Old 02-12-2010, 12:14 AM   #11461
what is the difference between Diff pulley and Spool pulley? they look identical! I have a 41 pulley that comes with a red line marked on it. is that a Spool pulley or diff pulley? are they interchangalbe?
THX.
NSLST is offline   Reply With Quote
Old 02-12-2010, 12:31 AM   #11462
dfiantii's Avatar
Trader Rating: 16 (100%+)
Send a message via AIM to dfiantii Send a message via Yahoo to dfiantii
The difference is the spool pulley has no holes made for the diff balls. I think you can still make it work as a spool if you put the sandpaper pieces in there and take the diff balls out.
TT-01/Hitec MG/SP LPF V1.1/Trinity 7.5
Losi Type-R/JR Z8800S/SP GT 2.0
Exotek F1R/Savox 1251/Tekin RS
TLR 22 2.0
"ELECTRIFIED TO THE HILT"
dfiantii is offline   Reply With Quote
Old 02-12-2010, 08:27 AM   #11463
Greg Sharpe's Avatar
Trader Rating: 15 (100%+)
THX.
The black spool pulleys (both the 41 tooth and 42 tooth) have spacers installed over the diff ball holes, but are otherwise the same as the diff pulley. The 41 tooth pulleys (diff, spool, and one-way) are usually used to overdrive the front wheels.
Why don't we endurance race more often?
Greg Sharpe is offline   Reply With Quote
Old 02-12-2010, 11:52 AM   #11464
Trader Rating: 66 (100%+)
Does anbody know if there is a losi part number for a complete diff or do I just need to order everything seperate? Are there any advantages in the flying fox front spool over the stock diff with a spool pulley?
Gwoodrc is offline   Reply With Quote
Old 02-12-2010, 12:33 PM   #11465
Company Representative
SweepRacingUSA's Avatar
no complete set, fflying fox 1pc will give you straight accelation, harder. and snap on braking. but requires some modification to make it last.
http://dajohnwee.blogspot.com/2009/09/front-spool-mod.html read here about it.
da john wee
SweepRacingUSA.com 2014 &2015 US. NATIONAL CHAMPION!
10th Buggy F1 TC 8th Buggy 8th Truggy GT8 M-Chassis Monster Truck(SRC) Bodies&Wings
SweepRacingUSA is offline   Reply With Quote
Old 02-12-2010, 03:43 PM   #11466
crabboy's Avatar
Trader Rating: 58 (98%+)
Guys
I ran the JRXS-R last weekend for the first time and its a great car, but in Mod (4.5) the diff seems to last only one run, i looking for tips you guys have been using to build the diffs.
Rhys
Rhys Marshall.
crabboy is offline   Reply With Quote
Old 02-12-2010, 08:02 PM   #11467
Yokomo_Ant3's Avatar
Trader Rating: 29 (100%+)
Originally Posted by crabboy View Post
Guys
Rhys
Rhys runs outdoors BTW
Antoni Caretti
Team Yokomo - Racing Performer - Sweep Racing
Yokomo_Ant3 is offline   Reply With Quote
Old 02-12-2010, 10:47 PM   #11468
I heard that you Have to use AE Stealth Differential Lube (black letter) with ceramic diff balls, not to use regular red letter AE diff lube. can anyone please varify this. thank you.
Old 02-13-2010, 07:43 AM   #11469
tim fry's Avatar
No never use black grease on the balls just get a decent thrust race and rebuild whenever it get gritty. Xray thrust works well although it is expensive.
tim fry is offline   Reply With Quote
Old 02-13-2010, 09:39 AM   #11470
he ment Black Letters. yes a stealth lube does have black letters on it, use that. as you've said black thrust grease is for the thrust BB. clear stealth grease have black letters on a packaging is for the Diff balls
da john wee
Old 02-13-2010, 02:06 PM   #11471
rallyebmx's Avatar
Trader Rating: 21 (100%+)
da john wee
Thats interesting about the spool, thanks. I just started running it last night. What about that foreign company that makes the alu outdrives? Would that be a good option for the spool?
cpaurl
rallyebmx is offline   Reply With Quote
Old 02-13-2010, 02:25 PM   #11472
IMO not an good idea, origianl plastic cup design is like having an plastic C pillow, kinda cushion for the CVDs to ride on, metal outdrive will creates groove (half pipe?) figure in no time and that will cause binding. you know how horrible that is.
da john wee
Old 02-13-2010, 10:16 PM   #11473
rallyebmx's Avatar
Thanks. I want to try a fan on my motor, but it seems a 20mm fan is hard to come by. Any suggestions?
cpaurl
Old 02-14-2010, 05:05 AM   #11474
Here's an eBay source, although it's expensive. Sym Bang makes fans that a number of big r/c suppliers have labeled over the years, although it's tough to search for those because they're never called "sym bang" fans.
Old 02-14-2010, 12:15 PM   #11475
rallyebmx's Avatar
Thanks Greg. I was just doing some measuring, its seems like running one 30mm fan diagonally on top of the motor might work. The screw holes diagonally on each bulkhead measure about 42mm apart. Close to the measurement of the holes diagonally on a 30mm fan
Also, a separate newb question. I have experienced advances in the esc technology after starting this year with an LRP Sphere and now having a Tekin RS. I currently run my friends used Duo 13.5 motor. Does anybody know if there is an amount of normal usage time or whatever, where a brushless motor will start to fall off performance wise ? I am thinking about trying a new motor. Are all good 13.5 relatively the same performance wise? I just dont want to get a certain one, and then find another is superior or...... Kind of like the esc stuff i guess.
Dont kill me-Is a Duo 2 better than a Duo?
cpaurl
[FS] Team Losi JRXS-Type R squarehead R/C Items: For Sale/Trade 9 07-20-2012 11:59 PM
Team Losi JRXS Type R gtxpro2 R/C Items: For Sale/Trade 18 09-11-2008 07:45 PM
WTB: Team Losi JRXS Type R shifter R/C Items: Wanted to Buy 1 07-03-2008 02:30 PM
Team Losi JRXS TYPE-R John Q R/C Items: Wanted to Buy 1 10-03-2007 05:55 PM
Team Losi JRXS Type R New In Box Canyon R/C Items: For Sale/Trade 0 06-20-2007 03:50 PM
