Old 01-09-2010, 02:56 AM   #11266
jrxs-r's Avatar
Have you got the Flying Fox Layshaft? If so, then use a smaller spur. If not, order one now!
Cheers,
Zack
___________________________________________________________________________
Proudly Sponsored by Stanbridges Hobbies
Serpent S411
jrxs-r is offline   Reply With Quote
Old 01-09-2010, 07:10 PM   #11267
Company Representative
SweepRacingUSA's Avatar
Originally Posted by Giorgio View Post
Well..... I'm back!
I was forced to stay awya form my Losi (and all related upgrade project) for job reason, but now the new season is approaching and I'll do my best to race as mcuh as possibile.
We will have a new class (for us...) using 13.5 motor (single brand, Lipotech).
I need all the ideas and suggestions from you 13.5 guys (I was 4.5 before...)
I gearing should be in the 4-5ish area. Will be worth use the 41 gears inestad of the 42 in the diff? Just to avoid pinions big as frying pans...
for a 13.5 I wouldn't worry about a 41t pulley.
SweepRacingUSA is offline   Reply With Quote
Old 01-10-2010, 03:11 AM   #11268
jrxs-r's Avatar
Just finished rebuilding my 2x Type Rs after a total strip down. I machined the rear motor bulkheads to accept the new IP5000 40C/50C packs. Took about 0.75-1mm off the side and the top. On assembling the top deck and screwing it down onto the rear bulkheads, you will need to use a #4 washer to space the screw up so it wouldn't get in contact with the LiPo. Have a look see and you will know what I am talking about.
Team Losi JRXS Type-R-_dsc0086.jpg   Team Losi JRXS Type-R-_dsc0088.jpg   Team Losi JRXS Type-R-_dsc0090.jpg   Team Losi JRXS Type-R-_dsc0101.jpg   Team Losi JRXS Type-R-_dsc0102.jpg
Cheers,
Zack
Serpent S411
Old 01-10-2010, 03:13 AM   #11269
jrxs-r's Avatar
Oops... left out the pic of the machined bulkheads on the car... Apologies.
Cheers,
Zack
Serpent S411
Old 01-10-2010, 06:25 AM   #11270
MikeXray's Avatar
Trader Rating: 73 (100%+)
most of us just dremel a few threads off the screw.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 01-10-2010, 12:52 PM   #11271
wow some heavy duty wiring going on there, look at the thickness of the input wires
Old 01-10-2010, 01:28 PM   #11272
dcuz383's Avatar
Default Carpet Help
I need a carpet setup sheet for rubber tires. I have three cars and I want to leave one with my current setup and try two different setups on the other two cars. Track will be minreg then snowbirds. Tires will be zenons and jaco blue. LTC-R body. 17.5 and 13.5 TC
Also I have a couple new Black Diamonds and one new Tekin RS speedo's to try. Any advise on gearing and profiles would help. Thanks
I would probably hate me too!
dcuz383 is offline   Reply With Quote
Old 01-10-2010, 07:04 PM   #11273
Trader Rating: 32 (100%+)
Forget it.
marooko is offline   Reply With Quote
Old 01-10-2010, 09:38 PM   #11274
Greg Sharpe's Avatar
Trader Rating: 15 (100%+)
This setup is for 17.5 with Jaco Blues and from a carpet track that has only ever had Jack the Gripper on it, which apparently is similar to the traction you'll be using at the 'birds. The setup is very throttle sensitive, but it is fast. Hope it helps put your Losi up front.
Why don't we endurance race more often?
Greg Sharpe is offline   Reply With Quote
Old 01-11-2010, 07:57 AM   #11275
jrxs-r's Avatar
Come to think of it...it does look huge in those pics... actually 12GA wire...
Cheers,
Zack
Serpent S411
Old 01-11-2010, 09:17 AM   #11276
Giorgio's Avatar
Well...the idea to use those 41, was due the fact I'm having a bunch of them laying here and there, with no use....
I saw some guy here using the 41 in the 10.5 class...
It's completely meaninless? I've no experience at all with 13.5...
https://www.facebook.com/FenixRacing.it/
www.fenixracingshop.com
Giorgio is offline   Reply With Quote
Old 01-11-2010, 09:31 AM   #11277
if you already have them than why not, I installed 41t pullies on my XXX-S for a same reason. I had so many of them in my parts box.
Old 01-11-2010, 01:30 PM   #11278
I'm lucky that my brother also has the losi. He can run 41's for stock, and I can run 42's for mod. That way they get used.
I thought I might post up something I was just playing with. Just rebuilding my diffs and noticed that the spring doesn't seem to sit very flat. I tried changing it out to a TC5 spring that I had on hand but ran into a problem with it being to small to fit the diff tube. So flipped the thrust and spring around and WOW! Diff was so much smoother than before! I rebuilt another diff and tried it with the losi and TC5 springs configured in the same way but the TC5 spring is soooooooo much better. Might be worth playing with guys...
Pics below.
Blade: Andro Treiber H 79g AN
FH: Donic Bluefire M3 Max Blk
BH: Donic Bluefire M2 Max Red
Powered by Falco
Dragonfire is offline   Reply With Quote
Old 01-11-2010, 01:33 PM   #11279
Trader Rating: 69 (100%+)
I just ran the Novak race,car was very good,iqualified 2nd in 17.5 a main,had some issues and ended up 5th overall,Jim piersol car was also very fast i believe he ended up 2nd,car was just a little tight during the mains but still had a blast.
steve eaves is offline   Reply With Quote
Old 01-11-2010, 01:52 PM   #11280
Pics below.
yeah, I played with a alum washer under the spring to help the spring to seat flat but wasnt much better, I found out that spring is a ASC6582 which is a general 1/10th diff spring for the AE cars, (which I have plenty!) I'll try that in my next rebuilt, thanks!
WOW good job. please share your set up sheet with us!
[FS] Team Losi JRXS-Type R squarehead R/C Items: For Sale/Trade 9 07-20-2012 11:59 PM
Team Losi JRXS Type R gtxpro2 R/C Items: For Sale/Trade 18 09-11-2008 07:45 PM
WTB: Team Losi JRXS Type R shifter R/C Items: Wanted to Buy 1 07-03-2008 02:30 PM
Team Losi JRXS TYPE-R John Q R/C Items: Wanted to Buy 1 10-03-2007 05:55 PM
Team Losi JRXS Type R New In Box Canyon R/C Items: For Sale/Trade 0 06-20-2007 03:50 PM
