Old 01-18-2010, 09:41 AM   #11326
Rouge711's Avatar
Originally Posted by Marcos.J View Post
never mind i found it!!
thanks
now how do i get this in the us??
Send him a mail, he will ship it.
It can be said I have your same problem, but in reverse. Should I buy an item outside of Europe, but I don't have good communication with those who make them.........
Team Associated
Team Trinity
Thunder Tiger Europe
Rouge711 is offline   Reply With Quote
Old 01-18-2010, 10:55 AM   #11327
Company Representative
SweepRacingUSA's Avatar
Originally Posted by MaxRain View Post
What are you guys using to sand the diff rings? I know da john wee posted something in the past about this.
I am thinking about ordering the yeah racing diff set from rcmart. Is this suggested? Thanks for your comments..
I used a one of LOSA3097 (xxx-s composite diff halve) to hold a ring in its place to sand it down.
SweepRacingUSA.com 2014 &2015 US. NATIONAL CHAMPION!
10th Buggy F1 TC 8th Buggy 8th Truggy GT8 M-Chassis Monster Truck(SRC) Bodies&Wings
SweepRacingUSA is offline   Reply With Quote
Old 01-18-2010, 11:04 AM   #11328
Super Moderator
Marcos.J's Avatar
Trader Rating: 140 (100%+)
Will do
Old 01-19-2010, 07:37 AM   #11329
jkirkwood's Avatar
Ran this car this weekend in Cincy at the big race. It was really good at the beginning weekend but just didn't get much better. As the traction came up my car just got really easy to drive but was just too stuck, attempts to free it up wasn't enough. Had a few problems with traction rolling early but that was fixed by some anti-dive in the front and lowering the body a bit, after those two adjustments it was good. Looking back now I would had done a few settings different between rounds.
I ended up qualifying 6th and finishing near the bottom of the A-final in 8th after blowing a motor in round 4 of qualifying and running a new motor for the main which I didn't get any track time on. The result was a disastrous misjudgment in gearing on my part. Live and learn and race another day.
I would like to thank Tory at Skyrocket for the support.
SMC Racing | AKA Products | Serpent America | Android Nitro Runtime Calculator
jkirkwood is offline   Reply With Quote
Old 01-19-2010, 08:03 AM   #11330
liljohn1064's Avatar
Trader Rating: 16 (100%+)
Send a message via AIM to liljohn1064 Send a message via MSN to liljohn1064 Send a message via Yahoo to liljohn1064
Originally Posted by Ray k View Post
Thanks guys, these are definitely warped. I will replace them during the rebuild.
This might sound odd, but are the inner hinge pins located in the right holes. Front might be in the bottom and the rear in the top. That would make the pins not parallel. It would also throw off the toe to some extent.
Just chiming in. Not sure if it was fixed already.
John
John Higgins
liljohn1064 is offline   Reply With Quote
Old 01-19-2010, 11:15 AM   #11331
Ray k's Avatar
Trader Rating: 46 (98%+)
John
Thanks John , no it was a bad set of arms.
Ray k is offline   Reply With Quote
Old 01-19-2010, 01:09 PM   #11332
YmeBP's Avatar
Trader Rating: 32 (100%+)
You are welcome! And you still made the A!!
I will have to try that antidive to curb some of the traction rolling issues i have now!
www.skyrocketracing.com quality RC gear!
http://www.rctech.net/forum/racing-forum/555071-2011-skyrocket-invitational-blue-diamond-raceway-october-15-16-a.html <- Great race!
YmeBP is offline   Reply With Quote
Old 01-19-2010, 01:13 PM   #11333
YmeBP's Avatar
Montech racing makes it and work very well.
Does someone knows where to buy F.F. layshaft and spool in Europe?
You can get one from us here in the states, or straight from oz, not sure if he's got a eu distributor quite yet. I'm waiting on stock but word on the street was very very soon for a restock.
Old 01-19-2010, 01:15 PM   #11334
bjames's Avatar
Trader Rating: 20 (100%+)
Default losi ?
I was wondering if anyone had a good setup from last years snowbirds for rubber tire. Also, has anyone had trouble with the flying fox spool and the plastic outdrives breaking and if so is there a solution?
-Brian James-
bjames is offline   Reply With Quote
Old 01-19-2010, 02:20 PM   #11335
YmeBP's Avatar
Breaking no, stripping out yes but only in high traction situations. Paul is working on a solution to this issue and i think you all will be very happy with the final product.
For the stripping John (da John Wee on the forums) came up w/ drilling tapping and setting a small grub screw in the outdrives to prevent them from spinning in the spool.
Old 01-19-2010, 02:42 PM   #11336
Unreal. Good luck with the car!
John Higgins
Old 01-19-2010, 07:25 PM   #11337
rallyebmx's Avatar
Trader Rating: 21 (100%+)
I've got 5 race days on my Type R. Just my front diff feels rough when i spin it by hand. Add a day of grit from racing and it feels gross. I clean it for every race day. I havent touched my rear for a few race days now and it still feels smooth. I do run my front diff a bit tighter than my rear. Should i replace the balls or...
cpaurl
rallyebmx is offline   Reply With Quote
Old 01-19-2010, 07:32 PM   #11338
YmeBP's Avatar
The front diff in my car gets gritty after about a weekend of racing 4 rounds of 6 minutes. I usually don't rebuild until it gets bad because i'm lazy.
Fairtrace and just about every other fast driver yells at me when they feel the diff . I'd say a rebuild after a weekend of racing would get rid of that, also the mcmaster thrust bearing does quite a bit to help your diff stay smoother longer.
Old 01-19-2010, 10:54 PM   #11339
jkirkwood's Avatar
The anti-dive really smooths out the steering in high traction, it may take too much away. I just shimmed it .030". I was able to continue running high roll center all around with just this one change.
I had to take the anti-dive back out tonight at the local club race. The home track being smaller and not has much speed it really needed allot more steering.
Old 01-19-2010, 10:55 PM   #11340
jkirkwood's Avatar
Run a front spool with rubber tires! That is if you are running rubber tires.
[FS] Team Losi JRXS-Type R squarehead R/C Items: For Sale/Trade 9 07-21-2012 12:59 AM
Team Losi JRXS Type R gtxpro2 R/C Items: For Sale/Trade 18 09-11-2008 08:45 PM
WTB: Team Losi JRXS Type R shifter R/C Items: Wanted to Buy 1 07-03-2008 03:30 PM
Team Losi JRXS TYPE-R John Q R/C Items: Wanted to Buy 1 10-03-2007 06:55 PM
Team Losi JRXS Type R New In Box Canyon R/C Items: For Sale/Trade 0 06-20-2007 04:50 PM
SEO by vBSEO 3.5.0
