.......
Alex Valdes
TQRacing / 360 v2 RC Raceway / Team Downgrade Designs
Kwikvdub is offline   Reply With Quote
Old 03-15-2010, 11:21 AM   #11559
YmeBP's Avatar
http://www.losipartshouse.com/servle...e-R/Categories
But you can also order them from me i have a ton of stuff in stock. I have to edit my website and put all the parts online. These stupid MAP pricing rules from horizon are getting on my nerves too because i can't stay competitive with ebay people.
Old 03-15-2010, 02:11 PM   #11560
Kwikvdub's Avatar
Thanks Tory!!
Alex Valdes
Old 03-21-2010, 02:02 PM   #11561
Trader Rating: 66 (100%+)
Default Camber?
We were playing with different cars on the setup board last night and noticed that the losi has lots of camber gain through the suspension travel, I see that most peoples setups have equal camber front and rear. Would it gain any steering by reducing some camber on the front from 2 to 1.5 so that more of the tire would be in contact with the carpet in the turns? Running rubber tire, 17.5. Thanks, Greg.
Gwoodrc is offline   Reply With Quote
Old 03-21-2010, 07:15 PM   #11562
Camber gain depends on setup. You can have lots or nearly none depending on the angle and length of your top links. Running a standard front top link will always give a lot of gain.
I like to run a lot of gain and very little static camber, sometime as low as only 3/4 degree neg camber. This works well for me on med/high bit asphalt. It also is the only way to get good even tyre wear.
Paul H
Old 03-22-2010, 09:41 PM   #11563
MaxRain's Avatar
I am in the same boat as Pablo, I run around 1 degree of static camber in the front and almost none in the rear. The result is even tire wear, and jaco blue's last a long time!! Also, download the roll centre calculator, set your static roll centre so that it sits right above ground. If you have to adjust ride height, do it. You will notice that the car responds well.
Good luck
Gordon "slow is fast"
Stock Car - Xray T3 EU Rubber, Modified Car - Xray T4 '14; Xray X1; Tamiya M-06
My Youtube Channel: search "CARCAR videos" or follow this link https://www.youtube.com/channel/UC7fp4qynjJzlXw13ocDpVAg
Facebook: CARCAR
MaxRain is offline   Reply With Quote
Old 03-23-2010, 08:51 PM   #11564
Radron's Avatar
Trader Rating: 36 (100%+)
Send a message via Yahoo to Radron
If anyones looking, I have a very nice,very FAST rubber set-up,RACE READY. Just add TX & RX......
I have some Dr. bills to pay,so she sadly has to go.
http://www.rctech.net/forum/r-c-item...ml#post7150891
Radron is offline   Reply With Quote
Old 03-25-2010, 07:42 PM   #11565
Trader Rating: 42 (100%+)
Default Tire compound for rubber
Which tire compound do you prefer for rubber carpet.
would you use a different compound for a high bite/ vs a low bite track ?
Is there any certain compound you wouldn't use and why ?
Mike
miket3 is offline   Reply With Quote
[FS] Team Losi JRXS-Type R squarehead R/C Items: For Sale/Trade 9 07-21-2012 12:59 AM
Team Losi JRXS Type R gtxpro2 R/C Items: For Sale/Trade 18 09-11-2008 08:45 PM
WTB: Team Losi JRXS Type R shifter R/C Items: Wanted to Buy 1 07-03-2008 03:30 PM
Team Losi JRXS TYPE-R John Q R/C Items: Wanted to Buy 1 10-03-2007 06:55 PM
Team Losi JRXS Type R New In Box Canyon R/C Items: For Sale/Trade 0 06-20-2007 04:50 PM
