Old 01-22-2010, 09:35 PM   #11371
Trader Rating: 29 (100%+)
Ok!!!
manthree is offline   Reply With Quote
Old 01-22-2010, 10:58 PM   #11372
RKeasler's Avatar
Location: A step closer to where I need to be a step further from where I was
Guys is there a rear belt from another car that fits the Type R?
Rod
ClemsonTigers
Team C Racing
TA10
RKeasler is offline   Reply With Quote
Old 01-25-2010, 11:45 AM   #11373
Company Representative
SweepRacingUSA's Avatar
WADAFA ! TTT
I will finally get to run at the horsharm indoor carpet this Sunday, Ray Murray who organised this "slow-birds" was kind enough to have this race on Sunday for rest of us!
to get ready for this race, I did few things on my machine.
I soldered input wires on back of a Tekin RS then soldered Deans in 90 degrees to make wiring more simple and save some high gravity mounted weight, 2pc of 12 AWG in few inches should be meaningful on car's cornering weight.
but...I can't shrink wrap the wires, I quit smoking 2years ago and got rid of all the matches, lighters and candles!
I'm going to start off with Greg sharpe's set up for the track to begin with, but that 2deg front anti dive and a 41t Fr pulley kinda got me worried. but oh well!
Here I come another roller coaster race day!
1st time on the horsharm
1st time trying totally different set up!
with 3 cups of coffee!!
me and Alex V (kwikdub) was PM each other from 8 in the morning today talking about this, telling each other HOW WE CAN'T WAIT!
Peace out brothers!
PS: more pics on my blog.
SweepRacingUSA.com 2014 &2015 US. NATIONAL CHAMPION!
10th Buggy F1 TC 8th Buggy 8th Truggy GT8 M-Chassis Monster Truck(SRC) Bodies&Wings
SweepRacingUSA is offline   Reply With Quote
Old 01-25-2010, 12:36 PM   #11374
I have a couple of Type-r's for sale with parts if anyone is looking. These need to go so make me an offer.
http://http://www.rctech.net/forum/r...e-rs-sale.html
Thanks,
Curtis
Fantom Racing | On-Point Racing | Parma/PSE | www.4chobbysupply.com
cmenard is offline   Reply With Quote
Old 01-25-2010, 01:20 PM   #11375
Greg Sharpe's Avatar
Trader Rating: 15 (100%+)
Originally Posted by da_John_wee View Post
[COLOR=#000000]I will finally get to run at the horsharm indoor carpet this Sunday, Ray Murray who organised this "slow-birds" was kind enough to have this race on Sunday for rest of us![FONT=Georgia]
John, if the car is too twitchy for your liking try the following in order:
  1. zero drag brake, 10 push
  2. remove both anti-dive and anti-squat, also remove push control
  3. try less ackerman, use outer steering rack holes
  4. swap to 42 tooth pulley
See you Sunday!
Why don't we endurance race more often?
Greg Sharpe is offline   Reply With Quote
Old 01-26-2010, 10:32 AM   #11376
See you Sunday!
then that will be my normal set up, haha
you should try a 57 pistons on front for less weight transfer to front too quick.
BTW got those white bladder for my shocks and it feel good! thanks
Old 01-28-2010, 12:39 AM   #11377
Hi guys,
bumped the other thread by mistake, sorry.
Any type-r's at the snowbirds?
dr_speed is offline   Reply With Quote
Old 01-28-2010, 02:42 PM   #11378
hello guys, am new to on road, my type Rs are still on the way. I read 250 pages on type R in 2 days but I think I need a quick answer cuase I have to buy parts b4 I finish reading all 700 pages. so
am going to run indoor carpet, 13.5T. please recommned me a set of foam tyes, and pinion size. am using mamba max 5700 now, but will buy 13.5t for it later.
please also recommend me a 13.5 BL system.which one is a drop-in fit? is LRP SXX STCOK/X12 a direct fit? Tekin is good, but I have to modify the motor to fit it in??
thank you in advance.
NSLST is offline   Reply With Quote
Old 01-28-2010, 03:08 PM   #11379
Yes, the X12 drops right in. The Duo1 also fits, along with all of it's "newer" sisters. The Novak Ballistic series clear by a mile too. Frankly, you usually don't need to mod the left rear pivot mount.
Old 01-28-2010, 03:29 PM   #11380
Trader Rating: 66 (100%+)
Default Gearing?
Ok, I just got a type-r and I need some info on gearing. I am running a SP 17.5 and I need to gear it around a 4.6-4.3 ( that was what worked best on my cyclone on our track). The car has a 116 spur and I cant get anywhere close to that as the motor is hitting the rear inner pivet block, do I just need to drop to a smaller spur or what are the norms on the spurs that you guys are running in 17.5. Thanks, Greg.
Gwoodrc is offline   Reply With Quote
Old 01-28-2010, 03:30 PM   #11381
only motor that can have some fits problem is a Tekin 17.5 , if you wanted to run 118 spur with that you might have a problem.
Old 01-28-2010, 05:39 PM   #11382
How big is your track? With the latest adjustable timing ESCs, most tracks wouldn't necessitate running such a low numerical FDR. On our 100' indoor track, most of us are at 5.5 or higher, and using 118 or lower spurs works well. But to answer your prayers, grab a FlyingFox layshaft so you can use any common spur gear. That will allow you to fit more motors.
Old 01-28-2010, 07:33 PM   #11383
so the tekin motor size is different from 17.5 to 13.5??
I also read someone had to bend the soldering tab on tekin motor? am I wrong on that?
Old 01-28-2010, 07:48 PM   #11384
no no no
all the tekins are all in same size, what I mean was if you run 17.5 you will need a huge pinion gears then motor will touch a arm mount. which dont happend often in 13.5 motor.
unless you onw a Tekin motor dont worry bout it.
BTW a duo 2 by epic w/ Tekin RS is da bomb. or with the Novak ballistic motor/ aTekin RS
Old 01-28-2010, 09:06 PM   #11385
no no no
thank you.
[FS] Team Losi JRXS-Type R squarehead R/C Items: For Sale/Trade 9 07-20-2012 11:59 PM
Team Losi JRXS Type R gtxpro2 R/C Items: For Sale/Trade 18 09-11-2008 07:45 PM
WTB: Team Losi JRXS Type R shifter R/C Items: Wanted to Buy 1 07-03-2008 02:30 PM
Team Losi JRXS TYPE-R John Q R/C Items: Wanted to Buy 1 10-03-2007 05:55 PM
Team Losi JRXS Type R New In Box Canyon R/C Items: For Sale/Trade 0 06-20-2007 03:50 PM
