Old 01-28-2010, 09:11 PM   #11386
am somewhere on page 540 and counting. I read in reverse thou (in like 2008 replys)
can anyone please tell if this batt fits w/o hand fitting and is this pack good enought for 13.5t rubber. only haft price compared to top name brand w/ the same C and mAh.
here is the size of the pack:
Diemensions: approx. 140 x 45 x 22mm
Team Losi JRXS Type-R-bj1jkfwcgk%7E%24-kgrhqih-dqes777ivdbblvczz2mvw%7E%7E_12.jpg
NSLST is offline   Reply With Quote
Old 01-28-2010, 10:21 PM   #11387
Trader Rating: 66 (100%+)
Originally Posted by Greg Sharpe View Post
How big is your track? With the latest adjustable timing ESCs, most tracks wouldn't necessitate running such a low numerical FDR. On our 100' indoor track, most of us are at 5.5 or higher, and using 118 or lower spurs works well. But to answer your prayers, grab a FlyingFox layshaft so you can use any common spur gear. That will allow you to fit more motors.
I got the flying fox layshaft in the car, so spur gear options are not a problem. I was just wondering what the norn was on this car for spur. Our track is 36x77, I have a sp lpf with the stock107 software and a sp 17.5, I just sold a HB cyclone that I ran this in and it ran best on our track at a 4.5fdr. The type-r that I got has a 116 spur on it now, so I went to put a 46 pinion on it and it wouldn't come close to going on, so I guess i'll drop down on the spur till I can get a pinion/spur combo to fit the car and give me the 4.6fdr for a starting piont.
Gwoodrc is offline   Reply With Quote
Old 01-29-2010, 12:02 AM   #11388
If it are really 45x22 mm it fits wery well
ciao ciao
www.wildracers.it
Belty Dog is offline   Reply With Quote
Old 01-29-2010, 05:22 AM   #11389
JRXS_chris's Avatar
Looks identical to the Demon 5040 I use. If it is it's got cell mounting lugs underneath so you will have to modify your Lipo tray (metal or plastic) for it to fit properly.
JRXS_chris is offline   Reply With Quote
Old 01-29-2010, 11:33 AM   #11390
Default carpet foam setup
after reading some pages and others setups, it is my understanding that I will be needing 6 degree hubs in order to run indoor carpet foam setup, my question is will 4 degree hubs cut it? and please also recommened a pinion size for 13.5t.
thank you.
Old 01-29-2010, 12:00 PM   #11391
jkirkwood's Avatar
You could probably develop a setup around the 4 deg carriers it's just 6 deg is much more common and easier to drive.
SMC Racing | AKA Products | Serpent America | Android Nitro Runtime Calculator
jkirkwood is offline   Reply With Quote
Old 01-29-2010, 07:26 PM   #11392
Company Representative
SweepRacingUSA's Avatar
going to race this Sunday! woo hoo!
can you spot a Type-R from that pic?
SweepRacingUSA.com 2014 &2015 US. NATIONAL CHAMPION!
10th Buggy F1 TC 8th Buggy 8th Truggy GT8 M-Chassis Monster Truck(SRC) Bodies&Wings
SweepRacingUSA is offline   Reply With Quote
Old 01-29-2010, 09:21 PM   #11393
MaxRain's Avatar
thank you.
One thing to remember, 4 degree hubs are better for hairpin type turns. 6 degree may be better suited for longer sweepers. My advice is to study the track layout and decide from there.
For my particular track, I thought 6 degree carriers were better, but after a while I started realizing how to apply the above knowledge.
Gordon "slow is fast"
Stock Car - Xray T3 EU Rubber, Modified Car - Xray T4 '14; Xray X1; Tamiya M-06
My Youtube Channel: search "CARCAR videos" or follow this link https://www.youtube.com/channel/UC7fp4qynjJzlXw13ocDpVAg
Facebook: CARCAR
MaxRain is offline   Reply With Quote
Old 01-29-2010, 09:28 PM   #11394
please enlighten me on PIONION size, at least, where to get started. like Robson Racing pinion, like what pitch? ie 18t, 48pitch something. (for indoor carpet, rubber or foam track)
thanks a million guys, am tyring to buy all the required parts b4 car arrives.
am off road guy, just jump in to on road 3 days ago.
Old 01-30-2010, 10:50 AM   #11395
MaxRain's Avatar
Which ESC do you plan on using? This will determine which spur and pinion you use. For indoor racing on carpet, it is recommended that you use 64 pitch vs 48 as it allows for finer tuning.
Facebook: CARCAR
Old 01-30-2010, 03:54 PM   #11396
am going to use mamba max + 6900 and will get a 13.5t later. thx.
Old 01-30-2010, 06:11 PM   #11397
morris's Avatar
Trader Rating: 40 (100%+)
last winter season i was using an lrp sphere.with a orion 13.5 motor.our track is a little bit bigger than yours and we would of have been using almost the same fdr.i used a 118 spur and a 45 pinion gear.
now i use the tekin rs pro...this set-up is way different as i am running a 6.75 fdr
hope this helps.
AE/VIPER/XPERT/DIRTCHEAPRC.COM/JCONCEPTS
A big thx to all the tracks that I race at:cause if it wasnt for these guys..we wouldnt have a place to race our r/c cars!!!
morris is offline   Reply With Quote
Old 01-30-2010, 06:14 PM   #11398
morris's Avatar
i also found that running foam tire pretty much anywhere that 4 degree hubs worked better for me...6 gave the car to much steering and made it feel twitchy.
although i am using 6 now.but dialed the car to them.4 gives the car i think much more of a relaxed/easy feeling drive.
hope this helps.
Old 01-30-2010, 09:17 PM   #11399
Default Front spool
I just picked up a used type-r with a buttload of parts but I need a front spool, can somebody give me a part number and tell me where is the best place to get parts for this car. Thanks, Greg.
Old 01-31-2010, 05:41 AM   #11400
JRXS_chris's Avatar
Forgive me gents for I have sinned....
There is an Xray sat on my bench.
Trying something new for a while as I'm becoming increasingly disillusioned by the lack of support (i.e none) for this great car here in the UK. Very sad
I can't get any set up advice when I'm at a meeting as I'm often the only Losi runner.
The Type R is not being sold or retired and will most likely get some action again when I get fed up of trying to balance this orange thing.
[FS] Team Losi JRXS-Type R squarehead R/C Items: For Sale/Trade 9 07-20-2012 11:59 PM
Team Losi JRXS Type R gtxpro2 R/C Items: For Sale/Trade 18 09-11-2008 07:45 PM
WTB: Team Losi JRXS Type R shifter R/C Items: Wanted to Buy 1 07-03-2008 02:30 PM
Team Losi JRXS TYPE-R John Q R/C Items: Wanted to Buy 1 10-03-2007 05:55 PM
Team Losi JRXS Type R New In Box Canyon R/C Items: For Sale/Trade 0 06-20-2007 03:50 PM
