Old 03-01-2010, 04:22 PM   #11506
F1fletch's Avatar
So I better plan on getting that then....? Does it give you more height to work with or just width?
F1fletch is offline   Reply With Quote
Old 03-01-2010, 05:52 PM   #11507
Yeti35's Avatar
Width is what you gain with that. You don't have to mod that much to get batteries to fit in the car.
JRXS Type R, I have four of them!! ;) ( Yes, I still have them!!)
22 2.0
22T 2.0
Yeti35 is offline   Reply With Quote
Old 03-01-2010, 07:53 PM   #11508
Trader Rating: 66 (100%+)
Does anybody know where I can get a spare topdeck and maybee a screw kit? Would like to experiment with cutting a topdeck for more flex but I can't find one.
Gwoodrc is offline   Reply With Quote
Old 03-01-2010, 07:57 PM   #11509
MaxSp97's Avatar
Here it is for you!
http://www.ampdraw.com/product/3767/...ssis-Top-Plate
Calvin. L
JOY IS IMPATIENT...
COTA Home Of The F1 US Grand Prix
MaxSp97 is offline   Reply With Quote
Old 03-04-2010, 04:48 PM   #11510
bmitchell373's Avatar
Hello, I'm new to this forum and have a Type R. But for the life of me i cant figure out why the car seems to "dog walk" a little bit. All hubs, carriers, knuckles match side to side. Ride height is even. nothings bent. Replaced the rear toe block. Shimmed the slop out. Still "dog walks" any ideas?
JRXS-R 19T brushed (keeping it real), Slash Nitro 2WD worked over 3.3, Slash 4X4 Mamba Max Pro with 1415 2400KV. Ridgecrest 45T comp rig.
bmitchell373 is offline   Reply With Quote
Old 03-04-2010, 04:55 PM   #11511
Company Representative
SweepRacingUSA's Avatar
that happend to me few weeks ago, I had a front arm hige pin mounted wrongway, front to a shorter arm hole, rear on a longer arm hole. Ineed a eye glass bad.
or check make sure hub is not binding by removing a hub out of the arm and mount a wheel as you normaly would and spin it, if you been using regula lock nuts for awhile or just have axles for long time causing binding on the hub bearings.
http://dajohnwee.blogspot.com/2009/0...xs-type-r.html
da john wee~~~
SweepRacingUSA.com 2014 &2015 US. NATIONAL CHAMPION!
10th Buggy F1 TC 8th Buggy 8th Truggy GT8 M-Chassis Monster Truck(SRC) Bodies&Wings
SweepRacingUSA is offline   Reply With Quote
Old 03-04-2010, 04:58 PM   #11512
Pins are correct. Ill have to check all the hubs tho. When the car is in the air is seems ok, but with a load i could see it. Thanks
Old 03-04-2010, 08:15 PM   #11513
morris's Avatar
Trader Rating: 40 (100%+)
what all do ya meen by it dog walks?
AE/VIPER/XPERT/DIRTCHEAPRC.COM/JCONCEPTS
A big thx to all the tracks that I race at:cause if it wasnt for these guys..we wouldnt have a place to race our r/c cars!!!
morris is offline   Reply With Quote
Old 03-04-2010, 08:22 PM   #11514
Just coasting straight or on power, you can see the back of the car kick out to a side, seems mostly like the left. Theres no consistency in it, it just happens every few feet.
Old 03-04-2010, 08:49 PM   #11515
morris's Avatar
yea thats weird...i have had 3 of these cars and never dealt with anything like that before.
what surface you run on?
Old 03-04-2010, 08:57 PM   #11516
Asphalt, I just rebuilt the whole car, The only thing i found is my rear diff is goofy. It like catches if you spin it. It has new rings and gear. But i think i need all new trust set up, balls, and nut/outdrive thing.
Old 03-04-2010, 09:10 PM   #11517
MikeXray's Avatar
Trader Rating: 72 (100%+)
replace the pulley, sometimes you just can't get all the dirt out of them.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 03-04-2010, 09:15 PM   #11518
The rear "big" one was brand new, just old balls.
Heres my car. My first body using Fasmask and cutting paint masks on my vinyl cutter. Don't mind the pink wire, lost a bet with my girlfriend. lol
Old 03-04-2010, 10:26 PM   #11519
Greg Sharpe's Avatar
Trader Rating: 15 (100%+)
Are you running 1' rear hubs? If so, you've got 4' of rear toe, which could be causing the dog walking. Tons of rear toe will make the rear end wander around inconsistently. Chassis has one degree drilled in, picture shows an additional 2' in the pivot block, plus whatever you've got in the rear hubs.
p.s.-make a bet with your girl that the car will handle better with the electronics mounted on the chassis. When you win the bet, have her buy you some black wire.
If only endurance racing was a thing.
Greg Sharpe is offline   Reply With Quote
Old 03-04-2010, 10:30 PM   #11520
It has 2 dots on the rear block so id assume thats 2 degrees. Yea good point CG, didnt even dawn on me when i put the tekin system in it. The car was gutted for a while then new radio and brushless. Duh thanks.
[FS] Team Losi JRXS-Type R squarehead R/C Items: For Sale/Trade 9 07-20-2012 11:59 PM
Team Losi JRXS Type R gtxpro2 R/C Items: For Sale/Trade 18 09-11-2008 07:45 PM
WTB: Team Losi JRXS Type R shifter R/C Items: Wanted to Buy 1 07-03-2008 02:30 PM
Team Losi JRXS TYPE-R John Q R/C Items: Wanted to Buy 1 10-03-2007 05:55 PM
Team Losi JRXS Type R New In Box Canyon R/C Items: For Sale/Trade 0 06-20-2007 03:50 PM
